Electric Field Strength Inside a Cylindrical Non-conductor
4 replies · 7K views · last reply
clementc
Hey everyone,
I'm just studying some physics, and came across this question where I don't know why I'm wrong =(
It's from Physics (5th Ed.) by Halliday, Resnick and Krane - Chapter 27, Exercise 22
Positive charge is distributed uniformly throughout a long, nonconducting, cylindrical shell of inner radius [tex]R[/tex] and outer radius [tex]2R[/tex]. At what radial depth beneath the outer surface of the charge distribution is the electric field strength equal to one half the surface value?
Here's a diagram I drew of my interpretation. It's the side on view:
[PLAIN]http://img690.imageshack.us/img690/613/cylinder.png
I did it using the shell theorems (HRK says they work for cylinders) and the equation for an electric field for a point charge.
For this question, all I used was:
[tex]\rho = \frac{q}{V}[/tex]
[tex]E = \frac{1}{4\pi\epsilon_0} \frac{q}{r^2}[/tex]
And also a bit of shell theory
Let the charge in the entire cylindrical shell be [tex]q[/tex].
[tex]\rho=\frac{q}{V}=\frac{q}{lA}[/tex] where [tex]\rho[/tex] is the volume charge density.
At the outermost surface, using the shell theorems, I treated all the charge as being at the centre of the cylinder.
[tex]\therefore E=\frac{1}{4\pi\epsilon_0} \frac{q}{(2R)^2}[/tex]
[tex]=\frac{1}{4\pi\epsilon_0} \frac{\rho l\pi(4R^2-R^2)}{4R^2}[/tex]
[tex]=\frac{3\rho l}{16\epsilon_0}[/tex]
To get where the E field is half of this, I solve for half this strength at a distance [tex]x[/tex] from the centre:
[tex]E=\frac{3\rho l}{32\epsilon_0}[/tex]
[tex]=\frac{1}{4\pi\epsilon_0} \frac{\rho l\pi(x^2-R^2)}{x^2}[/tex]
[tex]\therefore \frac{3}{32}=\frac{x^2-R^2}{4x^2}[/tex]
[tex]12x^2=32(x^2-R^2)[/tex]
[tex]3x^2 = 8x^2 - 8R^2[/tex]
[tex]5x^2 = 8R^2[/tex]
[tex]\therefore x = R\sqrt{\frac{8}{5}}[/tex]
[tex]Depth = R(2-\sqrt{\frac{8}{5}}) = 0.735R[/tex]
But the answer was [tex]0.557R[/tex] beneath the surface, and they used Gauss' law. However, I still don't see where I went wrong. I think the shell theorems still hold instead a cylindrical shell, but I'm not sure.
Could anyone please help me? =(
Thank you very much guys
What do you mean by 'shell theorems'? Note that this problem has cylindrical symmetry, not spherical symmetry.
[tex]\rho = \frac{q}{V} \\<br /> E = \frac{1}{4\pi\epsilon_0} \frac{q}{r^2}[/tex]
:confused:
Oh shell theorem
=D
what i meant was the one which like tells you that if you have a uniformly charged spherical/round surface
1. from outside, the electric field is the same as if all the charge were concentrated at a point in the centre
2. the electric field inside the shell is 0
so when I am like at point x, i can ignore all the charge outside and the electric field experienced is that which arises only from the charge inside that circle of radius x
OK, but for a cylinder that means you can treat the charge as if it were concentrated along a line at the center, not a point.
OH LOL OF COURSE! *bangs head on table*
im such a dummy =P
thank you so much doc Al thank you thank you thank you =D
in that case gauss' law is much nicer heh
