Electron oscillation frequency, what pushes them away?
The discussion revolves around the oscillation frequency of electrons, particularly in the context of atomic structure and electromagnetic interactions. Participants explore the forces involved in electron behavior, including Coulomb attraction and potential explanations for what might push electrons away from the nucleus.
  • Some participants propose that the oscillation of electrons can be described using harmonic oscillation concepts, questioning what force constant represents this behavior.
  • Others introduce the idea of "centrifugal force" and effective potential in relation to electron oscillation within an atom.
  • A participant mentions the theory of Rayleigh scattering, explaining how electrons are displaced by incoming light and oscillate in response, which relates to the frequency of the incoming radiation.
  • Some participants express confusion over the initial question's vagueness and emphasize the need for clarity in discussing electron oscillation.
  • There are claims that the concept of a "natural frequency" for electrons is not well-defined, as multiple frequencies may be involved in different contexts.
  • One participant suggests that the electron cloud is centered over the nucleus, implying that there may not be a force pushing electrons away.
  • Another participant references "Zitterbewegung," a concept related to the trembling motion of electrons, as a potential avenue for understanding electron behavior.
Participants do not reach a consensus on the nature of electron oscillation or the forces involved. Multiple competing views and interpretations remain, with some participants questioning the initial premise and others providing various theoretical frameworks.
The discussion highlights limitations in the initial question's clarity and the complexity of defining electron oscillation, as well as the dependence on different theoretical frameworks (classical vs. quantum physics).
Thierry12
Electron oscillate at their natural frequency. I know the force that brings them back is a force of attractrion (Coulomb law) but what pushes them away?
Er.. what is an electron's "natural frequency"?
Zz.
I guess you mean within an atom... then, it's a rather tricky question! Two possible answers:
(1) Short story: "centrifugal force". Along with Coulomb attraction create an "effective potential" for the radial variable which has a minimum and, around it, a well which looks like a harmonic oscillator well for low amplitudes.
(2) You mean the frequency of rotation around the nucleus. Then, nothing to do with harmonic oscillators.
I have always found that it is almost "futile" to guess at a question that has been posed in such a vague manner. Even if one were to assume that this particular question meant either an electron in an atom, or the deBroglie wave, it still doesn't define a "natural frequency" because in both cases, there can be more than just ONE "frequency" involved.
It is best that one waits till the OP comes back and put SOME effort into explaining the question.
Zz.
Sorry for the lack of precisions, let me try again: correct me if I am wrong but i picture the oscillation of the eletron as an harmonic oscillation, and i was wondering what would the force constant be/represent? (If I am completely wrong please tell me, I am not very advanced in physics).
ty
What do you mean by the oscillation of the electron?
Sorry to tell you, but you are completely wrong.
Could you tell me how it works generaly the electron oscillation ( no need to be precise but just the general idea )
ty
If we examine the theory of Rayleigh scattering in air, the conventional theory has the electrons in atoms being displaced from the nuclei center by the E field vector of the incoming visible light photons, and pulled back by the nuclear charge center (hence dipole oscillation). The oscillation is in phase with, and at the frequency of, the incoming radiation, hence the driving force frequency. The atoms re-radiate in the plane perpendicular to the E vector, which is why Rayleigh scattering (blue sky light) at 90 degrees is polarized.
Is your question "how does the electron move within an atom"?
Many times, the problem is that the question one is asking is the thing that is wrong. Are you thinking that the electron in an atom is oscillating radially back and forward? Where did you get the idea that "Electron oscillate at their natural frequency"? You have to be more explicit when you ask things if you are a beginner.
That is the explanation given in Classical Electrodynamics, this is the Quantum Physics forum;-)
Im trying to understand how an electromagnetic wave makes charges oscillate which makes em radiation similar to the original wave. I was trying to find out about oscillation at its base to understand how it really happens.
Ty for the help btw, really appreciate it!
You really need to sit down and think through your question, because if you look at the very beginning of this thread, you mentioned no such thing, but you somehow expected us to be able to read your mind and figure out what you meant. It took SEVERAL posts to actually extract something resembling a clarification of what you actually are looking for. Oy vey!
Zz.
Sorry about that, i will try to be more precise next time
when the electrons are bound to the nucleus the light produced is exactly the same as when they are free (as in a conductor) only the amount of light produced is different. instead of total reflection from the surface (like a mirror) you only get partial reflection (like from the surface of water).
in this way of looking at things we imagine that the electron is bound to the nucleus by some kind of spring or something. this might explain the reflection of light from a surface and this would indeed result in a 'natural frequency'.
however this idea has absolutely nothing to do with light emitted when the electron transitions from one energy level to another (even though you can associate a certain frequency with each orbital. the frequency of emitted light being equal to the differece of the frequencies of the orbitals that the electron transitions between)
the answer is 'nothing'. the electron cloud sits directly over the nucleus.
When asking about the natural oscillation of electrons, it is possible that Thierry12 had heard of “Zitterbewegung”.
See: http://en.wikipedia.org/wiki/Zitterbewegung for a great explanation of the “trembling motion” of electrons discovered by Schroedinger and Dirac.
For more advanced reading, see: arXiv:0810.2186v1 “Catching the Zitterbewegung”
Of course this is not for Classical Physics, it belongs in the Quantum Physics threads.
Bobbywhy
  • · Replies 20 ·
  • · Replies 27 ·
  • · Replies 22 ·
  • · Replies 54 ·
