Ellipsoid intersected by cylinder
  • Thread starter Thread starter jonroberts74
    Cylinder Ellipsoid
10 replies · 2K views
jonroberts74
Find volume of the ellipsoid ##x^2 +2(y^2+z^2) \le 10## intersected by the cylinder ##y^2 + z^2 \le 1 ##
seems like changing to cylindrical coordinates would be best
so I have
[tex]\left\{ \begin{array}{cc} r^2cos\theta + 2r^2sin^2\theta +2z^2 \le 10 \\r^2sin^2\theta +z^2 \le 1 \end{array}\right.[/tex]
[tex]0 \le \theta \le 2\pi[/tex]
and solving for z [tex]-\sqrt{1-r^2sin^2\theta} \le z \le \sqrt{1-r^2sin^2\theta}[/tex]
and [tex]-\sqrt{8}sec\theta \le r \le \sqrt{8}sec\theta[/tex]
[tex]\int_{0}^{2\pi}\Bigg(\int_{-\sqrt{1-r^2sin^2\theta}}^{\sqrt{1-r^2sin^2\theta}}\Bigg(\int_{-\sqrt{8}sec\theta}^{\sqrt{8}sec\theta}rdr\Bigg)dz\Bigg)d\theta[/tex]
I tried it on Wolfram|Alpha to check but it didn't seem to work.
Two things, when you set up the boundaries of your integral you have to make sure you eliminate a variable at each step. Therefore you need to do the z integral before the r integral. Otherwise, you will integrate r and then introduce another r which you will not be able to get rid of.
Second, r is defined from the origin so you integrate from 0 to the maximum value.
jonroberts74 said:
Find volume of the ellipsoid ##x^2 +2(y^2+z^2) \le 10## intersected by the cylinder ##y^2 = z^2 \le 1##
You can use
Code:
brackets to enclose tex statements. Presumably that second equation is a typo and means ##y^2 \color{red} + z^2 \le 1##
so I have
Cylindrical coordinates is a good idea, but not in the usual variables. Your cylinder and ellipsoid are both circular in the yz variables. So you want to use cylindrical like variables where the ##r## and ##\theta## variables are used in the ##yz## plane and you treat the ##x## axis as though it were the ##z## axis and integrate that direction first.
oh yeah, I didn't think of that. thanks
LCKurtz said:
You can use
Code:
before I go use up scratch paper. I am going to treat x as z, so should I set ##z = r cos \theta##? so my ##0 \le \theta \le 2\pi## will revolve about the z-axis as opposed to the x axis
EDIT: better yet after looking at it in grapher I am thinking ##y=rcos\theta ; z = rsin\theta##
##x^2 +2r^2(cos^2\theta + sin^2\theta)=10##
##r^2(cos^2\theta + sin^2\theta)=1##
##\int_{0}^{2\pi}\Bigg(\int_{-1}^{1}\Bigg(\int_{-\sqrt{10-2r^2}}^{\sqrt{10-2r^2}}dx\Bigg)rdr\Bigg)d\theta##
EDIT: I think the bounds are still amiss though because I got 0 which cannot be a correct answer for the volume
Think about what each of ##\theta, r, x## represent and then have another look at your bounds.
the ##\theta## bounds makes sense because there's a full revolution the the ##r## bounds are the cylinder so its on the interval [0,1]
still seems to not work
EDIT: nevermind I got it.
You don't want negative values of ##r##. You get the whole circle for positive ##r## and ##\theta## going all the way around. Much simpler this way, don't you think?
yeah I wasn't thinking in terms of polar. thanks!##\int_{0}^{2\pi}\Bigg(\int_{0}^{1}\Bigg(\int_{-\sqrt{10-2r^2}}^{\sqrt{10-2r^2}}dx\Bigg)rdr\Bigg)d\theta##
You could do this by looking up formulas rather than integrating. The volume of the ellipsoid cut by the cylinder is the volume of the cylinder inside the ellipsoid plus the volume of the two caps at each end of the cylinder. The ellipsoid is bounded by [itex]x^2+ 2(y^2+ z^2)= 10[/itex] and the cylinder by [itex]y^2+ z^2= 1[/itex]. Obviously the cylinder cuts the ellipsoid when [itex]x^2+ 2(y^2+ z^2)= x^2+ 2(1)= 10[/itex], [itex]x^2= 8[/itex], [itex]x= \pm\sqrt{8}= \pm 2\sqrt{2}[/itex].
So the volume we want is a cylinder with radius 1 and height [itex]2\sqrt{2}- (-2\sqrt{2})= 4\sqrt{2}[/itex] plus the two spherical caps with bases disks of radius 1 and height [itex]\sqrt{10}- 1[/itex].
