Entropy Change of Supercooled Water Freezing Spontaneously
The discussion revolves around calculating the entropy change of the universe when 100 g of supercooled water at -2ºC freezes spontaneously. The calculations utilize the latent heat of fusion (334,700 J/kg) and the specific heat capacities of ice (2090 J/kg·K) and water (4183 J/kg·K). The entropy change of the system is -122.60 J/K, while the surroundings contribute +123.51 J/K, resulting in a total entropy change of 0.9 J/K. The process is confirmed to be irreversible, as the spontaneous freezing does not adhere to the conditions required for reversibility.
  • Understanding of thermodynamic principles, specifically entropy and its calculations.
  • Familiarity with the concepts of latent heat and specific heat capacity.
  • Knowledge of reversible and irreversible processes in thermodynamics.
  • Ability to apply the equation dS = dQ/T for reversible processes.
  • Study the principles of reversible processes in thermodynamics.
  • Learn how to calculate entropy changes using specific heat capacities in various states.
  • Explore the concept of thermal reservoirs and their role in thermodynamic processes.
  • Investigate the implications of the second law of thermodynamics on spontaneous processes.
This discussion is beneficial for students and professionals in thermodynamics, particularly those studying entropy changes, heat transfer, and phase transitions in materials.
sanitykey
A 100 g mass of supercooled water at -2ºC in thermal contact with surroundings also at -2ºC
Calculate the entropy change of the universe assuming that the surroundings act as a large
temperature reservoir. [The specific heat capacity of ice is 2090 J kg-1 K-1, the specific heat
capacity of water is 4183 J Kg-1 K-1, and the latent heat of fusion of water is 334.7 kJ kg-1.]
Is this process reversible?
Change in entropy of the universe = change in entropy of the system + change in entropy of the surroundings
dS = dQ/T (for a reversible process)
latent heat of fusion = l = 334700J/Kg
T2 = freezing temperature of water = 273K
T1 = -2 degrees celsius = 271K
mass = m = 0.1Kg
Change in entropy of the system = (-)m*l/T2 = (0.1*334700)/273 = -122.60J/K
Change in entropy of the surroundings = (+)m*l/T1 = (0.1*334700)/271 = 123.51J/K
Change in entropy of the universe = 123.51 -122.60 = 0.9J/KThe process is irreversibleI have a feeling this is wrong because i haven't used the heat capacities of ice and water (not sure how to) any help would be appreciated, thanks.
mass = m = 0.1Kg
Why would the final temperature be 273K rather than 271 K?
If the liquid water at -2C (271K) turns to ice it must release heat into the surroundings (33.47 KJ). The surroundings are at the same temperature, 271K, and do not change temperature as a result of the change of state of the water and the release of this heat. So how does any part of this occur at a temperature other than 271K?
AM
Thanks for your response, I'm still not quite sure how to work this out though. The reason i used 273K was i was following a (what i thought to be) similar example i found at:
http://www.chem1.com/acad/webtext/thermeq/TE3.html
(the green box about 1/3 down the page)
If i use 271K for both processes then would that make the change in entropy of the universe 0? Would that make it a reversible process?
How do i include the heat capacities? I mean if the temperature of the water/ice isn't actually changing i don't see how i can use them?
Any help is much appreciated.
You need to apply the equations to a reversible process, which spontaneous freezing isn't. An appropriate process would be:
1) Take the supercooled water up to 0°C reversibly
2) Freeze the water (at 1 atm, 0°C is the only temperature for which freezing is reversible)
3) Take the ice back down to -2°C reversibly
The outcome is the same, but the whole process is now reversible. The heating and cooling steps are where the heat capacities come in. You can find more information on this technique in most thermo texts.
This is correct. The change in entropy is defined as the integral of dQ/T for the reversible path. Since ice will never melt at -2C in these surroundings, the spontaneous freezing of supercooled water at -2C is not reversible.
The path Mapes has given can be reversible (for example the water is heated and the ice is then cooled using a Carnot heat pump between the water and the surroundings). The change in entropy of the water is:
\Delta S_{water} = \int_{-2}^{0}mCdT/T + \left{(}-\frac{Q_{fusion}}{T_{0}}\right{)} + \int_{0}^{-2}mCdT/T = -Q_{fusion}/T_{0} = -33.47/273
since the integrals cancel each other. Similarly, the change in entropy of the surroundings (temperature constant at 271K) is:
\Delta S_{surr} = mC\Delta T/T + Q_{fusion}/T + mC(-\Delta T)/T = Q_{fusion}/T = 33.47/271
So the total change is:
\Delta S = \Delta S_{water} + \Delta S_{surr} = -33.47/273 + 33.47/271 > 0
Since the change in entropy of the universe is positive, the process is not reversible.
AM
I got caught up in exams recently and didn't get a chance to respond to this but it's a perfect explanation thanks!
