Energy Problem Involving Spring Force
1 reply · 6K views · last reply
angotta
1. As a 1.7×104 jet plane lands on an aircraft carrier, its tail hook snags a cable to slow it down. The cable is attached to a spring with spring constant 6.0×104 . If the spring stretches 31 to stop the plane, what was the plane's landing speed? (Answer in m/s)
2. Homework Equations
Fsp=k[tex]\Delta[/tex]s where k is the spring constant and [tex]\Delta[/tex]s is the change in position.
Also possibly the Equation for kinetic energy
K=1/2mv2
And also posibly
vf2=v i2+2a[tex]\Delta[/tex]s
where v is velocity and a is acceleration
Also the conservation of energy and momentum equations are possible along with f=ma
I found the spring force to be 1860000 N and then I lost where to go exactly. I tried to use F=ma to find acceleration, and then use kinematics (vf2=v i2+2a[tex]\Delta[/tex]s) because v final should be zero, but I got the wrong answer. My incorrect answer was 82m/s.
Maybe consider using the KE and PE of spring?
1/2*m*v2 = 1/2*k*x2
v2 = k*x2/m = 60,000*312/17,000
