Electrochemistry homework help problem
13 replies · 3K views
zorro
Tl+/Tl couple can be prepared by saturating 0.100 M KBr with TlBr and alowing Tl+ ions from the insoluble bromide to equilibrate. This couple was observed to have a potential of -0.443V w.r.t Pb2+/Pb couple in which Pb2+ was 1 M. Ksp of TlBr is ?
Given: EoPb2+/Pb = -0.126V and EoTl+/Tl= -0.336V
I have a problem understanding the question. Can somebody explain me?
You have a cell made of two half cells - one is Pb/Pb2+, the other Tl/Tl+. You are given everything but [Tl+], and that's the only thing you need to calculate to find Ksp of TlBr.
The potential -0.443V given in the question confuses me. It simply means that the cell reaction is not spontaneous. Which one is cathode and which one is anode?
We have Ecell = -0.443V and Eocell = -0.21 (if we assume Tl+/Tl is the cathode)
Is this right?
To be honest - I am not sure which way it goes off the top of my head, but if you take the sign wrong, you will get absurd results.
You will need E0 for Pb/Pb2+ as well.
Cathode- Tl+ + e ----> Tl
Anode- Pb------> Pb2+ + 2e
Ecell = Eocell - 0.059/2*log[Pb2+/[Tl+]2]
We have Pb2+=1M
What is the use of 0.1M KBr?
E0 for Pb/Pb2+ is given in the question.
Have you read the question?
I read it but did not understand fully.
Br- concentration is 0.1M
Let us assume that Tl+ produced from TlBr is x moles
Ksp = x(0.1+x)
How to find 'x'?
Right.
Ksp = x(0.1+x)
How to find 'x'?
From the cell potential. It will be so low you can easily ignore x in 0.1+x part.
Plugging the values in the equation in my post #5, I got x as 1.124 x 10-4
So Ksp = 1.124 x 10-5. This is not the correct answer.
epenguin said:
Thallium chemistry.
Prof. is showing off?
:biggrin:
@Borek- where is the mistake?
Your Ksp looks OK to me, unless you are expected to take ionic strength of the solution into account.
I just have the answer for it.
3.6 x 10-6
There is a big difference.
I think the answer given is incorrect.
No my fault. I know answer calculated is different from the Ksp value from tables, but as far as I can tell data given yields 1.12e-5.
