Equation for velocity of center of mass
The equation for the velocity of the center of mass (VCM) is derived from the total linear momentum of a system divided by the total mass. The formula is expressed as v_{CofM} = p / M_{total}, where p represents momentum. This discussion confirms that the momentum of the center of mass reflects the total linear momentum of the system, particularly in elastic collisions where VCM remains constant before and after the collision. The example provided calculates the total linear momentum as 15.5 Ns for a system with masses of 3 kg and 2 kg moving at a velocity of (3.00i - 0.8j) m/s.
  • Understanding of linear momentum and its calculation
  • Familiarity with the concept of center of mass
  • Basic knowledge of calculus for differentiation
  • Concept of elastic collisions in physics
  • Study the derivation of momentum equations in classical mechanics
  • Learn about the conservation of momentum in elastic and inelastic collisions
  • Explore the implications of center of mass in multi-body systems
  • Investigate advanced applications of calculus in physics, particularly in dynamics
Students of physics, educators teaching mechanics, and anyone interested in understanding the principles of momentum and center of mass in physical systems.
UrbanXrisis
What is the equation to find the velocity of the center of mass?
since...
x_{CofM}=\frac{m_1x_1+m_2x_2}{M_{total}}
then...
v_{CofM}=\frac{d(m_1x_1+m_2x_2)}{dt(M_{total})}
this means...
if p=momentum
v_{CofM}=\frac{p}{M_{total}}
is this correct?
Though i didn't understand very well what your formulas meant (i must be having a bad day :-p ),i can tell you that it's the other way around:
VCM (velocity of the center of mass) results immediately by computing the total (linear) momentum in 2 ways...
Daniel.
I'm not quite sure I undersatnd what you are saying...what 2 ways?
let me explain.
is the equation to calculate the distance of center of mass. I took the derivative of it to find the velocity. Therefore, my second equation was the velocity of the center of mass. My third equation went further to say that d(m1v1+m2v2)/dt was really momentum. So... VCM is really momentum over the total mass
I know what u did.It's not wrong at all.I've just given u an alternative approach and i think much more intuitive.
Daniel.
does the momentum of the center of mass tell the total linear momentum of the system?
Or do I have to caculate the momentum of each object and then add them together?
Of course.The total linear momentum of the system is the linear momentum if the CM.
Daniel.
in an elastice collision, the VCM is the same before and after to collisions right?
Yes,and that's due to total linear momentum conservation.
Daniel.
Daniel.
I have the velocity of the CM to be (3.00i-0.8j)m/s
would the total linear momentum be...
v=\sqrt{3^2+.8^2}
v=3.1m/s
p=(m_1+m_2)v
p=(3kg+2kg)3.1m/s
15.5Ns
Would 15.5Ns be the total linear momentum?
  • · Replies 27 ·
