Equation for a floating solid sphere
The problem involves a sphere floating in water, which is pushed underwater and released. The task is to derive the equation of motion for the sphere without assuming small oscillations, while considering the effects of buoyancy and submerged volume.
  • Participants discuss the necessity of including the changing buoyant force as the submerged volume varies. There are inquiries about the submerged volume as a function of the sphere's position and the implications for the equation of motion.
Some participants have provided hints regarding the calculation of submerged volume and the need to establish the equation of motion first. There is an acknowledgment of the complexity of the problem, with references to non-linear differential equations and the potential for oscillation analysis.
The problem specifies that the equation of motion must be derived before determining the period of oscillations, and it is noted that the coordinate 'y' represents the position of the sphere's center. The discussion reflects a mix of interpretations regarding the approach to the problem.
Grand
A sphere is floating in water. It is pushed just under the water level and released. I'm asked to write the equation of motion for the sphere, not assuming small oscillations.
Is it just:
[tex]my''=\rho V g - mg[/tex]
Or do I have to include that the buoyant force is changing while the volume under water changes as well?
Yes, you have to include it.
ehild
Any hint on how to do this?
Calculate the volume of the sphere submerged in water as function of y.
ehild
I found that the submerged volume is:
[tex]V=\frac{4\pi}{3}a^3-\frac{\pi(a-y)^2}{3}(3a-(a-y))=\frac{\pi}{3}(2a^3+3a^2y-y^3)[/tex]
but how do I find the period of oscillations from here on?
The text says that you have to write the equation of motion.
What is y?
ehild
The problem says find the eq of motion and then the period of oscillations (not small) but surely the first step is the equation of motion.
y is the coordinate of the centre of the sphere.
Are you familiar with non-linear second order differential equations? Can you find limit cycles? It is certainly not Introductory Physics.
You can find the period of small oscillation around the equilibrium position of the sphere.
ehild
  • · Replies 21 ·
  • · Replies 97 ·
