Energy, charge and electric field
The discussion centers on the relationship between electric fields, energy, and charge conservation, particularly in the context of particle creation. It is established that when an electron appears, a corresponding positively charged particle must also be created to maintain charge conservation. The conversation highlights the principles of quantum mechanics, emphasizing that particles exist in a probability cloud rather than fixed positions, and discusses the mechanics of particle accelerators as a relevant analogy. Key references include the Wikipedia articles on charge conservation and pair production.
  • Understanding of electric fields and their associated energy
  • Basic knowledge of quantum mechanics principles
  • Familiarity with particle physics concepts, including charge conservation
  • Knowledge of particle accelerators and their operational principles
  • Study the principles of quantum mechanics and probability clouds in particle behavior
  • Research the concept of charge conservation in particle physics
  • Learn about pair production and its implications in high-energy physics
  • Explore the operational mechanics of particle accelerators and their role in particle creation
Students of physics, particularly those interested in quantum mechanics and particle physics, as well as educators and researchers looking to deepen their understanding of electric fields and charge conservation.
GAURAV DADWAL
Hi there,
Im familiar with the concept that electric field has associated energy with it
Now if in space an electron apppeared at some instant t=0 then electric field will not be established instantaneously but will propagate at speed of light through space
As electric field is bieng established energy associated with it is changing with time
Now what is causing that change in energy although there is no change in charge placed there and no other interaction are seeming to be there to cause change in energy .pls help me understand this .
Any help will be appreciated
The problem is that you created an unphysical scenario (if I understand it correctly, your wording is very confusing). Charges don't just appear magically in place, they need to be transported in from somewhere else. That is, your scenario directly violates the conservation of energy, but your question is exactly about that aspect, the total energy.
In high school we are taught about decay of neutron into proton and electron with antineutrino .
I have just passed high school so i am not having enough knowledge but still i think that in this process proton and electon are generated instantaneously in the space which initially was having no charge particles and also i think these are not generated at same place .
So i think my question makes some sense
While particles can indeed be created out of energy, the total sum of charge however is conserved, just like energy:
https://en.m.wikipedia.org/wiki/Charge_conservation
So, you can't just create an electron from energy, there *has* to be a positive charged particle created at the same time to keep the total sum the same.
, there *has* to be a positive charged particle created at the same time to keep the total sum the same.[/QUOTE]
Is that positively charged particle has to be formed at the same position as that of electron?
Yes.
I didn't get that ??
How can electon and proton be at same position at same time
They are only in the same spot for an infinitesimal small amount of time, since they are flying away from each other. Look into how particle accelerators work, that's really the same principle.
Also, IIRC you can't create an electron and a proton on their own. I believe the latter would have to be a positron (i.e. an anti-electron)
Why are they flying apart as attractive force between them will be infinite when they are at same position
When it comes to these things, you can't look at it from a classical, static point of view. This is quantum mechanics, where particles aren't exactly in one spot but rather exist in a cloud of probability, and they also often have a large kinetic energy.
https://en.wikipedia.org/wiki/Pair_production
It's the same principle with how particle accelerators work :wink:
  • · Replies 21 ·
  • · Replies 22 ·
  • · Replies 22 ·
  • · Replies 16 ·
