How Is Electric Potential Difference Calculated from Work and Charge Movement?
The problem involves calculating the electric potential difference between two points when a charge is moved, considering the work done by an external force and the kinetic energy of the charge at the final point. The subject area is electric potential and energy in the context of electrostatics.
  • Participants discuss the relationship between work done, kinetic energy, and potential energy. Questions arise regarding the reference point for potential energy and the implications of the work done on the charge's motion.
Some participants have offered insights into the relationship between potential energy and the work done, while others are exploring different reference points for potential energy. There is an acknowledgment of the complexity of the problem, with suggestions to express energy changes in future attempts.
Participants note the discrepancy between the calculated potential difference and expected values, as well as the influence of opposing forces on the charge's motion. The original poster expresses confusion regarding the signs of the potential difference and the implications of the work done.
PeachBanana
The work done by an external force to move a -8.50 mu C charge from point a to point b is 1.90×10^-3 J.
If the charge was started from rest and had 4.86×10^-4 J of kinetic energy when it reached point b, what must be the potential difference between a and b?
V = PE / q
Vba = - W/q
If the charge started from rest, all the energy it had was potential energy which got converted to kinetic energy at point b.
V = 4.86 x 10^-4 / -8.50 x 10^-6 C
V at point a = -57.176
Vb - (-51.176 V) = -1.90 X 10^-3 J / -8.5 X 10^-6 C
Vb + 51.716 V = 223.5 V
Vb = 165.76 (166 V)
I use MasteringPhysics and it told me the answer should have been negative but I don't understand why. My book states "When the electric force does positive work on a charge, the kinetic energy increases and the potential energy decreases. The difference in potential energy, PEb - PEb, is equal to the negative of the work, Wba, done by electric field to move the charge from a to b."
Don't see how you can know the potential energy at a particular point - what are you using for your zero of PE?
From the looks of the numbers - the applied force did much more work than the resultant kinetic energy ... so the charge must have been encountering an opposing force, which means the motion was against an opposing potential. Thus Vb < Va (since negative charges roll uphill).
Simon Bridge - Thank you, that makes sense. Initially, I wasn't entirely sure how to approach the problem. I thought I the zero point was at "B" when all the energy was kinetic.
However, you also found a distinct value for Vb.
It looks like you found Vb from Vb - Va = 223.5V (and plug in your value for Va). But Vb-Va is the voltage difference you have been asked to find.
Have you tried expressing everything in terms of change in energy?
No, but the next time I come across a problem like this I will express things in terms of ΔU.
OK - have fun ;)
  • · Replies 22 ·
