Where Am I Going Wrong in Calculating the Net Electrostatic Force?
The problem involves calculating the net electrostatic force on a charge located at (3,0) in a coordinate system where three charges are positioned: +18 µC at (0,3), -16 µC at (0,0), and +45 µC at (3,0). Participants are tasked with determining the magnitude and direction of the net force on the charge at (3,0), specifically relative to the -x axis.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the calculation of forces between the charges, questioning the components of the forces and the angles involved. There are attempts to clarify the contributions of each charge to the net force, particularly regarding the x and y components. Some participants express confusion about the geometry of the setup and the implications for force direction.
The discussion is ongoing, with participants providing guidance on how to approach the calculation of the net force. There are multiple interpretations of the problem setup and the calculations involved, with some participants suggesting corrections to previous calculations while others express uncertainty about the correct approach.
Participants note the importance of considering the vector nature of forces and the distances involved in the calculations. There is mention of the need to clarify the distance used in the calculations, particularly in relation to the angles formed by the charges.
itsagulati
Three charges are fixed to an x, y coordinate system. A charge of +18 µC is on the y-axis at y = +3.0 m. A charge of -16 µC is at the origin. Lastly, a charge of +45 µC is on the x-axis at x = +3.0 m. Determine the magnitude and direction of the net electrostatic force on the charge at x = +3.0 m. Specify the direction relative to the -x axis.
F = k*q1*q2 / r^2
9e9 * 18e-6 * 16e-6 / 3^2 = .28768 N
and
9e9 * 45e-6 * 16e-6 / 3^2 = .7192N
(.29^2 + .72^2)^.5 = .7746N
tan^-1 ( .29/.72) = 21.8 degrees...90 - 22 = 68 degrees below the x-axis
Can anyone figure out where I am going wrong? I don't get what i am not seeing.
Thank you!
This is wrong for calculating the net force... first find the net x-component of the force acting on the charge (so add the two components due to each charge)... then find the net y-component (only one charge needs to be considered here since the charge on the x-axis only contributes an x-component)...
Then use the pythogrean theorem...
If they are straight on the x-axis just out 3.0m and the other one straight up on the y-axis just up 3.0 m...then doesn't that make them 90 degree angles? meaning no x component on the charge on the y-axis and then for the charge on the x-axis there is no y component?
So, just a charge 3.0 m out at 0 degrees and one 3.0m up at 90 degrees?
Thus only the .29 and .72 (clearly it is wrong, but i am not getting how to calculate otherwise).
Thanks!
Thanks!
The charge at (0,3) exerts both an x and y component on the charge at (3,0)...
The question is asking for the force on the charge at (3,0)... not the force on the charge at (0,0)
Ok so i was just not htinking in vectors...but here is what i have (i only have one more chance at this before it is due so i am trying to be cautious).
K * 18e-6 * 16e-6 / 9 = .288 = y comp1
K* 18e-6*45e-6/9 = .81 = x comp1
K*45e-6*18e-6/9 = .81 = y comp 2
K*45e-6*16e-6/9 = .72 = x comp2
x1 + x2 = 1.53N
y1+y2 = 1.098 N
(1.098^2 + 1.53^2)^.5 = 1.88N
THEN for the angle i am doing tan^-1 (1.098/1.53) = 35.66 degrees and relative to the -x axis that is -35.66 degrees if you draw the line to extend back through the origin and into quadrant 3?
And thanks for all of your help so far :)
It is definitely helping me past the road blocks!
You're making a common mistake calculating the components... Please look at post #22 in this thread:
https://www.physicsforums.com/showthread.php?t=181577&highlight=learningphysics+rootx&page=2
Also, I'm confused as to why you have a calculation for a force between the 18muC and -16muC charges... you only need the force on the 45muC charge...
The force that the -16muC charge exerts on the 45muC charge is 0.72N in the -x direction... or -0.72 in the x direction... that part is right.
Now you need to calculate the x and y components of the charge by the 18muC on the 45muC after looking at the post in the thread I linked...
First calculate the net force of the 18muC on the 45muC. Then calculate the x component and y component.
ok...it asks for: kq / x^2+y^2 * cos @ (where @ = theta).
only thing i can think of is 45 degrees...so:
kq / x^2 + y^2 * cos (45) = ((9e9 * 16e-6) / (3^2))* cos (45) + ((9e9 * 18e-6) / (3^2))* cos (45)?
(currently working on this...i realize i forgot the x and y component part of the problem)
No, the x^2 + y^2 is in the denominator...
What is the net force of the 18muC on the 45muC... what is r? what is r^2?
bleh. sorry the problems are getting jumbled in my head...
F = 9e9 * 45e-6 * 18e-6 / 9 = .81 N
and we already determined .72 N
So, now i calculate the x and y component?
i get: x1 = 0, y1 = .81
x2 = .72, y2 = 0
pyth. theo. => (.81^2+.72^2)^.5 = 1.08N?
Why do you have 9 in the denominator?
God i don't get this problem...
i got all the starred, double starred, etc. problems...and this no star basic arse problem i just am not getting. Why on Earth is this one so hard for me LOL
F***
9 in the denominator is from 3^2 as r^2
the only other thing i have come up with is since it is the repulsive force...then 3 sqrt(2) so 18 in the denominator giving me .405
.405 and .72 are my two sides then?
Yes, it should be 18 in the denominator... I'm not understanding why you say "since it is the repulsive force"... whether it was attractive or repulsive... the distance is 3sqrt(2) hence r^2 = 18... Hope I don't seem like a jerk... just want to make sure you understand this part. :smile:
No wait... 0.405 N is the net force exerted by the charge at (0,3) on the charge at (3,0)... that's right... now what is the x-component of this force... and what's the y-component of this force...
