Energy Consumed while charging a mobile phone
The energy consumed while charging a mobile phone can be estimated using the charger's specifications. For a charger rated at 100-240 VAC and 0.15A, the energy consumption is approximately 18 Watts or 0.018 kWh per hour. Considering a 20% loss in the charging cycle and inefficiencies in the charger, the total energy required to charge a typical cell phone battery, which stores about 50,000 Joules, can reach around 100,000 Joules or 0.03 kWh. This results in an estimated cost of about 0.3 cents at a rate of 10 cents per kWh.
  • Understanding of electrical power calculations (Watts, Joules, kWh)
  • Familiarity with battery specifications (amp-hours, voltage)
  • Knowledge of charger efficiency and loss factors
  • Basic concepts of charging cycles in lithium-ion batteries
  • Research the efficiency ratings of various mobile phone chargers
  • Learn about the charging characteristics of lithium-ion batteries
  • Investigate methods for measuring current during a charge cycle
  • Explore the impact of different wall wart designs on energy loss
Mobile phone manufacturers, electrical engineers, energy efficiency analysts, and anyone interested in optimizing mobile device charging processes.
Simon Goster
The Rating on my Mobile Phone Charger is:
Input : 100 - 240 VAC
50-60 Hz 0.15A
Output : 5.0V ⎓ 1.0A
How will we determine the energy consumed by the charger in T Hrs?
This will be very inexact because rated values are not actual values. By comparison, your car could be rated to drive at 120 mph, but that has nothing to to with speeds you actually drive.
120V * 0.15 A = 18 Watts, or 0.018 kWh of energy per hour, or 64,800 joules of energy per hour.
Edit: That does not include energy used in the grid supply chain.
A rule of thumb is 20% loss in the charge cycle of a battery. That doesn't count inefficiencies in the charger, etc.
I would guess a very rough estimate of twice the rating of the battery for a modern charger during active charging. (As opposed to sitting there not charging, but plugged in.)
I think Jeff Rosenbury is on the right track. A typical cell phone battery stores about 4 amp-hours at 3.6V = 4.0 * 3.6 * 3600 = about 50,000 Joules. Assuming half the energy is lost during charging as Jeff Rosenbury suggested brings us up to about 100,000 Joules. This is about 0.03 kWh, and costs about 0.3 cents at 10 cents/kWh.
Never seen a 4000maH cell phone battery. More like 2600 or less is typical.
Depending on the efficiency of the charger in the phone, you need to
1. put energy into the battery
2. deal with the efficiency of the charger circuit in the phone
3. Run the processor, etc. (maybe)
4. Deal with the efficiency of the wall wart.
Most are probably switchers, so that run in the area of 10-20% lost.
Only way you will ever know for sure is to record the current into the phone during a charge cycle at the wall wart input.
Here is a charge cycle for an 1800 maH battery. You can see the constant current phase followed by the constant current phase.
This is just how the battery itself behaves when charged by a charger. (this happens to use 900ma. The next phone might use 400ma. depends on the phone)
9K
  • · Replies 19 ·
  • · Replies 41 ·
9K
  • · Replies 31 ·
