Epsilon Delta proof of a 2variable limit. Is my proof valid?
The discussion revolves around proving the limit of (x*y^3)/(x^2 + 2y^2) as (x,y) approaches (0,0) using the epsilon-delta definition. Participants explore whether the inequality |x|/sqrt(x^2 + 2y^2) can imply |x|/(x^2 + 2y^2) and discuss the implications of using polar coordinates for simplification. They suggest setting delta as a function of epsilon to establish the limit, with various proposed values for delta, including 2sqrt(epsilon) and sqrt(2epsilon). The conversation highlights the need for careful handling of inequalities and the importance of absolute values in the proof. Ultimately, multiple approaches to defining delta are considered valid, emphasizing the flexibility in epsilon-delta proofs.
AutumnWater
Use the epsilon delta definition to show that lim(x,y) -> (0,0) (x*y^3)/(x^2 + 2y^2) = 0
sqrt(x^2) = |x| <= sqrt(x^2+y^2) ==> |x|/sqrt(x^2+y^2) <= 1 ==> |x|/(x^2+2y^2)?
This limit is true IFF for all values of epsilon > 0, there exists a delta such that:
0<sqrt(x^2+y^2)<delta ==> |(x*y^3)/(x^2+2y^2)| < epsilon
When checking my answers, I'm stuck at this step:
Can: |x|/sqrt(x^2+2y^2) <= 1 imply that |x|/(x^2+2y^2) will also be <= 1?
I'm skeptical as it seems wrong, but if this step holds, then the rest of my proof can be as follows:
(|x|/(x^2+2y^2))*|y^3| <= |y^3| = |(y^2)^(3/2)| <= (x^2 + y^2 ) ^ (3/2) < (delta)^3
thus
let delta = (epsilon)^(1/3) and we get:
sqrt(x^2+y^2)<epsilon^(1/3) ==> (x^2+y^2)^(3/2) < epsilon ==> (y^2)^(3/2) = y^3 < (x^2+y^2)^(3/2) < epsilon;
Since |x|/(x^2+2y^2) <= 1, (|x|/(x^2+2y^2)) * |y^3| < |y^3| < epsilon;
and we have f(x) < epsilon.
thus
No. (Take x=0.5 and y=0.1 for example)
Hint: ##\frac{1}{x²+2y²}\leq \frac{1}{2y²}##
thanks, I'll go review my polar coordinates chapters first :P
That works too. :oldsmile:
so we have: f(x,y) = (xy^3)/(x^2+2y^2)
since 1/(x^2+2y^2) <= 1/2y^2
f(x,y) <= (xy^3)/2y^2 where (xy^3)/2y^2 = xy/2 = p^2 sin(2theta) / 4 (let that = g(p,theta))
since sin(2theta) is between [-1, 1],
-p^2/4 <= g(p,theta) <= p^2/4
and f(x,y) is <= g(p,theta)
does that mean I should set delta = 2sqrt(epsilon) here then?
We need 0<p<delta to imply g(p,theta)< epsilon, since we know g(p,theta)< p^2/4, if we set delta = 2sqrt(epsilon), 0<p<2sqrt(epsilon) ==> (p^2)/4 < epsilon, then it works?
So in the end we have:
1) 0<sqrt(x^2+y^2)<delta where sqrt(x^2+y^2) = p, set delta = 2sqrt(epsilon)
2) |f(x)| <= g(p,theta) <= p^2/4 < epsilon
since p<2sqrt(epsilon) ==> (p^2/4) < epsilon
we have a connection between 1) and 2) here.
I assume you mean 1/(2y2) on the right hand side.
1/(x^2+2y^2) ≤ 1/(2y2) implies that x2 ≥ y2. Did you really mean that?
If you're going to change this to polar coordinates, Nothing is more convenient to convert than x2 + y2 .
After all, x2 + y2 = r2 .
Added in Edit:
Somehow I missed seeing the coefficient of 2 on the y2 in the denominator, so ignore this, which it seems you have. (thankfully!)
yes I meant 1/(x^2+2y^2) <= 1/(2y^2) implies (xy^3)/(x^2+2y^2) <= (xy^3)/(2y^2)
You need some absolute value signs: the inequality is reversed when xy &lt; 0.
Ok thanks.
Here I got 2 different deltas, would it be safe to say both are correct, only one is even more closer than the other one?
If looking at the initial equation directly:
We have:
$$|(xy^3)/(x^2+2y^2)| = [(p^2*(sin(theta))^2*sin(2theta))/2(1+(sin(theta))^2)] <= (p^2)/2 < epsilon$$
so we set delta = sqrt(2epsilon)
If looking at the equations from the perspective of $$|xy^3|/2y^2$$: then delta's $$2sqrt(epsilon)$$ according to previous post.
You could make it a lot simpler by substituting ##y=z/\sqrt 2## before going polar.
would it? whilst there will be a coefficient of $$1/(2^{3/2})$$ on the numerator of the f(x) only when doing the z substitution, the equation for delta wouldn't be p=sqrt(x^2 + y^2) anymore, instead it would turn out to be sqrt(x^2 + (z^2)/2) wouldn't it?
so $$|(x^{2} + (z^{2})/2))^{1/2}| <= delta$$ needs to imply $$|((xz^{3})/(2^{3/2}) / (x^{2} + z^{2})| < epsilon $$ ?
in polar form that would amount to:
sqrt(5p^2/4) < delta needs to imply that p^2/2 < epsilon
(sorry, I will get a hang of latex codes soon)
So make delta a bit smaller for the given epsilon.
oops, the p^2/2 < epsilon earlier didn't include the $$1/(2^{3/2})$$
so if it was $$(1/(2^{3/2})) * (p^2/2) < epsilon ==> p^2/2 < 2sqrt(2)epsilon ==> p < 2 (2^{1/4})\sqrt(epsilon)$$
and $$\sqrt(5)p/2 < delta ==> p < 2(delta)/\sqrt(5)$$
make ps equal, and I got $$\sqrt(5)(2^{1/4})\sqrt(epsilon) = delta$$ which is about 2.659 times $$\sqrt(epsilon)$$, bigger than the other two...
so far I've had: $$\sqrt(2epsilon)$$, $$2\sqrt(epsilon)$$, and now $$(2^{1/4})\sqrt(5epsilon)$$
  • · Replies 31 ·
  • · Replies 27 ·
