Understanding Electron Flow in EMF Cells: Anode to Cathode or Cathode to Anode?
The discussion focuses on the electron flow in the electrochemical cell Zn | Zn2+ (1M) || Cu2+ (1M) | Cu under varying external potentials (Eext). When Eext is less than 1.1V, electrons flow from the anode to the cathode; when Eext exceeds 1.1V, the flow reverses. However, the correct interpretation is that electrons always flow from the anode to the cathode regardless of the external potential, as defined by the roles of the electrodes. This understanding is crucial for interpreting the behavior of electrochemical cells.
  • Understanding of electrochemical cells and their components
  • Familiarity with oxidation and reduction processes
  • Knowledge of reduction potentials and their significance
  • Basic principles of galvanic/voltaic processes
  • Study the Nernst equation and its application in electrochemical cells
  • Learn about the impact of ion concentration on cell voltage
  • Explore the concept of standard reduction potentials and their tables
  • Investigate the effects of external potential on electrochemical reactions
Chemistry students, electrochemists, and anyone interested in understanding the principles of electron flow in electrochemical cells.
Raghav Gupta
A variable , opposite external potential ## E_{ext} ## is applied to the cell Zn | Zn2+ (1M) || Cu2+ (1M) | Cu, of potential 1.1V . When Eext < 1.1 V and Eext > 1.1V , respectively electrons flow from :
1. anode to cathode and cathode to anode
2. cathode to anode and anode to cathode
3. cathode to anode in both cases
4. anode to cathode in both cases
NA
At anode oxidation happens and at cathode reduction.
So electrons are moving from anode to cathode when Eext < 1.1 V and cathode to anode when Eext > 1.1 V
So option 1 is looking correct.
In answer key option 4 that is anode to cathode in both cases is given.
Why?
My guess is this is almost a "trick" question,
The anode is defined as the electrode where electrons leave a cell and the cathode where electrons enter a cell. So no matter which way the current flows, external to the cell electrons always flow from anode to cathode.
When you switch the battery, you switch the names of the electrodes.
Likes Raghav Gupta
Thanks, got the tricky part.
Look at a table of Reduction Potentials (here's one for quick reference: http://chemunlimited.com/Table of Reduction Potentials.pdf ), in all cases electrons flow from the more negative reduction potential to the more positive reduction potential ... ALWAYS. Choose any two half reactions and note the Eo-values. The more negative value is the anode (site of oxidation) and the more positive value cathode (site of reduction). I might suggest studying how the respective ion concentrations in each half cell affect the voltage of the Galvanic/Voltaic Process. That is, what voltage does the cell have if [reducing agent ion] < [oxidizing agent ions] and visa versa. If [oxidizing agent ions] = [reducing agent ions] what is the cell voltage? Happy charging... :smile:
  • · Replies 19 ·
