Equating differentials => equating coefficients
The discussion revolves around the mathematical justification for equating coefficients in the context of thermodynamics, specifically regarding the expression of differentials and their implications for functions. Participants explore the conditions under which certain conclusions can be drawn from equations involving differentials.
  • Some participants assert that if the equation A dx + B dy = ∂f/∂x dx + ∂f/∂y dy holds, then A must equal ∂f/∂x and B must equal ∂f/∂y, under the assumption that dx and dy are linearly independent.
  • Others challenge this conclusion, noting that it is not universally true and referencing the concept of exact differentials.
  • A participant suggests that the constants introduced in the equations must vanish, questioning the justification for this assumption.
  • Another participant introduces the idea of treating dx and dy as orthogonal vectors, implying a geometric interpretation of the problem.
  • Some participants clarify that the differentials used in Maxwell relations are exact, while work and heat are considered inexact differentials.
  • One participant proposes a method of setting dx or dy to zero to derive the values of A and B, indicating a practical approach to the problem.
Participants express differing views on the necessity of equating coefficients in the context of differentials, with some supporting the conclusion and others contesting its validity. The discussion remains unresolved regarding the justification for the vanishing of constants and the conditions under which the initial assumptions hold.
There is an ongoing uncertainty regarding the conditions under which the differentials are treated as independent and the implications of exact versus inexact differentials in thermodynamics.
Derivator
Hi all,
In thermodynamics one often has equations like
From which follows
A = ∂f/∂x
B = ∂f/∂y
Can anyone explain to me why this conclusion is necessary from a mathematical point of view, please?
Here is my try:
(A-∂f/∂x )dx + (B- ∂f/∂y)dy = 0
since the terms in front of the differentials are independent of each other:
(A-∂f/∂x ) = const_1
(B- ∂f/∂y) = const_2
However, I cannot justify why const_1 = const_2 = 0
Derivator
Science news on Phys.org
This is not always true. See, exact differentials.
But on this the derivation of the maxwellequations is based!?
Derivator said:
Hi all,
From which follows
A = ∂f/∂x
B = ∂f/∂y
Let's suppose that dx and dy are linearly independent of each other. This may not always be true, especially if y is a function of x. However, we'll work under the assumption that dx and dy are linearly independent.
Then, from this point of view, there is no scalar you can multiply dx by to get dy. Thus, we can split the equation into two parts, one for each independent form. That is,
$$\begin{matrix} A \, dx = \frac{\partial f}{\partial x} \, dx \\ B \, dy = \frac{\partial f}{\partial y} \, dy\end{matrix}$$
Maxwell equations or maxwell relations?
Sorry, i meant maxwell relations, of course.
The differentials used for Maxwells relations are exact - dU, dS, dP, etc. Work and heat, for example, are inexact though.
As I showed in my first post, I only can see that
$$\begin{matrix} A \, dx = \frac{\partial f}{\partial x} \, dx + const_1 \\ B \, dy = \frac{\partial f}{\partial y} \, dy + const_2 \end{matrix}$$
Why do the both constant have to vanish?
Derivator
Derivator
Think of dy and dx as orthogonal vectors. They are actually covectors, but that's more math and less physics.
For example, ##\begin{bmatrix} A \\ B \end{bmatrix} = \begin{bmatrix} \frac{\partial f}{\partial x} \\ \frac{\partial f}{\partial y} \end{bmatrix}## is the same as saying ##A \hat{i} + B \hat{j} = \frac{\partial f}{\partial x}\hat{i} + \frac{\partial f}{\partial y}\hat{j}##.
Derivator said:
Hi all,
From which follows
A = ∂f/∂x
B = ∂f/∂y
Set dx = 0
you'll get Bdy = [itex]\partial f/\partial y[/itex] dy .
So B = [itex]\partial f/\partial y[/itex]
Similarly you'll get the value of A by setting dy = 0.
