Electric field of finite line charge and 2 point charges
The discussion focuses on calculating the electric field at the origin due to a finite uniform linear charge density (ρ_L = 4 nC/m) and two point charges (8 nC each) located at specified coordinates. The participants explore the complexities of integrating the electric field contributions from the line charge, particularly the limits of integration and the correct formulation of the electric field equations. The consensus indicates that the correct limit for the integral is 7, derived from the geometry of the line charge, and the final electric field at the origin is determined to be approximately -7.231 i - 7.231 j V/m.
  • Understanding of electric field concepts and equations, specifically for point charges and line charges.
  • Familiarity with calculus, particularly integration techniques in vector fields.
  • Knowledge of coordinate transformations, especially rotating coordinate systems for simplification.
  • Proficiency in using MATLAB for numerical verification of analytical solutions.
  • Study the derivation of electric fields from continuous charge distributions, focusing on finite line charge scenarios.
  • Learn about coordinate transformations and their applications in simplifying electric field calculations.
  • Explore numerical methods for solving integrals related to electric fields, particularly using MATLAB.
  • Review the principles of symmetry in electric fields to predict field directions and magnitudes effectively.
Students and professionals in physics, electrical engineering, and applied mathematics who are involved in electrostatics and electric field calculations, particularly those dealing with complex charge distributions.
eminem14
A finite uniform linear charge ρ_L = 4 nC/m lies on the xy plane; start point and end point are (7,0,0) and (0,7,0) .While
point charges of 8 nC each are located at (0, 1, 1) and (0, -1, 1). Find E at (0, 0 ,0)
dE=ρ_L *dz'/4∏ε * (r-r'/[magnitude(r-r')]^3)
where r'=z' *a_z and r=ρ * a_ρ and z=0, 0<=∅<=2∏
dE_ρ=ρ_L*dz'/4∏ε *ρ/R^3 dE_z= - ρ_L*dz'/4∏ε * z/R^3
I obtained the E-field contributions of the two point charges using the E-field formula for a point charge. However, the line charge is tricky because if it were infinite there would only be the ρ component contributing. I know the length of the rod matters and also the vector from the point of observation (0,0,0) to the midpoint of the rod. However, can't quite connect the dots. Need some help asap.
Thank you in advance
It might be easier to rotate the set-up 45 degrees, so the line of charge runs from (a, -a) to (a, a). Which way will the field act at O? What is the magnitude of the field an element of the line length dy at (a, y) exerts at O? What is the component of this in the direction of the net field?
i got to a solution for the line charge:
Q=ρ_L * dL= 4*10^-9 *(dx + dy)
=> k*ρ_L /_Rmagnitude^3∫Rx dx + k*ρ_LRmagnitude^3∫Ry dy
where R is the vector pointing from the origin to the midpoint of the line charge
=> R= -3.5i -3.5j
but what are the limits of the integral? i did it over the length of the line charge √(7^2 + 7^2)= 7√2
it ddnt get the correct result. however when i did the integral over the L*(√2)/2= 7 it got the correct result. (i verify the result by running a MATLAB solution I have)
I don't know why 7 is the correct upper limit for the integral. Can u tell me why?
Not sure why you solved for Q.
Looking at this a couple of ways, I would suggest:
note symmetry so that the E field is in the direction of i + j , i.e. 45 deg. from x to y axis
then determine an element of E along this direction as dE = {kρdL/r2}cos(θ - π/4)
then use y = -x + 7
and dL = √2 dx
x = r cosθ
y = r sinθ
finally obtaining dE in terms of x and constants. Integrate from x = 0 to x = 7. (Ignore sign of result, it's obvious what the direction of the E field is.)
My answer, for what it's worth, is E = 7kρ(0.0408) = 10.28 V/m in direction i + j. Subject to all sorts of mistakes, of course :smile:
PS this is for the line charge only.
How do you get dx+dy?
It really is much easier my way. Set 2a = length of line = 7√2. Rotate the set-up so that the line runs from (a, -a) to (a, a). Consider an element dy at (a, y), y = a tan(θ), -π/4 < θ < π/4. This has charge ρ dy = ρ a sec2(θ) dθ. The field at O from it has magnitude k ρ a sec2(θ) dθ / (a sec(θ))2 = ρ dθ / a, where k = 1/4πε. The component of that in the x direction is (k ρ dθ / a) cos(θ). Integrating, ##\int_{\theta=-\frac \pi 4}^{\frac \pi 4}\frac{\rho \cos(\theta)}a d\theta = \frac \rho a [\sin(\theta)]_{\theta=-\frac \pi 4}^{\frac \pi 4} = \frac \rho a \sqrt(2) = \rho/7##.
Now, it bothers me that both you and rude man get something like Lkρ where I'm getting kρ/L, but it makes more sense to me that it would be inversely proportional to the scaling of L. See also eqn 2 at http://www.eece.ksu.edu/~bala/notes/emt/finite-line-field.pdf
Edit: the final step should read "= 2ρ/7"
i know the correct e-field is -7.231 i - 7.231 j which is the result i got using the method i mentioned in the previous comment (integrating over L*(√2 / 2)). I am still confused regarding that solution if someone can clarify that for me
I got dx+ dy because in the formula sheet provided by the professor, dL in cartesian coordinates is dx*i + dy*j +dz*k. Q is ρ_L * dL and E= ∫kQ/R_mag^3 * R * dL= k*ρ_L/R_mag^3(∫dx +∫dy).
R is the vector pointing from the observation point to the mid point of the line = -3.5i -3.5j
Can any of you explain why that solution works?
My E = kρy0*∫from 0 to 7 of dx/(2x2 - 2y0x + y2)(3/2)
with y0 = 7 which wolfram alpha had no trouble solving.
Comparing with your answer, when the omitted k is included, it is interesting to observe that my answer is exactly twice yours (your E = 5.14 V/m).
I don't know how you came to conclude that my E scales with L. Looking at the indefinite form of my integral it doesn't seem to. Our respective answers seem to reinforce that viewpoint.
I also just took note of the fact that my magnitude agrees with the OP's stated 'correct answer'.
That's correct if dL is a vector. But the charge on an element length |dL| is ρ|dL| = ρ√(dx2+dy2). Given that in this case dy=-dx, that reduces to ρ√2.dx. OTOH, dx+dy reduces to zero!
You effectively turned |dL| into 2dx, getting √2 times the correct answer.
I guess I read too much into "E = 7kρ...".
There was an error in my working at the final step. It should say 2ρ/7.
So the correct answer is which? And how would it work out using my method? (E(0,0,0) due to the linear charge as a vector?)
could u show me the correct steps (just a modification of what i did)?
If you simply change your dx+dy to dx√2 (which you understand, yes?) I think you'll get the right answer. Whether the rest of your method is right I can't tell since you didn't post the details of what you did.
E= k∫p_L*dL*R/(R_mag^3). so that would mean (√2*k*ρ_L)/(R_mag^3) * ∫R dx ?
1. Is the upper limit of the integral L which is √(7^2 + 7^2) = 7√2 ?
2. Since R = -3.5i -3.5j that would mean: ∫R dx= -3.5∫dx -3.5 ∫(-dx) (Because dy=-dx) →∫R dx=0
that doesn't make any sense. Where's the mistake?
R = -3.5i -3.5j
Isn't R the vector from the element of the line charge to the origin, -xi-yj? It varies as x varies, and so does its magnitude. How do you move the Rmag-3 term out of the integral?
R is the vector pointing to the midpoint of the line charge from the origin. if the midpoint of the line charge is at (3.5, 3.5, 0) then R would be < 0 - 3.5, 0 - 3.5, 0 - 0 > ∴ R= -3.5 i -3.5 j
Regarding Rmag-3 , the magnitude of R is a constant so it can be out of the integral
thats how the code does it
Then I am at a loss for how you arrive at the integral you posted. It makes the whole integrand a constant.
  • · Replies 17 ·
