Elements of Aut(Z/4Z) and their Inclusion in Inn(Z/4Z)
  • Thread starter Thread starter Mr Davis 97
    Elements
The discussion focuses on identifying the elements of the automorphism group Aut(Z/4Z) and their inclusion in the inner automorphism group Inn(Z/4Z). It is established that the identity map is the only element in Inn(Z/4Z), as all inner automorphisms yield the identity due to the abelian nature of the group. Two automorphisms are identified: the identity map and a second map defined by f(0)=0, f(1)=3, f(2)=2, and f(3)=1, which is confirmed to be a homomorphism. The conversation also explores the general approach to characterizing automorphisms of cyclic groups, emphasizing the significance of preserving order and the relationship between generators and their mappings. The necessity of the condition gcd(k,n)=1 for an automorphism is also discussed, highlighting its importance in ensuring that the mapping generates the group.
Mr Davis 97
Find, with justification, all the elements of ##\operatorname{Aut} (\mathbb{Z}/4\mathbb{Z})##. Which ones are in ##\operatorname{Inn} (\mathbb{Z} / 4\mathbb{Z})##?
First we note that ##\operatorname{id}_{\mathbb{Z} / 4\mathbb{Z}} \in \operatorname{Aut} (\mathbb{Z}/4\mathbb{Z})## and that it is the only element in ##\operatorname{Inn} (\mathbb{Z} / 4\mathbb{Z})##. This is because any inner automorphism will have the form ##c_g (x) = g+ x - g##. But since ##\mathbb{Z} / 4\mathbb{Z}## is abelian the g's cancel out and we're left with the identity.
Now, we claim that there is only one other automorphism. This comes from the the fact that ##|0| = 1,~|1|=4,~|2| = 2,~|3|=4##. Since order must be preserved by a homomorphism, ##3## must either mapped to ##1## or itself. Likewise, ##1## must be mapped to itself or ##3##. ##0## must be mapped to itself (as it is a property of homomorphisms). ##2## must also be mapped to itself because it is the only element of order 2. This leaves us with the identity map and the map where ##f(0)=0,~f(1)=3,~f(2)=2,~f(3)=1## as possibilities for automorphisms. This map is certainly bijective, so we must only check that it is a homomorphism. Since ##\mathbb{Z} / 4\mathbb{Z}## is abelian we only have to check three sums: ##f(1+2) = f(3) = 1~|~1=3+2=f(1)+f(2)##
##f(1+3) = f(0) = 0~|~0=4=3+1=f(1)+f(3)##
##f(2+3) = f(5)= f(1) = 3~|~3=2+1=f(2)+f(3)##. Hence, the map ##f## is an automorphism.
Correct. Here are my thoughts:
I find it easier to use the multiplicative notation ##\mathbb{Z}_4=\{\,1,g,g^2,g^3\,\}## but that doesn't matter. Now you have only to check what ##f(g)## could be. With ##f\neq 1 ## we get ##f(g)\in \{\,g^2,g^3\,\}## and as you said, ##f(g)=g^2## can be ruled out. Either by your argument or simply by ##f(g^2)=g^4=1## and a non trivial kernel. So ##f(g)=g^3## is left. To see it's a homomrphism ##f(g^n\cdot g^m)=g^{3n+3m}=f(g)^n\cdot f(g)^m## is easy.
Injectivity is sufficient and ##g^{3n}=1## implies ##4\,|\,3n## and so ##4\,|\,n##, i.e. ##g^n=1##.
Likes Mr Davis 97
A few questions. Why do you only have to check what ##f(g)## could be? Also, what are you trying to show in the last line of your response on injectivity?
How would I approach this problem in general? For example, how could I characterize the automorphisms of ##\mathbb{Z}/8 \mathbb{Z}##? Or ##\mathbb{Z}/n \mathbb{Z}##? Is the answer very much related to generators and mapping to other generators?
As ##g## generates the cyclic group all other values are given by ##f(g^n)=f(g)^n##.
##g^n## is an arbitrary element. If we assume ##g^n \in \operatorname{ker}(f)## we get ##f(g^n)=g^{3n}=1## and from that ##g^n=1##. Since the kernel of a homomorphism is trivial, the homomorphism is injective. Since it is a map between sets of equal finite order (4), it has to be surjective as well.
What you did was absolute o.k. I just wanted to add a different notation. This was an easy group. To determine an Automorphism group in general could be rather difficult and there is probably no golden way. At least as long as we will not use heavy machinery. It also depends on how the group is given. E.g. a presentation ##G= \langle r,s\,|\,r^2=s^n\, , \,srsr \rangle## can be difficult. (IIRC then even the word problem in an arbitrary group is NP complete.)
Similar to what you did. Abelian groups have no inner automorphisms, so all are outer. Then cyclic groups are generated by a single element, which means ##G=\langle a\,|\,a^n\rangle##. If you look closer into this situation, you will find out, which powers of ##a## are allowed to be ##f(a)=a^k##. Hint: It has to do with whether ##k## and ##n## are coprime or not. With this result, your question above is easy: ##f(g)=g^k## and ##\operatorname{gcd}(k,4)=1## can only be, if ##k=1## (identity) or ##k=3## (your automorphism ##f##). This would have been really short. I suggest to prove this as an exercise. You already did it for ##n=4## and in general the arguments are the same (no induction!).
In this case (cyclic), yes. I explained above why it is sufficient to define ##f(a)##, and you can think about, why the image of ##a## has to generate the group as well, and why all coprime powers are generators.
Likes Mr Davis 97
fresh_42 said:
As ##g## generates the cyclic group all other values are given by ##f(g^n)=f(g)^n##.##g^n## is an arbitrary element. If we assume ##g^n \in \operatorname{ker}(f)## we get ##f(g^n)=g^{3n}=1## and from that ##g^n=1##. Since the kernel of a homomorphism is trivial, the homomorphism is injective. Since it is a map between sets of equal finite order (4), it has to be surjective as well.
So here is my argument for characterizing ##\operatorname{Aut} (\mathbb{Z}_n)##.
Since ##\mathbb{Z}_n = \langle~ g|~g^n=1 \rangle##, each map from ##\mathbb{Z}_n## to ##\mathbb{Z}_n## will be uniquely determined by where it takes ##g##. Since it is necessary that automorphisms preserve order, we suspect that all of the automorphisms will be of the form ##f(g)=g^k## where ##\operatorname{gcd} (k,n)=1##. First, we show that this is a homomorphism: ##f(g^pg^q) = f(g^{p+q}) = (g^{p+q})^{k} = (g^p)^k(g^q)^k = f(g^p)f(g^q)##. Next, we show that ##f## is a bijection. The kernel of ##f## is trivial because if ##f(g^p)=1## then ##g^{kp} =1##, and so ##n~|~kp##, but ##\operatorname{gcd} (k,n)=1##, so ##n~|~p##. But ##p \in \{0,1, \dots, n-1\}##, so it must be the case that ##p=0##, and so the kernel is trivial. Hence ##f## is injective, and since this is a map between two sets of equal finite order, it is also surjective. So ##f## is an automorphism and characterizes every automorphism.
Yes, correct. Maybe the step for ##n\,|\,p## could be more detailed, but that's a matter of taste. We basically use that ##\operatorname{gcd}(k,n)=1=a\cdot k + b\cdot n##, multiply by ##p## and take the module by ##n##.
What you have shown now is, that ##f(g)=g^k## is an automorphism if ##\operatorname{gcd}(k,n)=1##. What's left to show is, why this is also a necessary condition. Why is ##f## no automorphism if ##\operatorname{gcd}(k,n) > 1##.
Didn't I show the necessary condition (maybe somewhat implicitly) by using the fact that any isomorphism must preserve order? Doesn't this necessitate that ##\operatorname{gcd}(k,n)=1##?
In a way, yes, but this is very implicit in my opinion. Why do elements for which ##k## and ##n## share a common factor, say ##k=r\cdot s## and ##n=r\cdot t##, do not generate the group? However, you are right, this is a matter of how detailed a proof should be.
Don't they not generate the group because they have a different order than the generator ##g##, since ##|g^k| = \frac{n}{\operatorname{gcd} (k,n)}##? Order is the same iff ##\operatorname{gcd} (k,n) = 1##
Yes, in case you have this formula, which I think is not so obvious that it doesn't need proof or at least mention. However, I repeat myself, it's a matter of taste, resp. audience.
Likes Mr Davis 97
  • · Replies 16 ·
