Electric Potential for an infinity line of charge
The electric potential \( V \) for a long line of charge with linear charge density \( \lambda \) is expressed as \( V = \frac{\lambda}{2\pi\epsilon} \ln\left(\frac{r_b}{r_a}\right) \), where \( r_b \) is the reference point set to zero potential. The challenge arises because setting the potential at the line of charge to zero leads to undefined values, such as \( \ln(0) \) or \( \ln(\infty) \). It is essential to recognize that electric potential is relative and can be adjusted by adding an arbitrary constant, similar to gravitational potential in a uniform field. Therefore, different choices for \( r_b \) yield potentials that differ only by a constant, maintaining the same electric field.
  • Understanding of electric potential and electric fields
  • Familiarity with calculus, specifically integration
  • Knowledge of logarithmic functions and their properties
  • Concept of linear charge density and its implications in electrostatics
  • Study the concept of electric potential in electrostatics
  • Learn about the relationship between electric field and potential using \( \Delta V = -\int E \cdot ds \)
  • Explore the implications of choosing reference points for electric potential
  • Investigate the behavior of potentials in different charge distributions, such as point charges and surface charges
Students and educators in physics, particularly those focusing on electromagnetism, as well as anyone preparing for exams involving electrostatics and electric potential calculations.
henry3369
Find the potential at a distance from a very long line of charge with linear charge density (charge per unit length) λ.
I actually have this solved with the help of my book, but I need an explanation of the results.
V = (λ/2πε)ln(rb/ra)
Where the electric potential at rb is zero.
ΔV = -∫E⋅ds
From this equation, it is clear that if you can't set the electric potential at the line of charge to be zero, otherwise you would have ln(0). Additionally, if it is zero at rb you get ln(infinity) = infinity. So does that mean it is not possible to find the electric potential with respect to the line of charge or infinity? I'm not sure how I would solve a problem like this on an exam if electric potential is relative, and rb is some arbitrary finite point. Wouldn't different points for rb yield different results for the electric potential?
Yes, picking different rb gives you different potentials. However, note that the potential is only physical up to the addition of an arbitrary constant (compare with the gravitational potential in a homogeneous gravitational field, you can chose where you put the zero level). As you can/should verify, different rb give potentials that only differ by a constant and therefore give rise to the same field.
Usually in 3D, we chose the reference point of zero potential to be at infinity but, as you have noticed, this is not possible for the line charge so you must instead pick a different zero level in order to have a finite potential for finite values of r.
  • · Replies 22 ·
  • · Replies 18 ·
