Where Is the Electric Field Zero Between Two Negative Charges?
The electric field is zero between two negative charges located at x = 6.0 m (q1 = -7.1 µC) and x = -4.0 m (q2 = -4.3 µC). To find the point where the electric field is zero, the equation E = KQ/r² is utilized, where K is the electrostatic constant. The distances r1 and r2 from the charges must be defined correctly to solve the equation. The direction of the electric field contributions from both charges must also be considered, as they point towards the charges due to their negative nature.
  • Understanding of electric fields and Coulomb's law
  • Familiarity with the concept of superposition of electric fields
  • Knowledge of algebraic manipulation and solving equations
  • Basic understanding of charge interactions and their directional properties
  • Study the principles of electric field superposition in electrostatics
  • Learn how to apply the concept of electric field direction for multiple charges
  • Explore the use of algebra in solving physics problems involving electric fields
  • Investigate the implications of charge sign on electric field behavior
Students studying electrostatics, physics educators, and anyone interested in understanding electric field interactions between charged particles.
tuggler
Two points are resting on a string. The first point is resting at x = 6.0 m and has charge q1 =−7.1 µC. The second point is resting at x = −4.0 m and has charge q2 = −4.3 µC.
At what location is the total electric field zero from the two points(other than infinity)?
E =\frac{KQ}{r^2}
\frac{q_1}{r_1^2} = \frac{q_2}{r_2^2}
I divided away the constant K from my second equation because they cancel out when you set them equal to each other.
I don't know what my r_1,r_2 should be here?
Why don't you set the distance from the first charge x and define the distance from the other with x and the distance between the two charges? Thus you introduce only one variable in one equation.
Don't forget that the contribution to the electric field from each charge has direction, so, if the point is between the two charges, the contribution from the charge at x = 6 is pointing in the negative x-direction, and the contribution from the charge at x = -4 is pointing in the positive x-direction.
I am not following can you guys elaborate more please?
  • · Replies 23 ·
