Enthelpy of water at triple point and freezing point
The discussion revolves around the enthalpy of water at its triple point and freezing point, focusing on the definitions and calculations of specific enthalpy, internal energy, and the effects of pressure on these properties. Participants explore theoretical implications and practical calculations related to these states of water.
  • Some participants define specific enthalpy as h=u+pv, where u is specific internal energy, p is pressure, and v is specific volume.
  • It is noted that the internal energy of water at the triple point is taken as zero, leading to a positive enthalpy due to the pv term.
  • Participants discuss the change in enthalpy between the triple point and freezing point, suggesting it is primarily due to the change in pressure (Δp) since Δu is zero when ΔT is zero.
  • Some argue that the specific volume of liquid water does not change significantly between the two pressures, leading to a small change in enthalpy.
  • One participant questions the assumption that Δu=0 is valid for liquid water, noting that internal energy is a function of both temperature and pressure.
  • There is a discussion about the appropriateness of calculating enthalpy changes along an isothermal path versus an isobaric path, with some participants expressing uncertainty about the implications of this distinction.
  • Participants provide specific calculations for enthalpy at both the triple point and freezing point, highlighting the numerical differences in values obtained.
Participants generally agree on the definitions and basic calculations of enthalpy and internal energy, but there is disagreement regarding the implications of pressure changes and the validity of certain assumptions in the calculations. The discussion remains unresolved regarding the best approach to calculate enthalpy changes under the given conditions.
Some limitations include the dependence on specific definitions of enthalpy and internal energy, as well as the unresolved nature of how to properly account for pressure changes in enthalpy calculations.
Soumalya
By definition we have h=u+pv for a system
where h=specific enthalpy
u=specific internal energy
p=external pressure applied on the system
v=specific volume of the system
The internal energy is arbitrarily taken to be zero at the triple point of water i.e, u=0 when T=273.16K and P=4.587 mm of Hg.
So at the triple point of water we have enthalpy of water to be slightly positive due to small value of the 'pv' term.
At freezing point,however,we have T=273.16K and P=760 mm of Hg.
So the change in enthalpy could be obtained as Δh=Δu+Δ(pv)
Now, Δu=0 as ΔT=0
and the only difference in enthalpy is due to the Δ(pv) .
At triple point, we have a range of values for 'v' along the triple point line and p=4.587 mm of Hg.
At freezing point, we have v=0.001 m3/kg and p=760 mm of Hg.
So to bring a unit mass of water from triple point to the freezing point a reversible isothermal path could be followed at T=273.16K from P1=4.587 mm of Hg to P2=760 mm of Hg.
Thus the change in enthalpy would be equal to the displacement work done to bring water from the triple point to the freezing point i.e, Δ(pv).
But in most textbooks the enthalpy of water at both triple and freezing points are taken to be equal.Whereas they cannot be theoretically equal in value is this because the change in specific volume is too small to take Δ(pv) into account?
Science news on Phys.org
Soumalya said:
Now, Δu=0 as ΔT=0
Liquid water is not an ideal gas.
Somalya,
You are saying that the internal energy of liquid water at the triple point is taken as zero, correct? Then, yes, the enthalpy of liquid water at 273.16 K and 4.587 mm Hg is pv, where v is the specific volume of liquid water at 273.16 K and 4.587 mm Hg, and p is 4.587 mm Hg. For liquid water at 273.16 K and 760 mm Hg, the enthalpy is pv, where v is the specific volume of liquid water at 273.16 and 760 mm Hg, and p is 760 mm Hg. Of course, in both these cases, you have to use appropriate units. The specific volume of liquid water does not change much between 4.587 mm Hg and 760 mm Hg. So the change in enthalpy between the two cases is basically vΔp, where Δp=(760 - 4.587) mm Hg. Again, you have to use consistent units. Also, since the specific volume of the liquid is very low (1cc/gm), the enthalpy in either case is very low.
Chet
Chet
Thank You Chet
That's what I was confused about...so the enthalpy is pretty much taken the same and closely equal to zero.
Am I wrong here?
I mean as far as I know,Δu=0 when ΔT=0 regardless of the working substance being an ideal gas or any other non-ideal substance.
Is it so that my assumption is incorrect for liquid water?
Soumalya said:
Thank You Chet
Yes. Calculate it yourself and see what you get. It should only take a minute or two. Compare what you get with what is in your table.
Chet
Soumalya said:
Am I wrong here?
In general, u is a function of both temperature and pressure. However, for the situation you are looking at, the effect of pressure on u is orders of magnitude lower than the effect of pressure on h (because h has that pv term). For gases at pressures beyond the ideal gas range, the effect of pressure on both u and h need to be taken into account.
Chet
I just realized it might be wrong to calculate enthalpy the way previously assumed.
Enthalpy is the heat added at constant pressure Δh=CpdT+pΔv.
To take the system at the triple point of water (at a low pressure) to it's freezing point(at a higher pressure) we are following an isothermal path and not an isobaric path so heat added during the process is not heat added at constant pressure.
But the internal energy at the triple point of water is assigned a value zero and hence having practically zero enthalpy as the value of the 'pv' term is almost negligible.So if I wish to calculate the change in enthalpy for water at it's freezing point(at a higher pressure)taking the value of enthalpy at the triple point of water to be zero we must elevate the system at the triple point to a higher pressure at the freezing point and hence a constant pressure process cannot be followed!
Then how is the value of enthalpy for a system at higher pressures assigned?
internal energy of water at 273.16 and 4.587 mm Hg = 0
4.187 mm Hg = (133.32)(4.587)=611.5 Pa=611.5 N/m2
specific volume of water ~ 0.00100 m3/kg
pv = (0.001m3/kg)(611.5 N/m2)=0.612 Nm/kg=0.612 J/kg
For p = 760 mm Hg, pv = 101.3 J/kg
enthalpy at 273.16 and 4.587 mm Hg = 0.612 J/kg
enthaply at 273.16 and 760 mm Hg = 101.3 J/kg
How do these value compare with those in your table?
Chet
Well couldn't find the values at such low pressures as triple point:frown:
What about the point at 273 and 760?
Chet
  • · Replies 0 ·
