Energy, current and electrical potential of a particle accelerator 🎆
The discussion revolves around calculations related to energy, current, and electrical potential in the context of a particle accelerator, specifically focusing on the Large Hadron Collider (LHC). Participants are examining the relationships between voltage, charge, and energy, as well as the implications of these calculations for understanding particle bunches and their behavior in accelerators.
  • Mixed
  • Participants explore the relationship between voltage and energy, questioning the calculations of charge based on the number of particles and their individual charge. There is discussion about the average current and the correct use of time intervals in calculations. Some participants express confusion about unit consistency and the implications of their calculations.
There is ongoing dialogue about the correctness of various calculations, particularly regarding the charge of a bunch of protons and the energy associated with it. Some participants have provided guidance on ensuring unit consistency, while others are still seeking clarification on their previous answers and calculations.
Participants are working under the constraints of a homework assignment, which requires careful attention to detail in calculations and unit usage. There is an emphasis on understanding the physical principles behind the calculations rather than simply arriving at numerical answers.
  • #31
mfb said:
Correct. This is your answer here, everything else that follows is a mess that isn't leading anywhere.
No. As you determined literally one line before, the current is 0.7 A.How can 25 times 10-9 be smaller than 10-9?ns/ns wouldn't be per second, so that's again having wrong units. If one bunch come every 25 ns, then how can there be less than one bunch per second?
Ampere per second would be a change of current over time, but the current does not change.
You need to check your answers if they can make sense.
Sorry I think that I had confused myself.
iii. " If one bunch reaches the collision point every 25 ns, what is the average electric current, in Amps, due to these arriving bunches?"
I understand how as you stated previously when you multiply a charge by something per second the product is not a charge but rather a current.
So to answer part iii.
Find how many bunches reach the collision point in one second;
1 second = 1000000000 ns
1000000000ns/25ns= 40000000 = 4.0*10^7 bunches per second
Charge = 1.8423*10^-8 C
Average current = (4.0*10^7 bunches/second)*(1.8423*10^-8 C)
Average current = 0.73692 A
However, does this not neglect the formula I=Q/t ?
Should current not be 1.8423*10^-8 C/4.0*10^7 bunches/second=4.61*10^-16 A ?
  • #32
t = 25 ns
Or, equivalently:
1/t = 4.0*107 / s
  • #33
mfb said:
t = 25 ns
Or, equivalently:
1/t = 4.0*107 / s
Thank you for your reply. So I=4.0*10^7/ s * 1.8423*10^-8 C = 0.73692 A
However, sorry to ask again but does this not neglect the formula I=Q/t ?
  • #34
However, sorry to ask again but does this not neglect the formula I=Q/t ? No.
Should current not be 1.8423*10^-8 C/4.0*10^7 bunches/second=4.61*10^-16 A ? No also.
Each bunch has a charge of 1.8423×10−8 C and a bunch reaches the collision point in 25ns.
Yes the average, I, is given by I = Q/t . If you want that to be in units of Amps, you need charge to be in Coulombs and time to be in seconds, or some equivalent but strange combination, such as having charge in units of nano-Coulombs and time in nano-seconds. I would convert the 25ns to seconds.
So you could say I = (1.8423×10−8 C) / (25×10−9 s) = 0.73692 A .
Alternatively, you can find the total amount of charge reaching the collision point in some other period of time and divide that charge by that time. Essentially, this is what you did - well, what you sort of did - using a time of 1 second. To do this strictly, you have that in 1 second, 4.0×107 bunches reach the collision point. They represent a total charge of 0.73692 C. In this case Q is 0.73692 C and t is 1 s.
By your first calculation quoted in this post, you found the current by multiplying the two following quantities:
"bunches per second" and "Coulombs per bunch". Yes, multiplying these does give the desired current. However, it is not strictly by using I = Q/t .
  • #35
You ignored my post (that you quoted) completely.
4.0*10^7 bunches/second is not the time. It's the inverse of the time. 25 ns is the time.
  • · Replies 23 ·
  • · Replies 22 ·
