Electric field of a wire segment
The discussion focuses on calculating the electric field a distance 'z' above the midpoint of a straight line segment of length 2L with a uniform charge density λ, as presented in Griffith's book. The electric field is derived using the integral E = (1/4πε₀) ∫(0 to L) (2λz / (z² + x²)^(3/2)) dx. The evaluation of the integral is clarified through a substitution method involving trigonometric identities, leading to the final expression for the electric field as E = (1/4πε₀) [2λL / (z√(z² + L²))]. Additionally, the implications of taking the limit as L approaches infinity are discussed, resulting in a nonphysical scenario where the electric field simplifies to E = (2λ / (4πε₀z)).
  • Understanding of electric fields and charge distributions
  • Familiarity with calculus, particularly integration techniques
  • Knowledge of trigonometric identities and substitutions
  • Basic concepts of electrostatics from Griffith's "Introduction to Electrodynamics"
  • Study the evaluation of integrals involving trigonometric substitutions
  • Explore the concept of electric fields from infinite charge distributions
  • Learn about the implications of singularities in electrostatics
  • Review Griffith's book for additional examples of electric field calculations
Students of physics, particularly those studying electromagnetism, educators teaching electric field concepts, and researchers exploring electrostatic phenomena.
Reshma
This is a solved example in Griffith's book.
Question: Find the electirc field a distance 'z' above the midpoint of a straight line segment of length 2L, which carries uniform charge \lambda
Solution: Let me work out the steps and show you where my problem is(I have avoided showing some of the steps).
The coordinate axis has been set up taking the midpoint of the wire as the origin. Magnitude of the electric field is given by:
E = \frac{1}{4\pi \epsilon_0} \int_{0}^{L} \frac{2\lambda z}{(z^2 + x^2)^{3/2}} dx
HERE, Griffith has not elaborated the evauation of the integral under the bracket and directly given the solution. I have tried my level best to solve it but couldn't suceed. So can someone show me the intermediate steps involved in evaluating the integral:
\int_{0}^{L}\frac{1}{(z^2 + x^2)^{3/2}} dx (\lambda & z are constants)
For your convenience, the final solution is:
E = \frac{1}{4\pi \epsilon_0} [\frac{2\lambda L}{z\sqrt{z^2 + L^2}}]
to deal with the integral \int \frac{1}{(z^2+x^2)^{3/2}} dx
try putting x = z \tan\theta
and using the identity 1+\tan^2\theta = \sec^2\theta
Thank you for the guidance. Here is my evalution of the integral:
\int_{0}^{L} \frac{z^2\sec^2 \theta d\theta}{({z^2\tan^2 \theta +z^2})^{3/2}}
= \frac{1}{z^2} \int_{0}^{L} \cos \theta d\theta
= \frac{1}{z^2} [\sin \theta] \mid_{0}^{L}
= \frac{1}{z^2} \frac{x}{\sqrt{z^2 + x^2}} \mid_{0}^{L}
=\frac{1}{z^2} \frac{L}{\sqrt{z^2 + L^2}}
Sticking to the original question, electric field is:
How will the formula be modified if L\rightarrow \infty
Consider that \sqrt{z^2 + L^2} = L \sqrt{1 + (z/L)^2}
Now can you see what happens when L\rightarrow \infty ?
Wow! Thanks Doc Al :smile:.
E = \frac{1}{4\pi \epsilon_0} [\frac{2\lambda L}{z L\sqrt{1 + (z/L)^2}}]
So,(z/L)^2\rightarrow 0
Hence,
E = \frac{2\lambda}{4\pi \epsilon_0 z}
Please note, that the solution in a limit of L→∞ is nonphysical. The total charge of such system is infinite. That leads to another singularity: the electrostatic potential at any point of the space is also infinite.
\varphi(z)=\int_{z}^{\infty}E(\zeta)d\zeta=\infty
  • · Replies 18 ·
