Electric or mechanical scale to weigh yourself?
The discussion centers on the comparison between electric and mechanical scales for personal weight measurement. Participants agree that while both types can provide similar readings, precision is more critical than absolute accuracy for weight management. Mechanical scales offer visible pound markings, while digital scales provide half-pound increments. However, electronic scales using strain-gauge technology are highlighted as more accurate and less prone to drift compared to mechanical options, making them a preferable choice for consistent weight tracking.
  • Understanding of weight measurement concepts
  • Familiarity with mechanical and electronic scale technologies
  • Knowledge of precision vs. accuracy in measurements
  • Basic principles of strain-gauge technology
  • Research the differences between mechanical and electronic scales
  • Explore the principles of strain-gauge technology in weight measurement
  • Learn about the calibration and maintenance of mechanical balances
  • Investigate alternative methods for tracking body composition beyond weight scales
Individuals interested in weight management, fitness enthusiasts, and health professionals seeking accurate measurement tools for body composition analysis.
Electric or manual scale?
  • Electric
    Votes: 2 25.0%
  • Manual
    Votes: 6 75.0%
  • Total voters
tgt
Which one would you pick for your scale and why? Have a vote (mechanical=manual in poll) .
The question boils down to which is more accurate?
Computer science news on Phys.org
If you're trying to lose (or gain?) weight, accuracy isn't as important as precision.
True.
I've owned both, and they both gave similar readings. Mechanical scales usually have markings for every pound, and you can see if you're somewhere between pounds. Digital scales give readings in half pound increments. Since weight loss and gain is only meaningful when it's more than a pound or so (anything less can be daily fluctuations in water retention or other things that have nothing to do with muscle or body fat that people are interesting in gaining or losing), either one is adequate.
Neither one. Body composition is independent of weight. Also, clothing sizes are not listed in lbs. Ditch the scale and get a measuring tape. It is cheaper and gives better information than a scale.
I have a mechanical one that really sucks. If you stand closer to the middle, your weight is lower. It's impossible to get precise readings out of the thing.
Spring scales may or may not be accurate and their performance will change over time due to wear.
Balances (platform scales with sliding weights on beams) are quite accurate and do not drift as much, but they are expensive.
Electronic scales using strain-gauge technology are not much more expensive than spring scales and are far more accurate. They also cost a lot less than balance scales and take up considerably less room, with about the same accuracy as balance scales.
Mechanical balances.
Don't understand.
why?
tgt said:
Don't understand.
What she's saying is that it's more important that you can tell how much weight you've lost than how much you weigh, e.g. you weigh 190 but the scale says 140. Okay, so that's bad. But if it can accurately display a 20lb drop, i.e. you go to 170 and the scale says 120, then you're still good to go.
yeah okay. But what happens if I'm trying to measure myself against standard weights? Then accuracy is important.
I prefer the electric scale: its batteries are always empty :redface:
Manual. I don't understand the mechanics behind the electric scale, and until I do, I can't trust it.
That's a strange way of thinking. Do you also use a mechanical computer ?
WarPhalange said:
:smile:
Wow. That's a dead on identical (except for looking newer and shinier) abacus to one I have at home.
tgt, mechanical balances need little in terms of recalibration. Cheap op-amp circuits have thermal drifts in gain that can be as large as 1 part in a few hundred per K. And the electronics will age, in addition, creating long term drift. Strain gauges will also experience fatigue (though only on the order of 10^5 or more cycles).
  • · Replies 26 ·
  • · Replies 20 ·
  • · Replies 22 ·
  • · Replies 59 ·
