Electricity Without the analogies (need expert varification)
  • Context: Graduate
  • Thread starter Thread starter tim9000
    Electricity
3 replies · 2K views
tim9000
The topic of how electricity actually flows is one of the worst answered most common questions I've seen. Best answer I've seen was here by Gokul43201:
https://www.physicsforums.com/showthread.php?t=377359&page=3
I also HATE the "shock-wave" analogy
YET I'm still confused, as I know an electric field cannot propagate inside a conductor, I have read that a conductor is like a medium with infinite permittivity. -> I've seen pictures where the conductor's free charges move to set up an apposing electric field (I think) on the surface.
Crux:
So I always thought that a conducting wire was a TM mode TL, but I haven't seen any literature supporting my assumption (from Right hand screw rule), hence I believe it to be wrong.
Am I to conclude that infact the Electric Flux does indeed flow through at least the skin-depth (if AC) of a conductor at near the speed of 'c', because the charges are able to circulate in a loop? (and thus not oppose the E-field)
It seems weird to me that the conductor would go from having what seemed to be infinite permittivity (like an isolated sphere in an E-field), to almost no permittivity, so the E-field sticks inside the conductor and don't leak out, as it often is not a straight line (wires etc).
(or an adoquate distance for high frequencies, in an antenna)
THANKS
For anyone curious, I think I may have found half the answer to my question here:
https://www.physicsforums.com/showthread.php?t=154617&page=2
In that-
"Now, what is an EXTREME change in charge flux, is when it tries to cross the surface of the conductor: it simply can't. So all charge that wants to flow "outside" of the conductor is accumulated on its surface! And this in such a way, that the E-field is modified UNTIL it is entirely parallel to the conductor surface (because only then, no charge wants to "flow outside" and hence gets accumulated more at the surface)."Although I still wouldn't mind hearing a "no" about the wire not being a TM mode TL, from someone who knew.
This is true in electrostatics, but a current-carrying wire is not an electrostatic situation.
Thanks for clearing that up. Is a current carrying wire of a type of mode TL?
