Electric field in cylinder with missing section
The discussion focuses on calculating the electric field around a uniformly charged, non-conducting, infinitely long cylinder with a cylindrical void. The cylinder has a charge density ρ (C/m³) and a radius A, while the void has a radius A/2. The key equations utilized include Gauss's Law, specifically flux = E A cos(θ) and total charge = (ρ)(volume). The solution involves modeling the charge distribution as two solid cylinders, one positively charged and the other negatively charged, to account for the missing section.
  • Understanding of Gauss's Law and its applications
  • Familiarity with electric field calculations for cylindrical geometries
  • Knowledge of charge density and its implications in electrostatics
  • Basic concepts of electric flux and its relationship to charge
  • Study the derivation and application of Gauss's Law in various geometries
  • Learn how to calculate electric fields for composite charge distributions
  • Explore the concept of superposition in electrostatics
  • Investigate the effects of charge density variations on electric fields
Students and educators in physics, particularly those focusing on electromagnetism, as well as anyone involved in solving electrostatic problems involving complex charge distributions.
hawaiigurl123
A uniformly charged, non-conducting, infinitely long cylinder of radius A is parallel to the z-axis, and its central axis intersects the x-y plane at the origin. It has a charge density p (C/m^3). Material is removed from the cylinder leaving a cylindrical void of radius A/2 running parallel to the z-axis, but its central axis intersects the x-y plane at the point x = A/2, y =0. Calculate the electric field at the points x = 0, x = A/4, x = A/2, and x = A.
flux = E A cos(theta)
total charge = (p)(volume)
flux = total charge/e0
area of cylinder cross section before removal: piA^2
area of void cross section: (piA^2)/4
area of cylinder cross section after removal: (3piA^2)/4
We're working on Gauss's Law in class so I'm guessing I'm supposed to use that, and I think I understand how to do this if a section wasn't missing, but I have no idea how to take into account the off-center missing section.
Thanks!
Hint: You can cancel a positive charge by adding a negative charge.
What kind of negative charge would you need to add to produce the given charge distribution with its missing section?
I'm not sure I understand...
You mean, in order to keep p of the area as a whole constant before and after material is removed?
Here's what I'm getting at. Finding the field from a solid cylinder (or two solid cylinders) is easy. But having a missing piece makes it hard. So see if you can model the charge distribution with the missing piece as being composed of two solid cylinders, one of which happens to be negatively charged.
I think I got it now. thanks a lot!
  • · Replies 36 ·
  • · Replies 21 ·
