How Much Energy Is Required to Elevate a Satellite to 1800 km Altitude?
  • Thread starter Thread starter rdn98
    Energy Satellite
The energy required to elevate a 1700 kg satellite to an altitude of 1800 km involves calculating both potential and kinetic energies. The correct formula for total energy is given by the equation -GMm/r + 0.5mv², where r is the sum of the Earth's radius and the altitude. It is crucial to note that total energy is zero on an escape trajectory, indicating that any bound orbit will yield a negative energy value. For this specific problem, only the potential energy to reach the altitude should be considered, excluding kinetic energy associated with orbital motion.
  • Understanding of gravitational potential energy and kinetic energy concepts
  • Familiarity with the Vis-Viva equation for orbital mechanics
  • Knowledge of gravitational parameters, specifically G and M
  • Basic understanding of circular orbits and escape trajectories
  • Study the Vis-Viva equation in detail to understand its applications in orbital mechanics
  • Learn about gravitational parameters and how to calculate them for different celestial bodies
  • Explore the differences between potential energy and kinetic energy in the context of satellite motion
  • Investigate the implications of escape velocity and its significance in satellite launches
Aerospace engineers, physics students, and anyone involved in satellite design or orbital mechanics will benefit from this discussion.
rdn98
A 1700 kg satellite is orbitting the Earth in a circular orbit with an altitude of 1800 km.
a) How much energy does it take just to get it to this altitude?
Ok, I just need help getting the setup on this first part.
The amount of energy need to get to this altitude would the sum of the initial potential and kinetic energies, right?
So -GMm/r + .5mv^2 = total energy?
where r= Radius of Earth + altiude (m)
I can figure out the velocity using escape velocity equation, but I get this big negative answer. Thats not right, so what's the right way to do this?
This is correct.
By definition, total energy is zero if you are on an escape trajectory. That means that any bound orbit will have a negative energy.
To find the velocity, use the Vis-Viva equation, which relates energy, velocity, semi-major axis and orbital distance (and the escape velocity is drawn from the equation as well)
<br /> <br /> \epsilon = \frac{V^2}{r}-\frac{\mu}{r}=-\frac{\mu}{2a}<br /> <br />
Where \epsilon is total energy
\mu is the gravitational parameter, G*M
r is the distance from the earth
and a is the semi-major axis of the orbit (r for circular, infinity for parabolic or escape velocity)
But the original problem said "just to get it to this altitude". My guess would be that you should not take into account the kinetic energy of moving in orbit. "Just to get it to this altitude" would seem to me to be the energy necessary to get up to that altitude, not to be in orbit at that altituded.
12K
