How Much Energy Is Needed to Drag a Block Over a Distance?
The energy required to drag a block over a distance L is determined by the coefficient of friction (μ) between the block and the floor, and the mass (m) of the block. The frictional force opposing the movement is calculated as Fr = μmg. To maintain constant speed, the net force must equal the frictional force, leading to the equation for energy: E = m(a - μg)L. This discussion clarifies that the energy required is equivalent to the work done against friction, not the change in kinetic energy.
  • Understanding of Newton's laws of motion
  • Familiarity with the concept of friction and the coefficient of friction (μ)
  • Basic knowledge of work-energy principles
  • Ability to manipulate algebraic equations
  • Study the relationship between friction and motion in physics
  • Learn about work-energy theorem applications in real-world scenarios
  • Explore advanced topics in dynamics, such as acceleration and force analysis
  • Investigate the effects of different surface materials on friction coefficients
Students in physics or engineering courses, educators teaching mechanics, and anyone interested in understanding the principles of work and energy in relation to friction and motion.
indie452
whats the energy required to drag a block a distance L
coefficiant of friction between block and floor = \mu
density of block = p
force*distance = change in kinetic energy
friction acting against movement Fr = \mumg m = mass of block
force in direction of movement F = ma
resultant force = F - Fr = m(a-\mug)
resultant force*L = energy = m(a-\mug)L
i don't think the last step is right though as I am not sure sure that the assumption made that energy required is the same as the change in KE is correct...
help or guidance appreciated
Although not stated as such, I think you are looking for the energy (work) required by a person or machine to just overcome friction and move the block at constant speed (no acceleration).
  • · Replies 24 ·
  • · Replies 45 ·
  • · Replies 18 ·
