Electricity: Calculating Current and Potential Difference in a Circuit
  • Thread starter Thread starter dumb__x
    Electricity
7 replies · 2K views
dumb__x
[SOLVED] Electricity (probably easy
In a circuit shown, the p.d. across the 4Ω resistor is 8 V.
a)What is the current through the 4Ω resistor?
b)What is the current through the 3Ω resistor?
c)What is the p.d. across the 3Ω resistor?
d)What is the p.d. applied by the battery?
Ohms Law V=IR
a)2A?
Please show how you arrived at the solution. Since the attachment is pending approval from moderators, I can't see your circuit. A quicker way would be to upload the attachment to an online image hosting site like http://photobucket.com" and use the corresponding link in IMG tags while posting. Can you do that?
Can you see it?
<a href="http://s262.photobucket.com/albums/ii120/reika_xx/?action=view&current=Electricity.jpg" target="_blank"><img src="http://i262.photobucket.com/albums/ii120/reika_xx/Electricity.jpg" border="0" alt="Electricity Circuit"></a>a)V=IR
8=I*4
I=2A
sorry
i. For the 4[itex]\Omega[/itex] resistor,
[tex] V = 8~NmC^{-1}[/tex]
[tex] R = 4~NmC^{-2}s^{-1}[/tex]
Hence,
[tex] I = \frac{V}{R} = \frac{8}{4} \frac{NmC^{-1}}{NmC^{-2}s^{-1}}[/tex]
[tex] I = 2~Cs^{-1} = 2~A[/tex]
ii. Current through the 3[itex]\Omega[/itex] resistor is the same as through the 4[itex]\Omega[/itex] resistor as both of them are in series.
iii. For the 3[itex]\Omega[/itex] resistor:
[tex] I = 2~Cs^{-1}[/tex]
[tex] R = 3~NmC^{-2}s^{-1}[/tex]
Hence,
[tex] V~=~IR = 2 \times 3~Cs^{-1}.NmC^{-2}s^{-1}[/tex]
[tex] V = 6~NmC^{-1} = 6~V[/tex]
iv. Do you mean the potential difference across the terminals of the battery? If that is the case, you can solve it using Kirchhoff's law. Refer to the figure in the attachment.
Hence,
[tex] \epsilon + 2(4)~NmC^{-1} + 2(3)~NmC^{-1} = 0[/tex]
[tex] |\epsilon| = 14~NmC^{-1} = 14~V[/tex]
So, the battery provides and e.m.f of 14V. [In case you can't see the attachment, go here: http://image.bayimg.com/iajbbaaba.jpg ]
I=U/R=8V/4om=2A
I=8V/3om=8/3 A
This questions I don't understand
"c)What is the p.d. across the 3Ω resistor?
d)What is the p.d. applied by the battery?"
"sorry
http://s262.photobucket.com/albums/i...lectricity.jpg"
I=8V/(4om+3om)=8/7 A.
If electricity is ~, then (8/7)A/2=8/14 A, becouse of diod.
@fermio: I am not able what you are trying to say due to poor formatting. Please repost with proper formatting and punctuation.
