Electrical Engineering BS to Aerospace Engineering MS
Transitioning from a Bachelor of Science in Electrical Engineering to a Master of Science in Aerospace Engineering is feasible, particularly for those interested in avionics and electronic systems. While some areas such as fluids and propulsion may present challenges due to a lack of foundational knowledge, concentrations like controls align well with an electrical engineering background. Prospective students should carefully consider their desired focus within aerospace engineering, as various specializations exist, including avionics, structures, and controls.
  • Understanding of avionics systems and their applications in aerospace engineering
  • Familiarity with aerospace engineering specializations such as fluids, controls, and propulsion
  • Knowledge of foundational electrical engineering principles
  • Awareness of the academic requirements for a Master's program in Aerospace Engineering
  • Research the specific prerequisites for a Master's program in Aerospace Engineering
  • Explore the field of avionics and its relevance to satellite technology
  • Investigate the various concentrations available within Aerospace Engineering
  • Learn about the integration of electrical engineering principles in aerospace applications
Aerospace engineering students, electrical engineers considering a career shift, and professionals interested in avionics and satellite technology will benefit from this discussion.
DominoK
Hello. Is this possible, or would I be missing out on a lot of groundwork? Any options?
I'd like to work on anything involving space, like satellites and such.
Thank you!?
Not to discourage you but if am being honest, it will be difficult. If you're smart enough (which I believe you are ;)), then it should be fine. The easiest part for you will definitely be the electronic side of aerospace, which is avionics if you join aeronautical engineering. All the best :).
I looked into doing that when I picked a masters program. It really depends on what you want to concentrate on. Even in aerospace engineering for a masters you can get a wide range of concentrations (fluids, controls, avionics, propulsion, structures, etc)
as an electrical engineer, some of those you will have zero background in, others, like controls, you have all the prerecs required (at least in my case I did)
