Energy and Simple Harmonic Motion - Part II.
The discussion focuses on calculating the speed of an object attached to a spring undergoing simple harmonic motion. The spring is compressed by 0.064 m and oscillates with an angular frequency of 11.5 rad/s. Using the formula for maximum velocity, V(max) = A(ω), the maximum speed is determined to be 0.736 m/s. The final speed at a stretch of 0.037 m is calculated to be 0.601 m/s using the conservation of energy principles and Hooke's Law.
  • Understanding of Hooke's Law and spring constants
  • Knowledge of angular frequency and its relation to simple harmonic motion
  • Familiarity with conservation of energy principles in mechanical systems
  • Ability to perform calculations involving square roots and algebraic manipulation
  • Learn how to derive the spring constant using Hooke's Law
  • Study the relationship between angular frequency and frequency in oscillatory motion
  • Explore energy conservation in different mechanical systems
  • Investigate the effects of damping on simple harmonic motion
Students studying physics, particularly those focusing on mechanics and oscillatory motion, as well as educators looking for practical examples of energy conservation in spring systems.
sailordragonball
A horizontal spring is lying on a frictionless surface. One end of the spring is attached to a wall whle the other end is connected to a movable object. The spring and object are compressed by 0.064 m, released from rest, and subsequently oscillate back and forth with an angular frequency of 11.5 rad/s. What is the speed of the object at the instant when the spring is stretched by 0.037 m relative to its unstrained length?
... I tried using KEo + PEo + SPEo = KEf + PEf + SPEf ... but, I can't get anywhere ...
... I found out that the frequency is 18.05hz and it's relative time is .056 seconds - and that's where I'm stuck!
Use Hooke's law and conservation of energy.
Do I set them equal to each other??
... I don't understand the .64 meter compression part ... does that equal "X" in Hooke's Law and in ?
Hint -- Can you find the value of the spring constant?
BTW -- you are right in that the compression WILL be X in hooke's Law.
I figured it out ...
A = 0.064m (given in the problem)
omega = 11.5 (rad/s) - given in the problem
x = 0.037m (given in the problem)V(max) = A(omega)
V(max) = 0.064(11.5)
V(max) = .736(m/s)
V = V(max) * [the square root of the quantity of (1- {[x^2]/[A^2]})]
V = .736 * [the square root of the quantity of (1- {[0.037^2]/[0.064^2]})]
V = 0.601 (m/s)
10K
