Electron velocity when beam is restored by a magnetic field.
The discussion centers on calculating the velocity of ions in a beam that is deflected by an electric field of 500 volts across two plates spaced 5 cm apart, which is subsequently restored by a magnetic field of 0.2 T. The electric field strength is calculated to be 1 x 104 V/m. To find the ions' velocity, the forces from the electric field (F=qE) and magnetic field (F=Bev) are equated, leading to a definitive solution for the ions' velocity.
  • Understanding of electric fields and forces (F=qE)
  • Knowledge of magnetic fields and forces (F=Bev)
  • Familiarity with potential difference and its relation to electric field strength
  • Basic principles of ion motion in electric and magnetic fields
  • Calculate the velocity of ions using the equation v = E/B
  • Explore the relationship between electric field strength and potential difference
  • Study the effects of varying magnetic field strengths on ion trajectories
  • Investigate the applications of electric and magnetic fields in particle accelerators
Physics students, electrical engineers, and professionals working in fields involving ion propulsion or particle physics will benefit from this discussion.
angelabean
A beam of ions is deflected by the electric field between two plates 5cm apart with a p.d. pf 500 volts. It is found that this deflection is restored by a magnetic field of o.2T so that the ions continue in a straight line.
What is their velocity (ions) ?
So far I am thinking:
upward force, F=qE E=v/d, 500V/ 5exp-2m = 1exp4 Vm^-1
Downward force F=mv^2/ r = Bev
F= mv^2/r^2
I have some idea of what I need to do but some clarification would be great.
Hi angelabean & welcome to PF
I think you're pretty much there... if you assume the magentic field is applied along the same length as the electric field, then to restore the path, the magnetic force must exactly balance the electric force. So I would equate them & solve for v.
I would also be careful with your notation as you have used v for both potential difference & velocity. (I would use V for potential difference, as long as its not confused with the units) ;)
You don't need the circular motion equation (if that's what it is). The forces of the magnetic and electric fields are simply opposite each other, and equating will give you the answer.
