Equation relating mass, time, distance, velocity, and force?
The discussion centers on deriving an equation that relates mass, time, distance, velocity, and force under the context of Newton's laws of motion. The specific scenario involves a mass of 5.6664g, an initial velocity of 0, a final velocity of 100m/s, and a time of 0.5s with constant force. The relevant equation identified is v = u + at, where acceleration a is defined as F/m. The acronym SUVAT is recommended for further exploration of equations of motion under constant acceleration.
  • Understanding of Newton's laws of motion
  • Familiarity with the SUVAT equations for motion
  • Basic knowledge of force, mass, and acceleration relationships
  • Ability to manipulate algebraic equations
  • Research the SUVAT equations in detail
  • Learn how to calculate acceleration using F = ma
  • Explore examples of constant force scenarios in physics
  • Study the implications of varying mass in force calculations
Students and professionals in physics, engineers working with motion dynamics, and anyone interested in applying Newton's laws to real-world problems.
The Exestentialist
Posted in wrong forum, so no template
I need to figure out an equation for the following situation: A force will be applied to an object with a certain mass. When the object has moved a certain distance over a certain time, it will have a certain velocity. I realize I wrote that out like a textbook question, but that's just to make it easier to understand. Believe me, I've done my fair share of googling and I can't seem to find anything which is leading me to believe that this is too many variables in one equation. Any help would be appreciated.
Depending upon the information you have Newton's first two laws / equations of motion can be used to analyse this situation.
Sorry, forgot to mention that in the initial post. Mass is 5.6664g, initial velocity of 0, final velocity is 100m/s, distance is variable, and time is 0.5s.
Okay, so you need an equation to relate the mass, velocity, time and force? Is the force constant? How about v=u+at , with a=F/m
Does that satisfy your query?
Force is constant, yes. Can I ask what u represents in that equation?
It is initial speed.
Google SUVAT. There are five standard equations for motion in one dimension under constant acceleration. Each involves four of the same five variables (from which the acronym SUVAT is taken). The trick is to figure out which three you know, which you want to find, then pick the equation with those four.
In your problem, you are given that net force is constant. That tells you the acceleration is constant, so you can use SUVAT.
You are a lifesaver. Thank you.
  • · Replies 18 ·
16K
  • · Replies 25 ·
