Energy required to bring 1 kg 1000 meter above the surface of the Earth
The discussion revolves around calculating the energy required to elevate a mass of 1 kg to a height of 1000 meters above the Earth's surface. It touches on concepts of gravitational potential energy and the importance of understanding underlying principles versus relying on calculators.
  • Homework-related
  • One participant inquires about the method to calculate the energy needed for the elevation of 1 kg.
  • Another participant suggests looking up "gravitational potential energy" and mentions the need to consider the difference in potential energy at two distances from the Earth's center.
  • Several participants reference a specific online calculator for gravitational potential energy, indicating a preference for quick solutions.
  • One participant expresses concern about relying on calculators, emphasizing the importance of memorizing basic principles and understanding how to apply them to various problems.
  • Anecdotal evidence is shared regarding the necessity of knowledge during examinations, highlighting the potential pitfalls of not being able to recall information without external aids.
Participants exhibit a mix of perspectives, with some advocating for the use of calculators while others stress the importance of understanding the concepts and memorization. There is no consensus on the best approach to learning or problem-solving in this context.
Some participants imply that there are foundational principles that should be memorized, while others suggest that using tools like calculators is acceptable. The discussion does not resolve the tension between these viewpoints.
Mikael17
How can i calculate the Energy required to bring 1 kg 1000 meter above the surface of the earth ?
Look up "gravitational potential energy". You need the difference in its value for a 1000kg mass at the two distances from the center of the Earth.
I had a friend and colleague who was asked a question he didn't know on an oral exam.
Him: "Well, I know where to look it up if I ever need it."
Prof: "But you need it now."
  • Haha
In either case this one is so easy/basic you really should be able to memorize it, plus knowing how it works you can deconstruct, rearrange and apply it to other kinds of energy/problems.
Mikael17 said:
There are formulae and there are basic principles which can often be expressed by formulae. To understand and know a basic principle it is necessary for you to be able to put names (words) to the basic symbols that a shorthand formula tells you.
Do you carry and use a map / gps with you when you go to work every morning or do you actually learn the route? Your brain is a great learning device - give it a chance.
  • · Replies 28 ·
  • · Replies 138 ·
9K
  • · Replies 20 ·
