Equation of Normal: M(2,3,1) to Line l
  • Thread starter Thread starter chmate
    Normal
The discussion focuses on deriving the equation of a normal plane from the point M(2,3,1) to the line defined by the equation \(\frac{x+1}{2}=\frac{y-0}{-1}=\frac{z-2}{3}\). Participants emphasize the need to calculate the direction vector of the line, find the intersection point between the line and the plane, and utilize the cross product to determine the normal vector of the plane. The normal vector shares the same direction as the line's direction vector, which is essential for formulating the plane's equation.
  • Understanding of vector mathematics and direction vectors
  • Familiarity with the equation of a plane in 3D space
  • Knowledge of cross product operations in vector calculus
  • Ability to solve linear equations involving multiple variables
  • Learn how to derive the direction vector from a line equation in 3D space
  • Study the formulation of the equation of a plane given a point and a normal vector
  • Explore methods to find the intersection point between a line and a plane
  • Review the properties and applications of the cross product in vector analysis
Students and professionals in mathematics, physics, and engineering who are working on problems involving vector calculus, particularly in 3D geometry and the analysis of lines and planes.
chmate
Write equation of normal from point M(2,3,1) into line:l: \frac{x+1}{2}=\frac{y-0}{-1}=\frac{z-2}{3}.
I just have no idea about this problem. Any hint?
Thank you.
What is the relationship between the line and the normal?
Calculate the plane normal to the given line and that passes through 2,3,1
Then calculate the point where the given line and the plane intersect.
This point will enable you, together with the (2,3,1), to calculate the direction of the normal to the given line
marlon
marlon
Let me understand this. I have to create a plane which passes through that point. Another point is point of intersection. But to find that point i must have a direction vector of that plane and I don't have so can you help me with point of intersection. How can i find it?
So, when I have that point I have to create a vector which passes through point (2,3,1) and point of intesection and cross product of vector direction of line and vector I created will create a normal vector of plane. Am I right?
Thank you.
Thank you.
Let's take this one step at the time :
First you need to find a plane that contains the point (2,3,1) and that is normal to the given line (your first equation).
Let's start with that.
Do you know how to do this ?
marlon
No, can you help me with this and line of intersection?
Thank you.
Thank you.
let's say that the plane has equatiuon ux+vy+wz+t=0 where (u,v,w) is the normal vector of the plane and t is a constant. We need to find u,v,w and t.
A) find u,v,w
B) find t
For A) i say that (u,v,w) denotes the same direction vector as the line.
Do you know why and if so, what's the direction vector of the line ?
If you have u,v,w then you can use the fact that (2,3,1) lies on the plane to find t
marlon
So the normal vector has the same direction as line. So how to find that vector and t?
Well, you know the normal vector (u,v,w) and you know one point on the plane
Substitute these two variables in the ux+vy+wz+t=0 and solve for t
marlon
  • · Replies 23 ·
