Magnetic flux through a solenoid with 300 turns
3 replies · 6K views
matt85
A solenoid 2.9 cm in diameter and 15 cm in length has 300 turns and carries a current of 5 A. Calculate the magnetic flux through the circular cross-sectional area of the solenoid.
-->> I tried using the equation B = u(0)NI/L to calculate magnetic field, and then putting this in the formula flux = BNA, where N is number of turns, and A is area (pi*r squared). This didn't work, though.
I'd appreciate some help! Thanks!
The field is indeed given by
[tex]B=\frac{\mu_{0}NI}{L}[/tex]
and the total flux through the solenoid
[tex]\phi=NAB[/tex] is also right.
Maybe what they asked for is the flux through a single turn which would be your answer divided by N
Also keep in mind that
is valid only for a long solenoid. (When its length is large compared to its radius)
I feel your solenoid is long enough. I don;t see why you're not arriving at the answer.
yep, it was wanting it through one turn. thanks.
matt85 said:
... Calculate the magnetic flux through the circular cross-sectional area of the solenoid...
I think NBA is the total flux linked with the solenoid, not the flux through the cross-section. It is BA only.
MP
