Energy<>Mass conversion
  1. Jul 22, 2007 #1
    Can energy be converted to mass as per the E=mc^2 equation? Theoretically, how to convert energy to mass? Does it happen anywhere in the universe?
    Another related question, why do we need to do nuclear fission or fusion to convert the mass to energy? Does physics have an explanation why mass and energy are not freely interchangable?
  3. Jul 22, 2007 #2
    Yes. Most commonly this occurs in particle accelerators. You can take two light particles, e.g., an electron and a positron, accelerate them to high kinetic energies, and collide. The products of such an collision many include much heavier particles, like protons and neutrons.
    The conversions mass->energy and energy->mass occur around us all the time. For example, when light is emitted by an atom, the atom experiences a transition from a high mass state to a low mass state. However the mass differences are normally too small to be visible, because electromagnetic forces are relatively weak. Nuclear forces are much stronger. This is the reason why mass changes and energies released in nuclear reactions are so much higher.
    Eugene.
  4. Jul 22, 2007 #3
    xez
    Yes, it happens all the time in
    matter-antimatter reactions, natural and artificial
    nuclear reactions, ordinary chemical reactions, etc.
    Everywhere there's a change in energy there's a change in
    mass.
    The "binding energy" of nucleons is converted to mass
    when the nucleons disassemble from the nucleus.
    Energy itself, via the equivalence relationship, has
    mass, so in some senses there isn't a distinction except
    when you specify the form and type of energy --
    rest mass of particles, energy contained in rest-massless
    particles like photons, potential energy of bound nucleons,
    chemical bond energy, energy in gravitational fields,
    energy in electromagnetic fields, etc.
    So you don't "need" a particular kind of reaction
    (nuclear or antimatter) to convert mass to energy, but
    to convery substantial amounts of one to the other
    quickly, those are noteworthy possibilities.
  5. Jul 22, 2007 #4
    xez
    As to why they're not "freely" interchanged, well they
    are, to a point.
    As you study particle physics, quantum physics, chemistry,
    et. al. you learn that there are specific possible reactions
    or transitions, emissions, absorbtions, conversions,
    et. al. that can occur.
    There are also specific states or events that can be
    observed to exist, for instance, there's a possibility that
    an electron positron pair can materialize from the
    vacuum field and exist for a while, then come together
    and annihilate into high energy photons. Energy
    shifts from field energy to mass energy back to field energy.
    There can be assigned specific probabilities that such
    conversions/events/transitions will occur depending on
    the involved energies, momenta, fields, temperature,
    et. al.
    Sometimes such events are highly probably and occur
    frequently, such as the explosion of a firecracker in a
    fire, or the melting of an ice cube on a hot day.
    Other times such events are improbable to occur at
    low temperatures / energies, such as the break-up of an
    iron nucleus into individual nucleons, or a piece of rock
    catching fire on a cold day spontaneously. It's *possible*,
    but very unlikely without a lot of added energy to help
    the process occur.
    It's like the reaction probability and rate and equilibrium
    in chemistry, and also it's similar to the consideration
    of the activation energy of a process -- without the right
    energy input, even a process that will release a lot of
    energy may be unlikely to occur. Thus the stored energy
    in a firecracker takes added heat/energy in the form
    of lighting the fuse before it'll become released with any
    likelihood.
    So you can say that the probability of a system *not*
    undergoing a given conversion between mass/energy
    is a measure of its stability.
    In just a few minutes free neutrons will probably
    'spontaneously' convert (decay) into a proton, electron,
    and added energy. Whereas a neutron inside a nucleus
    is usually quite stable and will probably stay there without
    decay for a long time in most (non-radioactive) nuclei.
    In contrast a free proton at normal energies will
    probably not decay or change into anything else even if
    you waited billions of years.
    If bound neutrons or protons were *not* so stable, we'd
    not be here discussing this topic now, because billions of
    years ago all the normal matter that makes up our
    bodies / planet / solar system / galaxy would have decayed
    into other kinds of matter/energy and we'd never have
    existed.
    So the reason the mass and energy doesn't seem so
    freely interchangable is that the universe we're familiar
    with in ordinary conditions is a 'cold' fairly low-energy
    place where in ordinary circumstances on earth matter
    is stable in the chemical and atomic states it exists in,
    and large scale changes of energy/mass do not occur due
    to the stability of matter at low temperatures/energies.
    Were that not the case, the planet would've "burned up"
    and we (being fragile creatures that can live only in
    very delicately balanced environmental conditions)
    wouldn't exist.
  6. Jul 22, 2007 #5
    xez
    Whereas at the beginning stages of the universe things
    were at very high energies and temperatures, and
    there was a large scale shift of kinds of particles,
    photons, etc. back and forth to various other kinds of
    energies/particles. As the universe cooled, normal
    matter like the protons/neutrons/photons/electrons
    that make up most of the universe today came into
    existance and their stability increased so
    that interconversions became less and less likely in most
    places other than inside stars or similar high energy
    high temperature places.
  7. Aug 23, 2007 #6
    i have heard that E=mc^2 has some defalts in some situations.is it true and how?
  8. Aug 23, 2007 #7
    Danger
    I've never heard of that. Can you cite a source? As far as I know, it's an immutable formula. It is very seldom, however, that full conversion is achieved. An H-bomb, for instance, converts only about 1% of the mass to energy. Perhaps it's an efficiency issue that you're thinking of?
  9. Aug 23, 2007 #8
    Any physical process that occurs must satisfy a whole slew of conservation laws. These are what allow certain states to be stable, and what prevents large-scale mass => energy conversion from being too common.
    All known processes obey the conservation of: energy, momentum, angular momentum, electric charge, color charge, baryon number, and lepton number (and quark and lepton flavors are mostly, but not always, conserved as well); although it is generally accepted that baryon and lepton numbers should not be conserved at higher energies than we've been able to probe.
    The application of these conservation laws is actually sufficient to predict exactly what kinds of interactions can occur and what cannot. For example, the conservation of electric and color charges, together with baryon and lepton numbers suggests that a proton might be able to decay into a neutron a positron and an electron neutrino. However, energy conservation will not allow it, as the mass of a neutron is larger than that of a proton.
  10. Aug 23, 2007 #9
    Energy is always equivalent to relativistic mass, but for moving particles it is more common to express energy in terms of rest mass, in which context this formula is just a special (stationary) case.
  11. Aug 23, 2007 #10
    well, its possible to change an objects rest mass isn't it...
  12. Jan 30, 2010 #11
    Reading some of the responses to energy mass conversion question, has prompted me to ask the experts in this forum the following question:
    What would be the length of time that visible light would be emitting from a very efficient process of converting enough energy into a body of mass of 6.0×(10 to the 24th power) KG ?
