I Embedding homeomorphic manifolds
  • I
  • Thread starter Thread starter Q-1
    manifolds
Q-1
Please forgive any confusion, I am not well acquainted with topological analysis and differential geometry, and I'm a novice with regards to this topic.
According to this theorem (I don't know the name for it), we cannot embed an n-dimensional space in an m-dimensional space, where n>m, without the former losing some of its structure.
So, does that mean that you can't render a higher n-dimensional space (for example, 4D), into a lower dimensional m-dimensional space (3D)? Is information lost, when trying to do so?
Edit: Does this relate or is applicable to holographic renderings?
How would you embed a full ball into a flat plane? You can only take perspectives, and these aren't bijective.
What do you mean by this?
Thanks.
If you have a 3D full ball laying on your desk, then you can take a photo, but all points on the line between the surface of the ball and the desk will be only one pixel of the photo. That is surjectivity and not injective, i.e. no embedding.
You can also say: A 3D object has 3 degrees of freedom, a plane only 2, so it cannot be embedded. That's basically how dimension is defined. The homeomorphism doesn't matter here, it only squeezes and stretches things.
If you want a detailed answer, then please define "dimension" first.
Likes Klystron
Is this true? Bijections exist between ##\mathbb{R}^n, \mathbb{R}^m, n\neq m##, thanks to Cantor. I thought that dimension was a topological property (i.e., preserved under homeomorphisms).
Likes Klystron
Yes, in a sense, you do lose information when you lower dimensions
But none of these maps are even locally continuous, as this would violate " Invariance of dimension" . There are definitely surjections, but I don't think they are injective. But it is also a standard result ( though not too easy to prove/generalize) that for ## m \neq n \mathbb R^n , \mathbb R^n ## are not homeomorphic.
You are right, e.g. the Hilbert curve. I erroneously had in mind that it wasn't injective, i.e. I had an example in mind with crossing lines. In any case, it depends on the definition of dimension. I think there are a couple of them: Hausdorff, fraktal, locally Euclidean for manifolds. I had the latter in mind, but that was why I asked for the definition, because the term isn't nearly as obvious as it sounds. I guess Lebesgue's covering dimension is appropriate here if we talk about homeomorphisms and therewith about topologies. But unless stated which one to use, there will be room for confusion.
Likes Klystron
If you use the Hausdorff ( On Golf?) dimension mentioned by Freshmeister, you will see that the Hausdorff dimension of ## \mathbb R^n ## is ##n##, which shows them to not be homeomorphic. We also use other types of dimension like Topological dimension: https://en.wikipedia.org/wiki/Lebesgue_covering_dimension
All I know in terms of proving this in other ways is still using heavy machinery, like Homology or Cohomology.
EDIT: Notice how we can go from lower to higher easily through ##(x_1,..,x_n) \rightarrow (x_1, x_2,...,x_n,0)##, but we cannot do this in the opposite direction.
Likes Klystron
this is not so easy to prove. for the case of R^1 and R^2, we can use connectivity. I.e. R^1 can be separated into two disjoint open subsets by removing one point, but R^2 cannot, so they cannot be homeomorphic.
If we know the jordan curve theorem, then any closed simple curve separates R^2 into two open disjoint components, but there is obviously a circle that does not separate R^3, so R^2 cannot be homeomorphic to R^3.
To keep going we need some theorems on how to separate R^n by an embedded sphere, or some other roughly equivalent result.
Another related approach is to ask about continuous maps of spheres into these spaces. E.g. if R^n is homeomorphic to R^m, then also the one point compactifications of these spaces are homeomorphic. Thus it is sufficient to prove that the spheres S^n anmd S^m are not homeomorphic if n > m.
For this we can define the concept of homotopic maps. Then we prove that the identity map of S^n to S^n is not homotopic to the constant map, but that for m < n, every continuous map from S^m to S^n is homotopic to a simplicial map which is not surjective, hence is homotopic to a constant map (since any proper subset of a sphere is contained in a contractible set). Thus when n>m, S^n, cannot be homotopic and thus not homeomorphic, to S^m. hence the same statements hold for R^n and R^m. (and thus also for all manifolds of different dimensions.)
I learned all this in a second year grad course on topology, but you can also prove it by homology theory, which was taught in first year topology in grad school. I just like homotopy theory better as more geometric and therefore to me more intuitive.
since i remember this over 50 years later, i wish to thank and compliment my teacher, Ed Brown Jr. of Brandeis.
Here is a link to one of his more beautiful results, that for good spaces, cohomology is "representable", i.e. equivalent to homotopy classes of maps into a specific space.
https://www.maths.ed.ac.uk/~v1ranick/papers/brown3.pdf
oops i am proving that R^m is not homeomorphic to R^n if n > m, and what is wanted is that R^n does not embed in R^m. If I think of how to do this variation I will post it later.
Likes member 587159
Don't we have something like borsuk ulam , that the n-sphere embeds in ##\mathbb R^n ## or higher? Then, if m<n, the n-sphere does not embed in ##\mathbb R^m## so the two cannot be homeomorphic. Does that work?
The Invariance of Domain Theorem says that a 1-1 continuous map ##f:U→R^{n}## of an open subset ##U## of ##R^{n}## into ##R^{n}## maps ##U## into an open subset of ##R^{n}##.
If ##g:U→R^{m}## is an embedding with ##m<n## and ##i:R^{m}→R^{n}## is the inclusion map then ##i \circ g: U→R^{n}## is an injective continuous map so its image is open. But no subset of ##i(R^{m})## is open in ##R^{n}##.
There is a confusing point here - confusing for me -which is why isn't it sufficient to use mathwonk's proof that ##R^{n}## and ##R^{m}## are not homeomorphic?
@mathwonk can you explain this?
it probably does suffice if you use it locally, since all open balls in R^n are homeomorphic to all of R^n. I was just trying to do it somewhat completely without quoting big theorems i did not prove.
How about the idea of Borsuk-Ulam, in that if n<m and S^{m-1} embeds in R^m , but not in R^n, then R^m, R^n cannot be isomorphic?
that sounds great! nice argument.
i confess i don't always remember the statement of the borsuk ulam theorem. It seems to me we had this discussion recently however of proving borsuk ulam, but i confess i have forgotten already how i proved it. oh yes it was a clever use of vector fields or something that i needed a hint for from chinn and steenrod. since i have a poor memory now i like to reduce everything to a few basic tools and try everytime to remind myself of how to use those tools to do the proofs. i.e. degree theory, homotopy, and homology which i know less well and find rather tediously complicated. i can visualize homotopy and path connectedness but not so much algebraic tools like homology.
my goal is to have a strong intuitive grasp of a few basic tools so that i can prove anything, but without quoting any theorems i do not know how to prove. for me this is all mental exercise to ward off alzheimer's and take pleasure in the contemplation of the concepts. thanks for the nice reminder of the value of the beautiful borsuk ulam theorem, i recall now appreciating earlier how clever it is to prove that more precise statement rather than the more general statement that the map cannot be injective. unfortunately i do not easily remember clever arguments, being less and less clever as i age.
so as to why i did not use some proof that to you youngsters is clearly sufficient, i just usually did not think of it. and i have this ideal that someday, if i understand a few basic principles well enough, then for every question i will be able to say: well if you use this principle, then it is easy. maybe i should include borsuk ulam among my fundamental principles! best wishes for stimulating responses as usual.
Likes lavinia and Klystron
Here is the statement of the Borsuk-Ulam Theorem on Wikipedia.
"In mathematics, the Borsuk–Ulam theorem states that every continuous function from an n-sphere into Euclidean n-space maps some pair of antipodal points to the same point. Here, two points on a sphere are called antipodal if they are in exactly opposite directions from the sphere's center."
Likes mathwonk and Klystron
I once sat in on a basic course in algebraic topology. The teacher considered a valid proof to be an intuitive picture. If a student attempted a deductive argument he got angry.
It seems that mathematics is often thought of as mere deduction starting with axioms. Intuition is often overlooked.
Yes.
There are also continuous maps that are surjective. But there is no continuous bijection.
One can completely fill space of any finite dimension with a continuous curve.
A Comment on the Invariance of Domain Theorem
Generally a continuous bijection ##f:U→X## onto a subset of a topological space ##X## is not a homeomorphism since the inverse function might not be continuous.
But in the special case of an open subset of ##R^{n}## mapped into ##R^{n}## it is true. This is why this theorem is so powerful.
lavinia said:
Yes.
I think there isn't even a local bijection between the two, meaning between open sets. If there was , restrict to a closed (bounded, of course) ball in the sets in question. This gives then a continuous bijection between compact and Hausdorff, which is a homeomorphism. Then we have a homeo between a set in ## \mathbb R^n ## and one in ##\mathbb R^m##.
i will think further on invariance of domain now, thank you. in regard to my remarks about algebraic functors like homology versus geometric ones like homotopy, the theorem i linked to of edgar brown jr is remarkable: it turns out that for reasonable spaces (simplicial complexes, but not a topologists sine curve), the apparently algebraic cohomology functor is naturally equivalent to a homotopy functor! e.g. (I may get this wrong modulo spaces with base points versus not) H^1 is equivalent as a functor to the homotopy classes of maps to the circle! The point is that there is a duality, again for nice spaces, between maps of circles into a space, i.e. sort of 1st homology, and maps out of the space into a circle. I.e. given a 1-cocycle on a nice space X, there is a map of X into a circle that pulls back the standard generator of cohomology, namely dtheta, to that cocycle class. this generalizes in higher degrees to homotopy classes of maps into "eilenberg maclaine" spaces, spaces with homoopy groups in only one dimension.
mathwonk said:
i will think further on invariance of domain now, thank you. in regard to my remarks about algebraic functors like homology versus geometric ones like homotopy, the theorem i linked to of edgar brown jr is remarkable: it turns out that for reasonable spaces (simplicial complexes, but not a topologists sine curve), the apparently algebraic cohomology functor is naturally equivalent to a homotopy functor! e.g. (I may get this wrong modulo spaces with base points versus not) H^1 is equivalent as a functor to the homotopy classes of maps to the circle! The point is that there is a duality, again for nice spaces, between maps of circles into a space, i.e. sort of 1st homology, and maps out of the space into a circle. I.e. given a 1-cocycle on a nice space X, there is a map of X into a circle that pulls back the standard generator pf cohomology, namely dtheta, to that cocycle class. this generalizes in higher degrees to homotopy classes of maps into "eilenberg maclaine" spaces, spaces with homoopy groups in only one dimension.
Isn't ## H^1## always the Abelianization of ##\pi_1## (or the other way around)?
yes indeed (the former), at least for path connected spaces (see p. 48, greenberg's lectures on algebraic topology). (Oops, not H^1 but H_1, since these are both covariant.) this is why i implied that homology is related to maps of circles into the space. this is indeed a nice relation of 1st homology with a geometric construct, although it is not entirely clear what the geometric content of "abelianization" is. this has no higher dimensional analog however. the only general relation between higher homotopy and higher homology i know of occurs in only one diomension, namely the first dimension in which a non zero homotopy group occurs. I.e. if all homotopy groups in dimensions less than n are zero, and n > 1, then the nth homotopy group is isomorphic to the nth homology group. But after that all bets are off.
Cohomology however which is often algebraically dual to homology is, for nice spaces (cw complexes), given in each dimension n, by homotopy classes of maps to a certain nth degree "classifying space". In dim one, that space is the circle, so that says that 1st homology, or essentially equivalently maps of the circle into the space, are the same as homotopy classes of maps of the space to the circle.
In dimension 2, although there is no general relation between 2nd homology and 2nd homotopy (i.e. the standard map from π2 to H2 is neither injective nor surjective in general), there is a degree 2 classifying space K(Z,2), (which happens to be infinite dimensional complex projective space), such that 2nd integral cohomology, i.e. H^2, is equivalent to homotopy classes of maps to the classifying space K(Z,2).
of course as stated above, in case π1 = 0, then H2 and π2 are isomorphic.
some of these general principles do not always hold for bad spaces. e.g. if one cuts apart a circle and then closes it up by a clasp formed by part of the topologists sine curve, one gets a space that admits no non trivial map of a circle, so π1 = 0. contrary to the representation theorem of brown mentioned above however, there are non trivial maps from this odd space to the circle. In particular this odd bracelet is simply connected, but its complement in the riemann sphere has 2 components.
this contradicts a principle i have had in mind from reading ahlfors book on complex analysis where he uses for certain subsets of the complex numbers, a definition of simple connectedness that equates it with the complement in the sphere being connected. It seems he used this definiion only for bounded open subsets.
There is something here about K(Z, ##\infty##) being Complex Projective space or something. Is that a sort of direct limit? You know how that works?
There is a fibration (even a fiber bundle) S^1\to S^\infty\to\mathbb{C}P^\infty. The long exact sequence for a fibration then tells you that \mathbb{C}P^\infty is K(\mathbb{Z},2) since S^\infty is contractible.
Likes mathwonk and WWGD
thank you! ( I just repeated something i read and have not gone through the calculation. Thanks for reminding of the value of the Hopf fibration!)
as to the invariance of domain theorem lavinia emphasized, i have been thinking about it and realized it follows for the jordan curve theorem. so here is another case of a beautiful theorem that is an easy corollary of another harder theorem. i.e. a basic (fairly easy) principle in topology is that a bijective continuous map of compact hausdorff spaces is a homeomorphism, i.e. is an open map. (for compact hausdorff spaces, closed is equivalent to compact, and compact sets are preserved by continuous maps so all continuous maps are also closed.) so for (weak) invariance of domain we want to prove that a continuous bijection of R^n is a homeomorphism, i.e. is open.
So consider the image of a closed sphere. It is a closed subset homeomorphic to a sphere, hence by jordan, separates R^n into two connected components, both open and one bounded. then ask for the image of the interior of the sphere. It must be connected and bounded since the image of the closed ball is compact hence bounded. Moreover the image of the exterior of the sphere must be connected hence must be the unbounded component. Hence the map sends the interior of the closed sphere onto the interior of the image of the sphere.
Now since a closed ball in R^n is compact hausdorff, this restricted map is a homeomorphism. it follows that the whole map is a homeomorphism of R^n. Thus the fact that a bijective continuous map of R^n is a homeomorphism, is a fairly easy corollary of the jordan curve theorem. so again we have a situation where the more basic and underlying theorem is the jordan curve theorem, dealing with connectivity.
Likes lavinia
mathwonk said:
thank you! ( I just repeated something i read and have not gone through the calculation.)
@mathwonk Nice proof. The idea is that the image of the interior of a closed ball around any point must be open by the Jordan Curve Theorem.
I am unsure about the last paragraph. It seems unnecessary.
I think you are right that openness has already been proved, hence homeomorphism.
One can also extend this proof to the stronger invariance theorem you mention, that an injective continuous map is open, by using a slightly stronger statement of jordan, that not only is the complement of the embedded sphere consisting of two open components, but the sphere actually wraps around each point of the bounded component, hence the map on the closed ball must be onto every such interior point, so again, without bijectiveness, we get the interior of the ball mapping onto the open bounded component. Maybe this is also unnecessary, but I did not see it.
Anyway, I like your emphasis on what this proves, as it is in general interesting to know in what categories a bijective morphism is an isomorphism. It holds e.g. in compact hausdorff spaces, and in banach spaces, and groups of course, but your observation seems to show it is also true for n dimensional manifolds. It fails in the presence of certain singularities, since in algebraic geometry a smooth curve can map bijectively onto a curve with a cusp, but not isomorphically. In algebraic geometry, "normality" is sufficient, but smoothness, i.e. non singularity is of course ok too.
Likes Klystron
For the case of closed orientable smooth ##n##-manifolds, most of the duality follows from the Implicit Function Theorem together with Sard's Theorem. If ##x## is a regular value of a smooth map ##f:M→S^1## then the Implicit Function Theorem says that ##f^{-1}(x)## is a smooth closed codimension 1 submanifold. This hypersurface is orientable since its normal bundle is trivial and ##M## is orientable. The Poincare dual of ##f^{-1}(x)## is an element of ##H^{1}(M;Z)##.
Sard's Theorem says that the critical values of a smooth function are closed and have measure zero so regular values always exist and one always has these hypersurfaces. The homology classes of these hypersurfaces are the same for any regular value of ##f## and are the same for any function ##g## that is smoothly homotopic to ##f##. Conversely, if two functions yield the same oriented hypersurface, then they are smoothly homotopic. The proofs again just use the Implicit Function Theorem. One gets an injective map from homotopy classes of maps of ##M## into the circle into the first integer cohomology group of ##M##.
Using the Tubular Neighborhood Theorem, it can also be shown that any closed orientable hypersurface is the inverse image of a regular value of some function into the circle. This implies that the map is also surjective since every codimension 1 integer homology class of an orientable smooth manifold is represented by an orientable closed hypersurface.
Note:
One can use the naturality of Poincare duality to show that these hypersurfaces are Poincare dual to the pull back of the fundamental integer cohomology class of the circle. Any regular value is Poincare dual to the fundamental class of the circle and the induced hypersurface is dual to the pull back of the fundamental class. This guarantees homotopy invariance and independence of the regular value.
Likes mathwonk
It's not true for manifolds. Map [0,1) to the unit circle using the complex exponential. Any smooth bijection with a critical point is also a counterexample in the smooth case (like the cubic function on \mathbb{R}).
I think an ##n## dimensional manifold is meant to be without a boundary. In that case, the theorem is true.
Likes Klystron
  • #31
yes, in my terminology, [0,1) is called a "manifold with boundary". i suppose you can generalize it to that case by saying the map restricts to a bijection between the two respective boundaries.
this phenomenon does fail for differentiable real manifolds however, (project the graph of y = x^3 onto the y axis), but it holds again for complex analytic manifolds, e.g. riemann surfaces.
  • #32
to add a little detail to lavinia's beautiful post #28, recall that poincare duality for manifolds is via intersection theory, which we thus want to relate to winding numbers. To specify a one diml cohomology class on M we want to see how it acts on a 1 diml cycle. If we have a map f from M to the circle, and a one cycle c on M, we can define the action of the corresponding cohomology class [f] on c by mapping c to the circle by f and asking how many times the image winds around the circle, i.e. we integrate dtheta/2π over the 1-cycle, which is the action of the pullback via f of the fundamental cohomology generator of the circle, on c.
Now as lavinia observed, we could alternatively look at the inverse image of a point p on the circle, via f, choosing p as a regular value, and obtain a sub manifold N of dimension n-1 in M. Now this sub manifold is poincare dual to a 1-cocycle [N], and the correspondence is by intersection of N with a one cycle. So [N] acts on c by intersecting N with c. Now almost by definition of N, this (oriented) intersection number equals the number of oriented preimages of the point p under the map f restricted to c, i.e. it is the number of times the path f(c) passes through the point p on the circle. (The orientation on the intersection cycle is sensitive to which direction the path passes through p, hence turning around and passing in the opposite direction subtracts an intersection, as it should).
Now by the basic principle of degree theory that the number of times you go around a monopoly board equals the number of times you pass GO, this oriented number of preimages equals the winding number of the path f(c) around the circle. Hence as lavinia said, the two actions, that of the class [N], and that of f*(dtheta) on c are equal.
Presumably this generalizes to higher dimensions, but it is a little harder for me to visualize it since the target spaces in higher dimensions tend to be infinite dimensional, i.e. to construct a K(Z,2) space, you start from a simply connected space with π2=Z, but then you have to add cells in all dimensions where your space has higher homotopy. I.e. you have to kill off all higher homotopy in all higher dimensions; the circle is nice since its universal cover is contractible, hence has no higher homotopy.
I suppose when you map a finite dimensional manifold into an infinite diml classifying space, you can prove the image can be considered as only lying in a finite amount of the skeleton, but to make sense of the theory of inverse images, we need the map representing a 2-cocycle say, to map into a 2 dimensional space, in order to claim the inverse image is of codimension 2. so it wold be nice if the 2-sphere were the classifying space, but as mentioned before, that is not true since the 2-sphere has homotopy in dimension 3 for instance, so you have attach a 4-cell to kill that element off...nonetheless Brown's theorem is true, but I have forgotten the arguments these 50 years later.
Lets see, maybe if we approximate our map by a simplicial map, hmmmmm... I wonder if even when our source space is higher diml, maybe we can homotopy the image of our map into the 2-skeleton using the vanishing of higher homotopy...?
  • #33
Ok here is a speculative suggestion of how to generalize lavinia's discussion to higher dimensions. Given a 2-cohomology class on an n manifold M, find the sub manifold N of codimension two which is poincare dual to it, then use some tubular nbhd argument (?) to realize N as the fiber over a regular value of a smooth map from M to the 2-sphere, i.e. CP^1. (Or do we need a triviality resultful the normal 2-plane bundle?) I.e. thus we would get a surjection from homotopy classes of maps M-->CP^1 to H^2(M), but then we presumably need the higher dimensional cells in CP^infinity, to kill the kernel of this surjection, i.e. two maps from M to CP^1 might give the same fiber but not be homotopic. ?
no that seems unlikely to work. e.g. let M = CP^2 and the the 2nd cohomology is poincare dual to the subspace CP^1, which seems unlikely to be represented by the fiber of a map to S^2 = CP^1. and the normal bundle is not trivial, since the zero locus of a section is represented by the self intersection of CP^1 i.e. degree one, not zero.
the map representing this cohomology class would seem to be the inclusion of CP^2 in CP^infinity. ?
  • #34
The arguments involving regular values generalize to any sphere but one can not in general obtain the entire second integer cohomology group from regular values of maps into the 2 sphere. For instance, if a cohomology class has a non-trivial cup product with itself it can not be the pull back of the fundamental class of the 2 sphere. In order to get 2 dimensional cohomology classes with non zero self cup products the classifying map must be into a higher dimensional complex projective space.
For a given manifold, I think that a single finite dimensional complex projective space will classify all of ##H^2(M;Z)##. But if its dimension is greater that the dimension of ##M## it is not immediately clear to me how to use the Implicit Function Theorem.
Also, no torsion class can be Poincare dual to an oriented smooth submanifold this because the Poincare dual can be represented by a smooth differential form. This form is cohomologous to the Thom class of the normal bundle to the submanifold.
Likes mathwonk
  • #35
We can get some insight about the relation between second cohomology of a manifold M and subspaces of codimension two in M, from the situation in algebraic geometry. As lavinia has explained, not all 2-cohomology classes occur as poincare dual to embedded oriented sub manifolds, but we could ask which ones do. We could also ask which ones are poincare dual to the fiber of a map to a 2-sphere. But we know that all classes are pullbacks via maps to infinite dimensional projective space, although for a given class on a given manifold, presumably the map can be chosen as going into a specific finite dimensional projective space, although possibly of high dimension, i.e. not only greater than 2, but greater than the dimension of the given manifold M.Thus it seems the right way to get a subspace of M from a map on M, is to look at the pullback, not of a point, but of a subspace of codimension 2 in the target space, e.g. of a hyperplane in projective space, in case our map goes into a projective space of any dimension. Thus given a map f:M—>P^r, for any r, we choose a hyperplane (this mathematically naive spell checker prefers hydroplane) of P^r that does not contain the full image f(M), and we pull back that hyperplane H to its inverse image f^-1(H) in M.In algebraic geometry, an algebraic map, or in complex geometry an analytic map, from M to P^r is defined by sections of a line bundle L on M, which has a chern class c, in H^2(M;Z), and under some hypotheses, which I am embarrassed to say I cannot state explicitly at the moment, (perhaps that the space of global sections of L has no "base divisor"), this chern class equals the pullback of the unique distinguished generator of H^2(P^r;Z) = Z, i.e. of the cohomology class of a hyperplane.Now it is a famous theorem of Lefschetz that a cohomology class c in H^2(M;Z), where M is a compact complex manifold, is the chern class of some line bundle if and only if it has “type (1,1)”, i.e. if under the Hodge decomposition of H^2(M;C) = H^(0,2) + H^(1,1) + H^(0,2), the class c maps into the component of type (1,1), by the map H^2(M;Z)—>H^2(M;C).In sheaf cohomology language, in which line bundles are classified up to isomorphism by classes in the group H^1(M;O*), this says that c goes to zero under the map H^2(Z)—>H^2(O), induced by the sheaf sequence 0—>Z—>O—>O*—>0 and the following map from the corresponding long exact sequence H^2(Z)—>H^2(O). I.e. we have
H^1(O*)—>H^2(Z)—>H^2(O), where the first map is the chern class map.Now for a “very ample” line bundle L, the corresponding map to projective space f:M—>P^r given by a basis of the space of global sections of L, is an embedding, and the standard generator of P^r does pull back to the chern class of L. But it seems that the corresponding maps to projective spaces of lower dimensions g:M—>P^s, s ≤ r, given by subspaces of the space of global sections of L, may also pull back the standard generator to the chern class of L, at least under some conditions.In particular, if we project down to P^1, that is CP^1 ≈ S^2 the usual 2-sphere, we may get a map with fiber poincare dual to the chern class. The catch is that projection tends not to be well defined when the center of projection meets the embedded manifold. Still it becomes well defined on a “blowup” of that manifold. In particular every pair of independent global sections of L defines a map M’—>P^1, where M’ is the blowup of M along the (complex) codimension 2 intersection in m of the zero loci of the 2 sections.
So we are getting, at least for certain 2 diml cohomology classes, some geometric realization via a map to both P^r for large r, and in some sense also via a map to P^1 ≈ S^2.
In the category of smooth topology, given a smooth map M-->P^r, presumably we want to choose our hyperplane to satisfy some transversality condition wrt the map f. No doubt a generalization of Sard guarantees existence of such, perhaps see Guillemin and Pollack.
Likes WWGD
  • #36
Is the Algebraic Geometric map you refer to the Lefschetz Hyperplane Theorem?
  • #37
no that is a much deeper theorem. Given a complex line bundle L on a compact complex manifold M, there is a finite dimensional vector space H^0(L) of global sections of that bundle. If s0,s1,...,sr is a basis of that space of sections, we define a map on M as sending a point p to [so(p),...,sr(p)]. Now the values sj(p) all lie in the same one dimensional complex vector space, the "line" over p. Thus their ratios determine a unique point of projective space P^r. This defines a map M-->P^r which is defined at those points p at which at least one section is non zero. "L has no base points" means it is defined at all points. Then we get a map M-->P^r defined everywhere and we can look at the intersection of the image f(M) with a hyperplane. That hyperplane pulls back to a (complex) codimension one subspace N of M that in good cases is poincare dual to the pullback of the standard generator of H^2(P^r;Z).
The Lefschetz hyperplane theorem gives a strong relationship between the low degree homology, cohomology, and homotopy groups of M and N. I.e. if (complex) dim(M) = n, then any of these groups is the same for M as for N, in degrees < n-1. The hypothesis is that M is embedded in P^r and that if M is singular, then N contains all the singularities of M.
If we apply this to the case of M = CP^3, and N a non singular surface embedded in P^3, then the case of π1 implies that N, i.e. any smooth complex surface embedded in CP^3, is simply connected, just because CP^3 is simply connected.
Likes WWGD
  • #38
The theorem of Lefchetz was first proved by him with the aid of a decomposition of the embedded algebraic manifold by means of a "Lefschetz pencil". This concept is just an example of the procedure we defined of projecting a manifold that is embedded in a higher dimensional projective, and projecting it down to P^1. E.g. consider a surface M embedded in P^3 and a line L (not a line bundle), meeting M at a finite set of points. Then consider the pencil of planes containing L. This pencil is parametrized by a P^1, so we get a map from M to this P^1 sending each point p of M to the plane determined by L and p. This is undefined precisely at the points where L meets M, but can be extended to the blowup of M at this points, a space obtained from M by replacing each of those points by a copy of P^1.
This blowup space is then fibered over P^1 ≈ S^2, with fibers isomorphic to the intersections of M with the planes through L. These intersections have been made disjoint by blowing up M. I.e. each point of MmeetL has been replaced by a whole P^1 of points, one for each plane. Thus the map from the blowup to P^1 is now isomorphic on each copy of P^1 replacing a point where L met M. I.e. those plane sections of M which used to meet each other, are now disjoint fibers of the map from the blowup M' to P^1 ≈ S^2. I suppose one can use the fairly simple relation between the cohomology of M and its blowup to say something of value. Note that in the new blowup space, the normal bundle of one of these plane sections has apparently been rendered trivial. I am not at all expert on this but it is such fun to see things becoming somewhat more clear and more overlapping with the concepts above of Brown's theorem and lavinia's geometric realization in degree one.
It appears to me that one can always project an embedded manifold M down into a space of the same dimension as M and still pullback a hyperplane to give a copy of a hyperplane section of the original embedded manifold M. This may help with lavinia's concern. Thus we may be able to realize a chunk of H^2, i.e. the (1,1) part, by a map to CP^n, where n = (complex) dim(M), in particular CP^n and M have also the same real dimension 2n.
This is super fun, not necessarily proving anything, but beginning to understand some things I had studied and memorized partially. Thank you!
  • #39
Thanks to @mathwonk for suggesting inverse images of higher dimensional submanifolds. Here is a thought on how to approach his idea.
There is a generalization of the Implicit Function Theorem due to Thom which says that if a map is transverse to a submanifold then the inverse image of the submanifold is a submanifold of the same codimension. If ##f:M→N## is transverse to ##S⊂N## where ##S## is a closed smooth submanifold of codimesnion k, then ##f^{-1}(S)## is a closed submanifold of ##M## of codimension k.
Transverse means that the dimension of the span of the tangent space to the submanifold together with the image of ##df## equals the dimension of the ambient manifold. This generalizes the idea of a regular value. A regular value is a zero dimensional submanifold on which ##f## is transverse.
The key theorem is that in any homotopy class of smooth maps, there is a map that is transverse to a given manifold. So in the case of complex projective spaces one can choose a nearby function that is transverse to the complex projective subspace of 1 less complex dimension. For instance, in the case of the 2 sphere this would be a point. In the case pf ##CP^2## it would be ##CP^1##.
If ##f## is transverse to the complex hypersurface ##CP^{m-1}## then ##f^{-1}(CP^{m-1})## is a codimension 2 submanifold of ##M##.
The Poincare dual of ##CP^{m-1}## given the canonical orientation is the generator of the integer cohomology group ##H^2(CP^{m},Z)## and this is just the fundamental class ##ω## of the 2 sphere embedded and oriented in ##CP^{m}## as ##CP^1##. Its pull back is Poincare dual to the codimension 2 hypersurface ##f^{-1}(CP^{m-1})##.
As mathwonk pointed out, ##f^{*}(ω)## is the Chern class of the pull back bundle ##f^{*}(γ^{m})## of the canonical(also called tautological I think) line bundle ##γ^{m}##
It remains to show that this map is bijective if ##CP^{m}## has sufficiently high dimension..
Surjective I think that one could start with an orientable codimension 2 hypesurface ##H## and consider the classifying map for its normal 2 plane bundle ##E## (which is a complex line bundle) into some complex projective space ##CP^{m}##. One gets a bundle morphism from ##E## into the canonical line bundle over ##CP^{m}##. Since ##H## and ##E## are orientable there is a tubular neighborhood of ##H## in ##M## which is homeomorphic to ##E##. This tubular neighborhood maps onto a tubular neighborhood ##T_{m}## of ##CP^{m}## in the canonical line bundle. Note that the classifying map is transverse to ##CP^{m}## in ##T_{m}##.
The normal bundle to ##CP^{m}## in ##CP^{m+1}## is also isomorphic to the canonical line bundle so ##T_{m}## may be taken to be a tubular neighborhood of ##CP^{m}## in ##CP^{m+1}##.
Identify the boundary of ##T_{m}## to a point ##p## and map the rest of ##M## to ##p## . I think ##T_{m}## modulo its boundary is homeomorphic to ##CP^{m+1}## because ##CP^ {m+1}## is homeomorphic to ##CP^{m}## with a ##2(m+1)## dimensional ball attached via the projection of ##S^{2m+1}## onto ##CP^{m}##. I think this makes it homeomorphic to the Thom space of the canonical (tautological) line bundle over ##CP^{m}##.
Likes mathwonk
  • #40
I don't know if this has been mentioned, but (transversal) intersection is Poincare dual to the cup product of homology classes. I think this is true for manifolds. @mathwonk : are there related notions of cup product, Poincare Duality for non-smooth spaces, like some of these Algebraic-Geometric objects with kinks/cusps?
Likes lavinia
  • #41
@WWGD, brilliantly insightful question! answer: YES! It is called intersection (co)homology I believe, and involves "perverse sheaves", but i never learned this theory. I.e. in the case of singular spaces, one restricts which cycles to include in order to still have poincare duality. I believe the original approach, by Clint McCrory in his 1972 Brown PhD thesis, involved stratifications and cycles transverse to certain strata. The theory was later developed by Mark Goresky and Robert Macpherson, and also (fields medalist) Pierre Deligne.
https://www.genealogy.math.ndsu.nodak.edu/id.php?id=5577
https://en.wikipedia.org/wiki/Intersection_homology@lavinia, your interesting post is food for thought...I need time to digest it, and a little research on such things as thom spaces.
Likes WWGD
  • #42
@mathwonk This is the perhaps erroneous thought.
The Thom space of a vector bundle is its 1 point compactification.
With respect to a Riemannian metric on the bundle this is the same as identifying the boundary of the unit ball bundle to a point. Hence the tubular neighborhood idea.
In the case of the Mobius band this is the same as attaching a disk to its boundary circle since the disk is contractible radially to a point. This gives the real projective plane. Similarly one gets ##RP^3## by attaching a 3 ball to the canonical real line bundle over the projective plane. And so on for arbitrary ##n##. Each real projective space looks like the Thom space of the canonical real line bundle over the real projective space of 1 less dimension.
I guess one would map the tubular neighborhood ##T_{m}## in ##CP^{m+1}## onto all of ##CP^{m+1}## by sending its boundary to the center of the attached ##2(m+1)## ball and its interior to all of ##CP^{m+1}## minus this central point - sort of like mapping a closed interval onto the 1 point compactification of the real line..
  • #43
Not quite true : an n- ball can be embedded in ##\mathbb R^n ## without any loss.
