Energy of a Dipole in a Constant E Field
The discussion focuses on calculating the mechanical and kinetic energy of an electric dipole in a constant electric field, specifically when oscillating between plus and minus 65 degrees. The potential energy (U) is defined by the equation U = -pEcosθ, where p is the dipole moment and E is the electric field strength. At 180 degrees, the potential energy is given as 2 μJ, which allows for the calculation of pE. The kinetic energy is maximized when the dipole is aligned with the electric field (θ = 0).
  • Understanding of electric dipoles and their behavior in electric fields
  • Familiarity with the equation for potential energy of a dipole (U = -pEcosθ)
  • Knowledge of mechanical energy concepts in physics
  • Basic trigonometry to calculate energy at different angles
  • Calculate the dipole moment (p) using the given potential energy at 180 degrees
  • Explore the relationship between potential energy and kinetic energy in oscillating systems
  • Investigate the effects of varying angles on the potential energy of dipoles
  • Learn about the dynamics of dipoles in non-uniform electric fields
Students studying electromagnetism, physics educators, and anyone interested in the mechanics of electric dipoles in electric fields.
saxyliz
The graph shows the potential energy of an electric dipole which is in a constant electric field; only the electric force is acting on the dipole. Consider a dipole that oscillates between plus and minus 65 degrees.
a) What is the dipole's mechanical energy?
b) What is the dipole's kinetic energy when it is aligned with the electric field?
U = -pEcos\theta
I know that when the graph is at the trough it's -pE and at it's peak it's +pE. But I don't know how to factor in the 65 degrees. Please help!
At 180 degrees U = 2 μJ. Substitute in the relevant equation and find pE.
At θ = 0, all the potential energy in converted to K.E. Similarly you can find P.E. at 65 degrees by substituting the value of pE and θ in the equation.
Thank you so much! That really cleared it up for me!
  • · Replies 20 ·
  • · Replies 30 ·
15K
