Electrical Breakdown: Insulator Behavior After High Voltage
  • Context: High School
  • Thread starter Thread starter Shakattack12
    Electrical
Electrical breakdown in insulators occurs when the applied voltage exceeds the dielectric strength, temporarily transforming the insulator into a conductor. Post-breakdown, materials typically experience deformation due to the formation of a breakdown channel, which results from local decomposition and high local stress fields. Hard breakdown events generate significant heat, leading to plastic deformation in the surrounding material. The extent of damage varies based on the medium; while solid materials often suffer permanent damage, certain gases can recover after sparking.
  • Understanding of dielectric strength in materials
  • Knowledge of electrical breakdown mechanisms
  • Familiarity with thermal effects on materials
  • Basic principles of ionization and plasma behavior
  • Research the effects of high voltage on dielectric materials
  • Study the mechanisms of electrical breakdown in insulators
  • Explore the thermal properties of materials during electrical stress
  • Investigate recovery processes in gaseous mediums post-sparking
Electrical engineers, materials scientists, and professionals involved in high voltage applications will benefit from this discussion, particularly those focused on insulator performance and breakdown behavior.
Shakattack12
Hey guys,
I as wondering what happens to an insulator during and after electrical breakdown. I understand that at a high enough voltage it exceeds the dielectric strength and becomes a temporary conductor. However, what happens afterwards. Is the material deformed or does it still maintain structural integrity?
Typically, a breakdown channel is formed somewhere in the material owing to local decomposition of the material. As hard breakdown events are generally accompanied by strong local heating effects, the material surrounding the channel can suffer from plastic deformation owing to the sudden generation of high local stress field. For various breakdown mechanism see, e.g.,: https://www.tf.uni-kiel.de/matwis/amat/elmat_en/kap_3/backbone/r3_5_2.html
I think it depends on the medium within which breakdown occurs. Sparking can occur during breakdown and this can permanently damage, I guess most if not all, solid materials. But certain gases can recover, in other words the excited and ionised atoms in the high energy environment of a spark can return to lower energy states after sparking. Not to forget that high temperatures can cause or speed up changes due to chemical and biological reactions.
  • · Replies 42 ·
