Electrolytic capacitor voltage headroom
  • Thread starter Thread starter Salvador
    Capacitor Voltage
The discussion centers on the selection of electrolytic capacitors for a switch-mode power supply (SMPS) application, specifically regarding voltage ratings and capacitance values. Users recommend using capacitors rated at least 160V for a 92V DC application to ensure longevity and reliability. It is emphasized that operating capacitors above 70% of their rated voltage can significantly reduce their lifespan. Additionally, low ESR (Equivalent Series Resistance) capacitors are suggested to minimize output ripple, with a focus on ripple current ratings and thermal performance.
  • Understanding of electrolytic capacitor specifications, including voltage ratings and ESR.
  • Familiarity with switch-mode power supply (SMPS) design principles.
  • Knowledge of ripple current and its impact on capacitor performance.
  • Awareness of temperature ratings and their effect on capacitor lifespan.
  • Research "CDE capacitor datasheets" for ripple current ratings and specifications.
  • Learn about "low ESR capacitors" and their advantages in power supply applications.
  • Investigate "electrolytic capacitor thermal ratings" and their importance in circuit design.
  • Explore "capacitor selection criteria" for high-performance SMPS applications.
Electronics engineers, power supply designers, and hobbyists involved in the design and repair of switch-mode power supplies and related electronic circuits.
Salvador
Hi , I'm in need for some 10+ caps for my smps secondary side smoothing.
the thing is electrolytics are not cheap , so I need about 1000uF a piece but there is a big difference between whether it's 200v rated or 100v rated.
the voltage across the each cap would be about 92v DC , I wonder would a 100v rated cap be just fine in this application or do a higher voltage rating would ensure longer life , I mean how close to its rated voltage limit can a electrolytic capacitor work for long periods of time ?
thanks.
thanks.
I'm with Jim on this one -- you need more than "about* 8% headroom. Big caps can fail rather loudly!
Why do you need so much capacitance? If you use low ESR caps instead of standard ones, that may help to reduce your output ripple without needing so much capacitance... :smile:
yes lower esr caps and also I'm just redesigning my smps because previously it had too much ripple still going through and also some leakage parasitics going thorugh my wires.
well it was basically an experiment whether it works now that it works it's time to put it together with more attention to detail.
Ok I will go through the materials Jim provided.So if 90 volts is my operating voltage then I assume the next standard I can choose is 160v then 200.
Electrolytic caps are temperature sensitive. If you run them a bit hot their life expectancy can reduce dramatically. Some have a life of just a few thousand hours if run a bit hot but still within their specified max temperature. Some well known manufacturers of set top boxes have had whole batches fail just out of warranty because their engineers got it wrong.
The electrolyte itself is something of a "trade secret" - just try to find details on it.
I suspect there was a learning curve, and the new guys stumbled.
On the bright side - my kid pulled a huge flatscreen TV out of the trash, replaced the caps with bulged tops and that fixed it. No kidding it was so big i teased him about his "Drive-in " .
Cost of parts - about six bucks .
the grin on his face - priceless .
yeah that wonderful feeling when you get something expensive for free and on top of that repair it yourself and even on top of that it costs you all in all a few bucks.
I once got an old Japanese Luxman amplifier from electronics scrapyard , and all it had was blown fuses , replaced them and it runs for many years now.
I still have no clue why the fuses were blown with everything else in perfect order but well whatever.
I have actually got quite a few things from scrap and with a bit of repair and knowledge they still work so it's a kind of 21st century hobby.
On the topic I wanted to ask , how much miliOhms is considered a low ESR cap ? The frequency with which my transformers run is about 50khz.
I just wonder what to better look for when searching the caps.
Now that'd depend on its capacitance, wouldn't it ? Because the ripple current flowing through ESR is what heats the capacitor .
Look at the CDE datasheets and study ripple current ratings
pick a cap rated 2X or more the ripple current you intend it to handle .
If you don't find ripple current rated per se, look for power dissipation rating probably tabulated by case size. Iripple2 X ESR gives power your cap will have to handle. Leave yourself at least 100% headroom.
It's really hard to choose the right caps especially when cost in an issue.
Maybe you guys can give me some advice basically I'm choosing between some panasonics , cornell dubilier , nichicon and nippon chemicon
some have higher ripple current but lower thermal ratings like 85 some higher thermal lower ripple etc.
I know this is a lazy questions but if you want you can check out the links and see maybe some memories or specifics rush to mind.
http://lv.rsdelivers.com/product/co...-slpx-series-3000h-25-dia-x-45mm/7441199.aspx
http://lv.rsdelivers.com/product/panasonic/eethc2c102jj/panasonic-1000%CE%BCf-160-v-aluminium-electrolytic-capacitor-ts-type-hc-series-2000h-25-dia-x-35mm/7900285.aspx?query=EETHC2C102JJ
http://lv.rsdelivers.com/product/nichicon/lls2d102melb/nichicon-1000%CE%BCf-200-v-aluminium-electrolytic-capacitor-ls-series-3000h-30-dia-x-35mm/8467151.aspx?query=LLS2D102MELB
http://lv.rsdelivers.com/product/nichicon/lgu2d102mela/nichicon-1000%CE%BCf-200-v-aluminium-electrolytic-capacitor-gu-series-3000h-25-dia-x-50mm/8442803.aspx?query=LGU2D102MELA
http://lv.rsdelivers.com/product/nippon-chemi-con/ekmq161vsn102mp40s/nippon-chemi-con-1000%CE%BCf-160-v-aluminium-electrolytic-capacitor-p40-kmq-series-2000h-22-dia-x-40mm/8414848.aspx?query=EKMQ161VSN102MP40S
http://lv.rsdelivers.com/product/panasonic/ecec2dp102dj/panasonic-1000%CE%BCf-200-v-aluminium-electrolytic-capacitor-up-type-ts-series-2000h-30-dia-x-40mm/7900474.aspx?query=ECEC2DP102DJ
http://lv.rsdelivers.com/product/panasonic/eetee2d102jj/panasonic-1000%CE%BCf-200-v-dc-aluminium-electrolytic-capacitor-ed-snap-in-series-3000h-25-dia-x-50mm/7435387.aspx?query=EETEE2D102JJ
http://lv.rsdelivers.com/product/nippon-chemi-con/ekmq201vsn102mq45s/nippon-chemi-con-1000%CE%BCf-200-v-aluminium-electrolytic-capacitor-q45-kmq-series-2000h-254-dia-x-45mm/8414889.aspx?query=EKMQ201VSN102MQ45S
  • · Replies 32 ·
  • · Replies 17 ·
