Electric Potential of a triangle?
The discussion focuses on calculating the electric potential at point P due to three charges in a triangular arrangement. The initial calculations provided by the user were incorrect due to a misidentified distance for one of the charges. After receiving guidance, the user corrected the distance and recalculated the potential, arriving at the correct answer. The importance of carefully reviewing each step in the calculation process, particularly the charge values and distances, was emphasized. Ultimately, the user successfully resolved the issue with their calculations.
dolpho
Find the electric potential at point P in the figure.
http://i.imgur.com/8FNSoML.png
V = kq / r
So what I did was calculated the electric potential each force gives on the point P.
Vp1 = (8.99e^9) (2.75e^-6) / .625
Vp2 = (8.99e^9)(-1.72e^6) / .625
Vp3 = (8.99e^9) (7.45e^6) / 1.25
Vp1 + Vp2 + Vp3 = 39556 - 24740 + 53580 = 68396 V
Would appreciate any help :D
What seems to be the problem (you have to actually say)?
Well my answer is incorrect lol, here's the full question.
Suppose the three charges shown in the figure are held in place. A fourth charge, with a charge of +6.50 and a mass of 4.20 , is released from rest at point P. What is the speed of the fourth charge when it has moved infinitely far away from the other three charges?
I need to do the first part I think before I start the second but I didn't get the first one correct. Any tips on how to find the electric potential at the point P?
The distance between charge 3 (the top of the triangle) and point P is not 1.25 m.
I've moved this post to the appropriate subforum of "Homework and Coursework Questions." In the future, please use those forums for help with specific exercises like this one. The other forums are for more general discussion.
Woops sorry about that! Thanks I made the mistake of putting 1.25 there, I got the right answer thanks!
The way to troubleshoot these things is to go back over each step and examine your reasoning ... in each step there are only two places for a mistake - the charge and the distance. Mind you - just writing numbers down like that creates a kind of blindness.
Good to see it's sorted out though - well done.
Thread 'Correct statement about size of wire to produce larger extension'
The answer is (B) but I don't really understand why. Based on formula of Young Modulus: $$x=\frac{FL}{AE}$$ The second wire made of the same material so it means they have same Young Modulus. Larger extension means larger value of ##x## so to get larger value of ##x## we can increase ##F## and ##L## and decrease ##A## I am not sure whether there is change in ##F## for first and second wire so I will just assume ##F## does not change. It leaves (B) and (C) as possible options so why is (C)...
  • · Replies 22 ·
