Electric potential due to two point charges
The discussion focuses on calculating the electric potential at point P due to two point charges of equal magnitude but opposite signs, positioned a distance d apart. The key equation used is the electric potential formula, V = Kq/r, where K is the Coulomb's constant. The participants clarify that while the potential can be zero at point P, it does not imply that the electric field is also zero. The relationship between electric potential and electric field is established through the equation E = -∇V, emphasizing that the electric field can exist even when the potential is zero at a specific point.
  • Understanding of electric potential and electric field concepts
  • Familiarity with the equation V = Kq/r for point charges
  • Knowledge of vector calculus, specifically gradients and derivatives
  • Basic principles of superposition in electric fields
  • Study the derivation and application of the electric potential formula V = Kq/r
  • Learn about the gradient operator and its role in calculating electric fields from potentials
  • Explore the concept of superposition in electric fields and how to calculate net fields from multiple charges
  • Review examples of electric potential and field calculations in three-dimensional space
Students and professionals in physics, particularly those studying electromagnetism, electrical engineers, and anyone involved in solving problems related to electric fields and potentials.
aftershock
Two point charges (opposite signs, equal in magnitude) are a distance d apart. Point P is a distance z above both charges and horizontally equidistant. Find the electric potential at point P.
Kq/r
It's my understanding that direction does not matter with potential so r is the same value for both. We can add the potentials together to get total potential. Plugging in q for the first charge and -q for the second gives 0.
I know that's not right, that would imply the electric field is zero which is obviously incorrect.
What am I doing wrong?
What's your reason for saying that zero potential implies zero electric field?
E = -∇V
gradient of zero is zero
Not necessarily. For example, sin(x) = 0 at x = 0. But the derivative of sin(x) is not zero at x = 0. Likewise, if the potential happens to be zero at some point, it doesn't mean that E has to be zero at that point.
But, if V = 0 (or any other constant) throughout some region of space, then E would be zero in that region.
Yeah, what I mean was that it would imply zero electric field only at point P. Is that incorrect?
EDIT: Never mind I just read the "if the potential happens to be zero at some point, it doesn't mean that E has to be zero at that point."So does that mean that zero potential is correct?
No. Suppose V as a function of position (x, y, z) happens to be V = -x - y2 + 2z. Then note that V = 0 at (x,y,z) = (1, 1, 1). What would E be at that point?
Yes.
TSny said:
Yes.
I really appreciate your help but I'm a little confused.
The problem states "Compute E = -∇V , and compare your answer with Prob. 2.2a"
2.2a is the same problem but instead asks to calculate the electric field.I understand now (thanks to you) why I can't simply differentiate the value of potential at some specific point, but then how do I go about this problem?
Good question. You can see that V = 0 as long as you stay on the z axis. So, if you are at point P and move up or down along the z axis, V remains constant. So you should be able to deduce what the derivative of V is with respect to z at point P. That will give you one of the components of the electric field.
To get the other components you need the derivative of V with respect to x and y at point P. This would require knowing how V varies as a function of x and y as you move parallel to the x and y axes from point P. Your calculation of V at point P does not give you that information. So, the question seems to me to be a bad question unless the question is just to get you to see that the one component of E that you can calculate is consistent with what you found for that component in the other problem.
You should already know the electric field of a point charge. Just like you can add potentials, you can add fields. The total field is the sum of all the fields of the point charges. Remember, the electric field is a vector, with components in the x, y, and z directions. TSny has already explained that the z component of the electric field will be 0, but you don't necessarily need that when using the superposition method.
  • · Replies 22 ·
