Energy & Spring: Rejuvenate Your Life
The discussion revolves around the application of Hooke's law and energy conservation principles in a physics problem related to springs and energy. Participants are exploring when to appropriately use these concepts in problem-solving.
  • Participants express confusion about the conditions under which to apply Hooke's law versus energy equations. There are attempts to clarify the relationship between forces and energy conservation, particularly in scenarios involving zero acceleration and zero velocity.
Some participants have provided insights into the use of conservation laws and the importance of showing work to facilitate understanding. There is an acknowledgment of the interconnectedness of the problems being discussed, though explicit consensus on the best approach has not been reached.
Participants are encouraged to adhere to homework guidelines regarding the submission of work, and there is a noted emphasis on the relationship between the two problems being addressed.
NickStar
In two cases two weights are tied using a string, and one of them is also tied to a spring(k=50N/m). Two weights are released when the spring is not compressed.
1) What is the maximum strain of the spring
2) What is the speed of the weight which is tied to the spring when the strain is 10cm
I need to solve this for two cases
I solved the first one using energy laws(but I couldn't solve this using Hooke's Law and I didn't understand why) if you could solve the first one using Hooke's Law, I would be really thankful)
And I have no clue how to solve the second one
Everything there is written in Hebrew
K=1/2kx^2
deltaE=W
Why would you use Hooke’s law? Is the problem asking you explicitly to use Hooke’s law? Please also show your solution to 1 using energy laws.
No, it's not. But I just can't understand when do we have to use Hooke’s law and when energy equations. And the most important is the second part(with speed) (I can't even get something close to the right answer)
Generally, it is going to be easier to use conservation laws whenever you can get away with it.
Please type out your attempts (with your steps explained) instead of attaching rotated images of questionable quality. (See the homework guidelines)
I solved the first one so It doesn't really matter. But I really need to solve the second one(I have no clue how to do it) Here is my attempt:
Mostly, you want to use forces when the situation of interest is zero acceleration. That means forces are in balance.
When the situation is zero velocity, as here when the spring is under maximum strain, energy conservation is useful because you know the KE is zero.
Energy is also useful for the second part because you want to find a velocity, not an acceleration.
This is not a constructive answer. In order to guide you to be able to solve the second, you need to show us how you have solved the first because (obviously) they are related to each other as they relate to the same system and the considerations necessary are very much alike. When we ask you to provide something, it is for your own benefit and for us to be able to help you better, please keep this in mind.
  • · Replies 58 ·
  • · Replies 20 ·
  • · Replies 17 ·
