Energy Required To Knock Something Over
  • Thread starter Thread starter sjd0004
    Energy
The discussion revolves around determining the force required to knock a can over, focusing on concepts of equilibrium and gravitational potential energy. Participants explore the physical principles involved in tipping an object and the calculations necessary to quantify the energy involved.
  • Participants discuss the need to find the difference in energy between the can's stable position and the tipping point. There are inquiries about the relationship between distance, force, and work, as well as the application of conservation of energy principles.
The conversation includes attempts to clarify the method for calculating the gravitational potential energy difference and how it relates to the force needed to tip the can. Some participants have drawn diagrams to visualize the problem, while others have confirmed the use of mass, gravity, and height in their calculations.
Participants are working under the assumption that they need to calculate the energy based on the center of gravity of the can, and there is an acknowledgment of the complexities involved in the calculations.
sjd0004
I need to figure out how much force it would take to knock a can over.
As of now, I have no clue where to even start with this.
I was told by a friend that the way to solve it is by finding the difference between the value at equilibrium and the value when the can is just about to tip. Unfortunately, I have no idea how to do this.
Draw a diagram showing a can standing in a stable position. Locate its center of gravity. Now draw the can in a position where it's tipped so it's just balanced and could go either way...fall over or return to its stable position. Where's the center of gravity in that case?
Okay, I have the diagram drawn. Would I just do the distance between the two points x the force required to get it there? I believe that the formula for work which is equal to energy would be distance * force?
You could do that, but it could involve a fair amount of effort to sort out the math (the force will be changing direction over the distance it's applied). It would be much simpler to apply conservation of energy. In particular, find the change in gravitational potential energy between the two positions of the center of mass.
Once the gravitational potential energy difference is found, would the difference of them be the total needed to tip the can?
Yes.
Thank you. One more question though to make sure I have it down. I know that the gpe would be mass*gravity*height. So for the cans would I use the mass of the can*9.8*center of gravity height?
Right. You use the height of the center of mass of the object to determine the overall GPE for it. While some parts of the object are higher and some are lower (and thus individually have higher or lower GPE's), the sum of the GPE over the whole object will be the same as though all the mass happened to be located at the center of mass.
  • · Replies 32 ·
  • · Replies 33 ·
  • · Replies 37 ·
