How Do You Relate Entropies to Temperatures in Water Mixing?
The discussion focuses on relating entropies S1 and S2 to temperatures during the mixing of water solutions. Participants emphasize the importance of reversible processes to compute entropy differences, specifically ΔShotter and ΔScooler, as the solutions reach thermal equilibrium. The total change in entropy is expressed as ΔSc + ΔSh, with a note on the necessity of manipulating the final expression to fit specific requirements. The conversation also touches on the calculation of total entropy changes when dealing with different masses of water.
  • Understanding of thermodynamic principles, particularly entropy.
  • Familiarity with reversible processes in thermodynamics.
  • Knowledge of mass-specific heat of water.
  • Ability to manipulate mathematical expressions involving entropy calculations.
  • Study the concept of reversible processes in thermodynamics.
  • Learn how to compute entropy changes for different states in a system.
  • Explore the relationship between temperature and entropy in mixing processes.
  • Investigate the mathematical manipulation of expressions in thermodynamic equations.
Students and professionals in thermodynamics, chemical engineering, and physical chemistry who are involved in entropy calculations and water mixing processes.
gfd43tg
I don't know how to relate the entropies, S1 and S2, to the temperatures in my entropy balance
  • 5.22 attempt 1.pdf
    5.22 attempt 1.pdf
Can't say I understand your attempt.
In order to determine entropy differences you have to come up with one or more reversible processes. Then you can compute the difference in entropies before & after.
Hint: take the hotter water solution and reversibly reduce its temperature from its original temperature to the final temperature of the two solutions. Compute ΔShotter.
Do the same for the cooler solution.
You wind up with two solutions of equal temperature, then you can mentally just pour them together without any further changes in any thermodynamic coordinate.
Answer will be ΔScooler - ΔShotter.
I am just doing an entropy balance on my control volume, being the tank where the two liquids are mixed. I just can't find an absolute value of entropy for S1 and S2
You never deal with absolute entropies in introductory physics. You deal in differences in entropy between two (or more) states.
So the hotter water's entropy changes by ΔSh and the colder by ΔSc. The total change in entropy is ΔSc + ΔSh.
I was able to solve it. The tricky thing at the end is to get it in the form they want, you have a squared term on top, so you have to take out a square from the top and bottom to make the bottom have the square root in it.
For the part with two masses being different, if I add them together, how can I get one expression for the total entropy? I can get the mass specific total entropy change, but not sure about the total entropy change.
yes, I noticed that too.
I don't know how exactly you did the math. If you did it the way I suggested it's a straightforward extension of the method. You compute the two entropy changes independently and then add them. You don't need specific entropies. Of course, the final temperature will not be the mean of the two starting temperatures.
Post your math if you want to.
EDIT Sorry, I hadn't noticed mass-specific heat of water already used in part (a). Of course, use it again for part (b). This is usually written with a lower-case c which is what threw me off in the originally provided answer.
