Electrolytic Capacitor and Potentiometer question
The discussion addresses two primary concerns regarding electrolytic capacitors and potentiometers. It confirms that the outside of an electrolytic capacitor is typically coated in non-conductive enamel, thus not conductive. Additionally, the user experienced a 5kOhm potentiometer that smoked during testing but returned to normal resistance after an hour. This phenomenon is noted as not uncommon, and the importance of using a multimeter for testing components is emphasized, along with the recommendation to maintain clean breadboards to avoid circuit issues.
  • Understanding of electrolytic capacitors and their properties
  • Knowledge of potentiometer functionality and testing
  • Familiarity with using a multimeter for resistance measurement
  • Basic circuit assembly skills, including soldering
  • Research the properties and applications of electrolytic capacitors
  • Learn about troubleshooting techniques for potentiometers
  • Study best practices for maintaining breadboards and circuit cleanliness
  • Explore advanced multimeter functions for circuit diagnostics
Electronics enthusiasts, hobbyists building circuits, and anyone troubleshooting issues with capacitors and potentiometers will benefit from this discussion.
jbord39
Hey guys,
I have two quick questions:
Is the outside of an electrolytic capacitor conductive? (Should I worry about it touching some other circuit components)?
I have a 5kOhm potentiometer that for some reason began to smoke once while testing a circuit. I powered off the circuit and tested the potentiometer (the resistance decreased from 0-1.3kOhm). After about an hour I retested the potentiometer and it was at 0-5kOhm again! I replaced it in the SAME circuit, powered it up, and left it on for about 10 minutes. No smoke and it has worked since. Is this common?
It should be easy enough to test with a multimeter. You mentioned measuring resistance so I assume that you have one. Just measure the resistance between two points on the outside of the cap. I'm going to guess that they're coated in non-conductive enamel.
I'll tell you what's common. Bugs. Lot's and lot's of bugs. Especially when you're just starting to build circuits/write software. Over time you'll develop a knack for doing it in an organized way that isn't so error prone.
Are you using a breadboard? Pro tip: breadboards get filled up broken bits of wire and metal dust. They can become unreliable in certain spots. I can't tell you how many times I fixed a circuit by simply taking it all apart and putting in a new spot. Don't put things too close together if you can help it. The leads of the components can touch and cause problems.
Thanks.
I do have a breadboard but I was not using it when this happened (the pieces were soldered).
  • · Replies 17 ·
  • · Replies 26 ·
9K
