Is There an Electric Field at the Midpoint Between Two Protons?
The electric field at the midpoint between two protons separated by 1mm is zero due to the cancellation of electric fields in the x-direction, with no contribution from the y-direction. When analyzing a proton and an electron separated by 1 micrometer, there is no point between them where the electric field is zero, as this configuration forms a dipole. The electric field must be treated as a vector, requiring the summation of fields from both charges to determine the total field accurately.
  • Understanding of electric field concepts
  • Familiarity with Coulomb's law and the electric field equation (E = kq/r²)
  • Knowledge of vector addition in physics
  • Basic principles of dipole formation
  • Study vector addition of electric fields in multiple charge systems
  • Explore the concept of electric dipoles and their properties
  • Learn about the implications of charge separation on electric fields
  • Investigate the behavior of electric fields in different configurations of charged particles
Students and educators in physics, particularly those focusing on electromagnetism, as well as anyone interested in understanding electric fields and charge interactions.
milkyway11
What is the electric field halfway in between two protons separated by a distance of 1mm?
When I first did this problem I simply used the electric field equation to solve which is E=kq/r2. However, as I came across another similar problem that states: " a proton and an electron are separated by 1micrometer. is there a point directly between them at which the electric field is zero." I realized that maybe I've been doing this kinda of problem wrong.
My answer now to the first question is there is no electric field since the electric field in x-direction would cancel out and there is no y-direction electric field. And the second problem is that there is no point between the two charges that would have a zero field, because it forms a dipole.
Can someone confirm if my thinking is correct? Also, if my new answers are right, please explain to me why we can't just use the electric field equation even though it still gives u a number?
Thank you!
Thank you!
Yes, your thinking is correct in both cases. Yes, you CAN just use the equation for the electric field to solve these problems.
Do you mean that you get a non-zero number for the case with two protons? If so, you shouldn't. Hint: remember that electric field is a vector, and that you have to add up the electric fields from each proton in order to get the total field.
Thank you for your fast reply. I think I get why I got a non zero in the first place, because I only calculated the electric field of one proton and completely ignored the other one!
Yep, that would do it! Glad to be of help. :smile:
