Entanglement swapping, monogamy, and realism
  • Context: Undergrad
  • Thread starter Thread starter kurt101
    Entanglement Realism
This discussion centers on the concepts of entanglement swapping, monogamy of entanglement, and their implications for realistic interpretations of quantum mechanics. Participants explore the compatibility of these concepts with cause and effect, as well as the implications of measurement order in entangled systems.
  • Some participants argue that the entanglement swapping experiment is compatible with realistic interpretations that respect cause and effect, referencing a specific paper on the topic.
  • Others contend that any interpretation preserving cause and effect must address the issue of measurement order, as the observed behavior remains unchanged regardless of this order.
  • One participant questions the practical testability of the monogamy of entanglement, suggesting that measuring entangled photons alters their state, potentially making the concept untestable in a realistic sense.
  • Another participant asserts that in the case where the BSM test is conducted after measurements of 1 and 4, entanglement only occurs post-measurement, challenging the notion that 1 and 4 were entangled throughout.
  • Some participants express skepticism about the lack of alternative explanations for the entanglement of 1 and 4 if not due to the BSM measurement.
  • There is a discussion on the implications of realistic interpretations being compatible with cause and effect but not with locality, raising questions about time ordering and its effects on entanglement.
  • One participant introduces the idea that in certain quantum field theories, fundamental degrees of freedom remain even when particles are destroyed, suggesting a potential avenue for realist interpretations.
  • Concerns are raised about the implications of nonlocal realistic theories that maintain time ordering while violating Lorentz covariance.
Participants express multiple competing views regarding the relationship between entanglement, measurement order, and realistic interpretations. There is no consensus on the implications of the BSM test timing or the validity of the monogamy argument in this context.
Participants note limitations in the definitions and interpretations of entanglement and monogamy, as well as the unresolved nature of the arguments surrounding cause and effect realism in the context of measurement order.
  • #61
Nullstein said:
I'm not treating anything differently.
In the particular math you go on to quote, you're not--but only because you're ignoring the result of the BSM and just looking at the full ensemble. But you also agree that that full ensemble, in the case of 2&3, is a mixture of entangled subensembles. Are you then claming that, once we know that in a particular subensemble, 2&3 are in a particular maximally entangled state (the one indicated by the result of the BSM in that subensemble), that doesn't tell us that the BSM had an actual physical effect on 2&3?
  • #62
Nullstein said:
then you are subject to Berkson's fallacy
So you say. But you have not proven it.
Nullstein said:
I haven't seen you or DrChinese address this argument so far.
It's not up to us to disprove that Berkson's fallacy is in fact the correct explanation for the entangled 1&4 subensembles. It's up to you to prove it if you are going to assert it. Saying that it is possible (because of general heuristics about correlations not necessarily showing causation) is not the same as proving it in this particular case. In all of the other cases you cited in previous threads, Berkson's fallacy was proven by looking at additional relevant data that ruled out actual causal effects. You need to do that for the case under discussion if you want to assert that that is the correct explanation.
  • #63
PeterDonis said:
What you quoted from me only says that, whatever interpretation we adopt, it should be the same regardless of the time ordering of the 2&3 vs. 1&4 measurements, since both the observed results and the QM math are the same in both cases. But that, in itself, does not tell us which intepretation to adopt. Both the interpretation @DrChinese and I are using, and the intepretation @Nullstein is using, are independent of the time ordering of the measurements. So pointing out that the interpretation should be independent of the time ordering of the measurements does not give any way of choosing between those two positions. Which means it doesn't give any argument either way about whether or not the BSM on 2&3 has an actual physical effect on 1&4.
The experimental fact is that the already recorded (14) results never change. It's not simply an issue of time ordering. The (14) results will be the same even if the (23) measurement is never done. If the results do not change, there is no physical effect. It doesn't matter what interpretation you use. This is the experimental fact I was referring to and it has nothing to do with interpretation.
  • #64
Nullstein said:
Well, but then you are subject to Berkson's fallacy and I haven't seen you or DrChinese address this argument so far.
Are you saying that Berkson's fallacy is (potentially) applicable to correlations resulting from all examples of entanglement and hence that one can not draw conclusions about causality from entanglement in general?
Or just the entangled 1&4 sub-ensemble in this case? That would be odd as entanglement should be a fungible resource.
  • #65
DrChinese said:
1. No! We (@vanhees71, @PeterDonis and many others) have previously established as follows (in another thread you were in):
You don't understand what has been established, because you don't understand the difference between the full ensemble and the subensembles. I will try to explain it once more.
DrChinese said:
b. The final quantum state is a Product State of 2 entangled pairs:$$\hat{\rho}'=\hat{\rho}_{23} \otimes \hat{\rho}_{14}.$$
That depends on whether we talking about the full ensemble or the subensembles. What you have written here is the state of a subensemble after the BSM. The state of the full ensemble after the BSM is not of that form.
DrChinese said:
c. And it should be obvious that: $$\hat{\rho}_{12} \otimes \hat{\rho}_{34} ≠ \hat{\rho}_{23} \otimes \hat{\rho}_{14}.$$
You are comparing a full ensemble (before) with a subensemble (after). This makes no sense at all.
  • #66
That's true of every experimental result. It tells you nothing special about any particular experiment.
Here you are making assertions without evidence. Since the (23) measurement was done in the actual experiment, you cannot use that experiment as evidence about what would happen if the (23) measurement were not done.
You can assert that the statistics of the full ensemble of (14) measurements, taken in isolation, would be the same whether the (23) measurement was done or not, as a prediction of QM. But that prediction is only about statistics; it says nothing about the actual results of individual runs.
  • #67
No, he isn't. By construction, the "before" state of any subensemble of runs is the same as that of the full ensemble, because the preparation process is identical for every single run.
  • #68
The BSM is responsible for the transitions ##\rho_{i_1,\ldots,i_n,\text{before}}\rightarrow\rho_{i_1,\ldots,i_n,\text{after}}##. The selection of subensembles is not a physical process. It happens long after the measurement results have become manifest and is performed by the experimenter on his computer when he analyzes the recorded data. Physical cause and effect relationships must be inferred from the evolution of the full ensembles.
  • #69
Well, I have provided a citation to a paper by Spekkens, where it is proved very concretely for the swapping situation. (I found that recently, so you may not have seen it yet.) In any case, the argument is that the measurement result at 2&3 is influenced by the preparation of 2 and 3, so it is a common effect and thus Berkson's effect applies.
If you are confronted with a proof, it is up to you to point out an error in the proof though.
I'm not saying it is the correct explanation. I'm saying it is one viable explanation and thus a knowledge-based interpretation is viable. An interpretation with non-local cause and effect relationships is of course viable too, but not required.
  • #70
No, it is only applicable if conclusions are to be drawn from the correlations in subensembles. Entanglement produced by, e.g., parametric down-conversion occurs in the full ensemble and is genuinely mysterious.
  • #71
Even if you take a subensemble of the initial full ensemble, then DrChinese's state after the BSM would be a subensemble of that subensemble, so they still can't be compared.
  • #72
Not if you take the subensemble of runs where the BSM gives an "event ready" signal. That is precisely the same subensemble that is used to ground the claim of entanglement swapping, since for that subensemble 1&4 are maximally entangled.
  • #73
In the evolution of the full ensemble, 2&3 are not entangled. Does that mean the BSM has no causal effect on anything?
  • #74
The experimental results at (14) are available before the (23) measurement. Those results do not change after the (23) measurement. Therefore the (23) measurement does not affect the (14) results. The fact that the results are the same before and after the (23) measurement is direct experimental evidence that the (23) measurement has absolutely no effect on the (14) results. Are you really arguing the contrary?
On the contrary, we have evidence from that experiment. The moment when the (14) measurement is complete and the results recorded but the (23) measurement is yet to be done. Those (14) results are exactly the same results as those after the (23) measurements are done. That is direct evidence that the results would not have changed if the (23) measurements were never done. That is direct evidence that the (23) measurement has no effect on the (14) results.
No, this is not the assertion. We are not simply talking of a different experiment showing similar statistics. We are talking about the same data already recorded, for every single particle pair, and not one of those results changed as a result of the (23) measurement done later. Therefore the (23) measurement had no effect on the (14) results. This is an experimental fact.
  • #75
Nullstein said:
There is no entanglement between 1&4 before the BSM and there is no entanglement between 1&4 after the BSM.
Show me a Quantum mechanical process that allow you two pick a sub ensemble of entangle pair, in a full set of non-entangled pair, with %100 certitude.
Nullstein said:
False. The 1&4 system is in the state ##\frac 1 4\mathbb 1\otimes\mathbb 1##. Let ##P_i## be projectors onto the Bell basis.
No let's not. Projection are not part of the preparation of state.
Nullstein said:
The completeness relation says that ##\sum_i P_i=\mathbb 1\otimes\mathbb 1##. So we conclude that ##\rho_{14,\text{before}}=\sum_i \frac 1 4 P_i##, i.e. a statistical mixture of 4 entangled states.
You conclude your preparation state from your results ? How convenient ... and backward.
Nullstein said:
Nope, the post-selection is done once the full data is collected.
Nope, post selection happens only at BSM site.
  • #76
So what? The QM math is clear that the time ordering of the measurements makes no difference.
It is no such thing. The (23) measurements are made in both cases, and the QM math says there is no dependence on the time ordering of the measurements, and that prediction is borne out by the results. So that's all the results are telling you.
To get experimental evidence about what happens if a (23) measurement is not done, you need to actually run the experiment with the (23) measurement not being done.
No. The experiment with the (23) measurement done before the (14) measurement, and the experiment with the (23) measurement done after the (14) measurement, are two different experiments. QM predicts that the statistics are the same in both cases, but that doesn't mean you can just do one experiment and claim to have evidence about both--still less about an experiment that is never done at all. To test the QM prediction, you need to do the experiment both ways and compare the results. That is what was actually done.
It is of course impossible to do a single experiment in which the (23) measurement is both before and after the (14) measurement. So we are not talking about "the same data already recorded"--it's not as if we record the (14) measurement after a (23) measurement, and then magically move the same (23) measurement to occur after the same (14) measurement (or the reverse). We are only talking about comparing data from different experiments in which the time ordering of the measurements is different. And of course this does not justify any claims about an experiment that was never done.
  • #77
... or after
Nobody said the results change
Quite the opposite. 2&3 measurement confirmed them. And this would be impossible if 1&4 measurement was just (classic) random. They are "Quantum random" with a different bound impossible to explain locally. And doubly impossible if 1&4 are not entangled at the start.
  • #78
I'm talking about an idealized experiment here. The event-ready scheme is an experimental complication in real world experiments in order to avoid measurement errors. The event ready signal is not produced by the BSM, but at the time of preparation. If the event ready signal occurs, we know that we can expect a properly prepared state. So the subensemble of event ready photons is taken as the ensemble that is being studied. This is fine, but this ensemble is not the subensemble we get from the BSM. The BSM at 2&3 still decomposes this event ready ensemble into the four subensembles that are studied in the idealized setting.
No, there are other subsystems ##\rho_{i_1,\ldots,i_n}## that are influenced by the BSM. The state ##\rho_{1234,\text{after}}## is definitely different from the state ##\rho_{1234,\text{before}}##, so some subsystems are subject to change.
By the way, I'm not even saying that we cannot perform causal inference from subensembles. But there are some well understood principles that need to be taken care of. If correlations remain after controlling for common causes and after summing over common effects, then this is definitely a hint for causality. But in the case of entanglement swapping, certain correlations go away after summing over the common effects.
  • #79
Picking a subensemble is not a quantum mechanical process. It's performed by the experimenter on his computer. But what does that have to do with the fact that the 1&4 subsystem is in the state ##\frac 1 4\mathbb 1\otimes\mathbb 1##, both before and after the BSM?
This sentence is quite meaningless. It's a mathematical fact that the equality ##\frac 1 4\mathbb 1\otimes\mathbb 1 = \sum_i \frac 1 4 P_i## holds. So it is a mathematical fact that the full ensemble at 1&4 is equivalent to a mixed state of Bell states, weighted with the probabilities ##\frac 1 4##.
  • #80
This is wrong. The "event ready" signal is generated by a combination of things: the 2 & 3 photons arriving at the BSM device within the same narrow time window, and the output of the BSM indicating the particular Bell state that the BSM is set up to distinguish. This happens at the BSM, not at the initial preparation. @DrChinese is more familiar than I am with the specific papers describing the experiments, and I'm sure can give specific references to the descriptions in those papers that match the above.
  • #81
I hope people realise that the WolframAlpha file I was sent from one of the co-authors, that presents the calculations of photons 2 and 3 through the Mach-Zehnder interferometer (with various wave plates) in the Zeilinger et al (2012) experiment before a bell-state measurement occurs on them treats those photons as if they were already entangled in a particular bell-state before entering the interferometer. I found that rather strange.
Again, I point to my comments: https://www.physicsforums.com/threa...ing-monogamy-and-realism.1050017/post-6855670
  • #82
This is ok to do if you are careful. The subensemble selected by the projector ##\mathbb 1 \otimes P_i \otimes \mathbb 1## is also selected by a history ##C_i## that projects to a bell state for (23) before the measurement occurs.
  • #83
PeterDonis said:
The "event ready" signal is generated by a combination of things: the 2 & 3 photons arriving at the BSM device within the same narrow time window, and the output of the BSM indicating the particular Bell state that the BSM is set up to detect. This happens at the BSM, not at the initial preparation. @DrChinese is more familiar than I am with the specific papers describing the experiments, and I'm sure can give specific references to the descriptions in those papers that match the above.
Most folks probably don't know some of the details in these experiments, and most of the time they don't matter. Everyone gets the main idea. But as @Nullstein shows us, the devil is sometimes in the details. So allow me to correct a few notions. What I am about to say below is the theoretical case of the perfect experiment, but swapping experiments are quite difficult to execute in practice so they won't work quite like I describe.
Imagine our same scenario, starting off with distant independent sources A and B generating entangled pairs (1 & 2) and (3 & 4) from Type I PDC (both H or both V). These pairs are produced spontaneously and asynchronously, no particular time of creation from either source. The initial quantum state is a Product State of 2 entangled pairs: ##\hat{\rho}=\hat{\rho}_{12} \otimes \hat{\rho}_{34}.## That of course is ONLY true when we have one pair from Source A and one pair from Source B that we choose to discuss as a candidate for a swap. We need to connect two pairs to have a set of 4 to make any sense of the pairs we start with.
What connects these pairs? Is it time of emission? No. Is it time of arrival of the 1 & 4 photons? No. What connects them is the time the 2 & 3 photons cross the Beam Splitter (BS) during the Bell State Measurement (BSM). They must cross within a narrow time window, let's call it 10 nanoseconds to have a number. And they must be indistinguishable as to whether the source was A or B once they pass the BS. So same wavelength, etc. and no other identifying characteristics (cannot be polarized). This is how the pairs from different sources interact, the creation time of the pairs itself is not a factor.
When they come out of the BS they are routed to 2 Polarizing Beam Splitters (PBS) and then to an array of 4 detectors. Some Bell States can be distinguished by this method, but unfortunately not all can. There will always be a percentage of cases that cannot be used for a Bell test on 1 & 4 pairs. However, that does NOT mean they aren't entangled. They are, we just cannot determine how.
For our purposes, let's assume that the 1 & 4 measurement systems (PBS plus 2 detectors for each) are positioned such that when we have a successful BSM, the 1 & 4 detectors go off at the same time (within our designated time window). We add fiber cable to make that work out, and we place them at the same spot. Additionally, we do the same with the BSM detector array. We use fiber to adjust the travel time, and route them to the same location as the 1 & 4 detectors. All 4 photons will arrive at location where all of the detectors are, and the photons will all arrive within the same time window. I am adding this little twist so you can see exactly what should be discussed when we talk about an ensemble or subset or subensemble. So what we expect, with a successful BSM, is that 4 detectors will click at almost precisely the same time. For the 1 & 4 photons, each will generate one click indicating their polarization relative to their respective PBS. The BSM detector array will register 2 clicks, one for the 2 photon and one for the 3 photon - but we won't know which is which. So 4 "simultaneous" clicks means we have a successful BSM in this setup.
Here is where the labeling of ensembles gets confusing. Most everyone assumes we are ignoring numerous sets of clicks. That's not really accurate. We often get a click on the photon 1 detectors and a single click on the BSM detector array, but nothing in the time window for the photon 4 detectors. And we often get a click on the photon 4 detectors and a single click on the BSM detector array, but nothing in the time window for the photon 1 detectors. Since there is no 1 click to match with a 4 click, there is no way to make any sense of the earlier statement ##\hat{\rho}=\hat{\rho}_{12} \otimes \hat{\rho}_{34}.## For me, only cases in which the 1 & 4 photons are detected within the time window should be considered. I would call that the full universe or data set. Note that this definition does not reference whether or not the BSM succeeded.
In theory: for every single case where the 1 & 4 photons are detected within the time window: they are entangled. We may not know which of the 4 Bell states they are in - and therefore we can't perform a Bell test on them - but they ARE entangled. The new state is ##\hat{\rho}=\hat{\rho}_{14} \otimes \hat{\rho}_{23}.## If the experimental setup is perfect, then every single time we have clicks for 1 and 4, we will also have 2 clicks at the BSM array. So once again, every 1 & 4 pair is entangled. Of course, that wouldn't be true if we messed up the BSM setup so that the source was distinguishable (we could do that if we wanted). But assuming we are good scientists, there is no subensemble yet.
The subensemble comes when we ask what kind of entanglement did we get? Each of the 4 Bell states is equally likely, but usually only 2 can be identified. So half the results are thrown out, but of course they were still entangled. So when you talk about the subensemble, it is something quite different than many here are picturing. To me, the subensemble is the group for which we know the specific Bell state. The full data set are the cases in which we have matched clicks for 1 & 4. And in the ideal case, they are all entangled and there are also clicks at the BSM array.
  • #84
[Mentor Note -- @lodbrok has been thread banned]
  • #85
PeterDonis said:
Any interpretation that attempts to preserve "cause and effect" therefore has to argue that, even though the actual behavior is exactly the same, which measurement is the "cause" and which is the "effect" depends on the order in which you do the measurements. Such an interpretation seems strained, to say the least.
I am ok if others think it is strained. I am not ok if others claim it is impossible without a solid argument.
PeterDonis said:
Perhaps you can
If that is the case, then the monogamy argument is not a problem for the cause and effect realistic interpretation that I have brought into this thread.
DrChinese said:
There are no "coincidental" violations of Bell Inequalities.
Maybe we are just using the term "coincidental" differently. See my explanation of how I am using "coincidental" below.
DrChinese said:
  1. Monogamy of Entanglement applies regardless of when the BSM occurs. The timing defies the usual cause and effect relationship/ordering. You cannot reasonably say "The swap occurred at time X". You can only make the statement that "1 was initially entangled to 2, and was later entangled to 4." But at no time was 1 maximally entangled with both 2 and 4, as that defies MoE.
I can live with that explanation for now. Taking your definition, it sounds like this is not a blocker for the cause and effect interpretation I am using to explain the "coincidental" entanglement.
PeterDonis said:
But how do 1 & 4 become entangled? If it isn't the BSM measurement (which you say it isn't in this case), what is it? You offer no alternative explanation, any more than the paper does (see above).
I will give an explanation that I think will stay in the rules of this forum. It is not a proof, but it is enough for a discussion.
Here is what I mean by "coincidental" in the context of a realist cause and effect interpretation that I am using and in the case where the BSM test is done after the measurements of 1 & 4:
Measuring the polarization of photon 1 changes the polarization of photon 2. Measuring the polarization of photon 4 changes the polarization of photon 3. When 2 and 3 are identical in almost all properties including polarization, the BSM test will determine they are indistinguishable and this indicates that the measurements of 1 & 4 are maximally entangled.
That is how I would describe what is happening in a realistic interpretation of this case. I use the short hand term "coincidental" to describe it and differentiate it from the other case, but clearly there is more going on then just coincidence, but fundamentally coincidence is the driving factor that allows 1 & 4 to be entangled.
So in this realistic description, at no time is the monogamy argument violated. Certainly, the details matter on whether this can be a valid explanation, but these important details set aside, as far as I can tell, there is nothing that @DrChinese is arguing that prevents this from being an explanation of what is actually happening. It produces the same correlation as when the BSM test in the other order and does not violate monogamy.
  • #86
I only said "perhaps". If you really want to make such an argument, you need to make it. I was only pointing out that it's not an argument anyone else has made in these discussions.
Is it just your own, or is it one you have encountered in the literature? It should be the latter, in which case you should be able to provide a reference.
  • #87
You have mixed some good points and some factual errors. "At no time is the monogamy argument violated" is good. "Measuring the polarization of photon 1 changes the polarization of photon 2" is fine as long as you accept it could as easily be the other way around (since ordering makes no difference). The important point is that the swap (BSM) is an essential action.
The polarization of 2 & 3 is one of the things that does not need to be identical (they might or might not). That is tested to determine the Bell state that 1 & 4 are cast into. But going into the beam splitter, the polarization must be unknown for both so that they can be indistinguishable, as you say.
Yours is not what I would call a realistic interpretation. "Fundamentally coincidence is the driving factor that allows 1 & 4 to be entangled" doesn't make sense, because the BSM is the driving factor. Each and every BSM results in 1 & 4 entanglement, and that does not occur otherwise.
  • #88
I am using the general realist position that John Bell and Einstein use when they refer to spooky action at a distance. I don't go into any details as to what that action is beyond that the polarization is changed. That is why I figured it would be safe to use. But to @DrChinese point, I am fine with just calling it some action that influences their respective polarizations versus assigning a particular direction to the action.
Yes, I can agree that it can be the other way around or some mix. And I can agree that the BSM is essential, but in a realist cause and effect interpretation that I am using it is just the test that reveals the correlation, not what causes the correlation.
In the realist cause and effect interpretation that I am using, the BSM test is the test that reveals the correlation, not what causes the correlation. All the actions that happened prior to the BSM test being performed is what caused the correlation between 1 & 4. And if you chose not to do the BSM test, the correlation between 1 & 4 is still there, you just don't have a BSM test to select it from all of your measurement data.
  • #89
I would like to say something about how projection can create entanglement. In the example in #16, the required projector is
$$\Pi=1\otimes 1-\pi_R\otimes\pi_R$$
where ##\pi_R=|R\rangle\langle R|##. The projector ##\Pi## is not separable, i.e. cannot be written in the form ##\pi_1\otimes\pi_2##. In particular, it is not equal to the separable projector
$$(1-\pi_R)\otimes(1-\pi_R).$$
The separable projector above would project the state in #16 to the non-entangled state ##|L\rangle \otimes |L\rangle##.
So the moral is, a projection can create entanglement when the projector is not separable. I'm sure it can be formulated precisely and proved rigorously as a general theorem, but it looks so intuitive that I don't really feel a need for a precision and proof.
  • #90
a. That the initial quantum state is a Product State of 2 entangled pairs: $$\hat{\rho}=\hat{\rho}_{12} \otimes \hat{\rho}_{34}.$$
One has to be careful. The point here is that, at least within the minimal statistical interpretation, the complete ensemble is always described by state (a), i.e., no matter what you measure on the pair (23), if considering coincidence measurements on all four-photon preparations, the statistical outcome of these measurements is predicted by (a).
(b) describes the subensemble, selected by projecting (23) to one and only one of the four Bell states. For each of these four possible subensembles the pairs (14) and (23) are described by the state (b) and thus are entangled.
2. The full set of 1 & 4 will be entangled if and only if there is a successful BSM. But the issue here is that most of the 1 and 4 photons cannot be placed together as pairs. That is because they are created at random times by fully independent sources. So they are not otherwise synced or forced to pair up. Occasionally the sources fire in such sequence that the 2 & 3 photons arrive within a narrow time window and a swap can occur. The partner 1 & 4 photons can be identified in these cases, and all of them will be entangled. The others are ignored precisely because each cannot be matched to anything.
Of course to measure the entanglement of (14) one has to do a coincidence experiment, i.e., one has to be sure to take the pair (23) doing the projection measurement to a Bell state with them associated with the photons 1 and 4 prepared in state (a), but this has been obviously done in these experiments.
DrChinese said:
In principle, there are no 1 & 4 pairs detected that are not entangled (again assuming the BSM apparatus is running). 1 & 4 pairs are identified by having a specific difference in their arrival times. There will be many more lone 1s, and many more lone 4s. You don't actually need the BSM to identify them. Again, this is in principle. In practice, the issue is that you cannot tell which Bell state they arrive in. You need that to run the Bell test.
Sure, you need to select the photons according to the result of the measurement on (23).
In all this it doesn't matter in which temporal order the measurements on (23) and on photons 1 and 4 are done. They can even be space-like separated, and you can post-select the subensemble(s), provided you have the accurate measurement protocols for all these coincidence measurements.
Concerning the causal question, I think due to micorcausality and within the minimal statistical interpretation entanglement swapping demonstrates no non-local causality-violating effects of one local measurement (measurement on the pair (23)) and the others (measurements on photons 1 and 4) but the correlations on the selected subensemble described by state (b) are already due to the correlations implies by the preparation of the full ensemble in state (a).
At least this is a consistent interpretation of the local-QFT formalism which doesn't contradict its mathematical defining properties (in this context most importantly microcausality), and this resolves the EPR paradox, and what has to be given up is the assumption of "reality", i.e., the assumption that all observables take predetermined values and the probabilities were thus only due to ignorance of these values due to the ignorance about the values of some "hidden variables". In this sense what has to be given up is the assumption of separability, i.e., precisely what Einstein considered the most serious quibble he had with QT (according to his Dialectica paper of 1948, which is the far more clearly formulated source about Einstein's point of view than the EPR paper, which Einstein himself didn't like too much).
  • · Replies 96 ·
9K
  • · Replies 85 ·
  • · Replies 54 ·
  • · Replies 32 ·
  • · Replies 178 ·
11K
11K
  • · Replies 60 ·
  • · Replies 27 ·
