Equations relating to a loudspeaker?
  • Thread starter Thread starter doomsdaydave1
This discussion focuses on the physics of loudspeakers, specifically how to relate equations to determine air pressure and sound volume. The speaker is modeled as a driven damped harmonic oscillator, with the driving force derived from the Lorentz force law. Air pressure is calculated by dividing the force exerted by the coil by the membrane's surface area. Additionally, it is noted that the perceived volume is logarithmically related to the air pressure, and diffraction principles explain the size requirements for bass speakers.
  • Understanding of driven damped harmonic oscillators
  • Familiarity with the Lorentz force law
  • Knowledge of basic algebra for calculating pressure
  • Concept of sound diffraction and its impact on speaker design
  • Research the mathematical modeling of driven damped harmonic oscillators
  • Study the application of the Lorentz force law in audio engineering
  • Explore the relationship between air pressure and perceived sound volume
  • Investigate sound diffraction and its implications for loudspeaker design
Physics students, audio engineers, and anyone interested in the principles of loudspeaker design and sound propagation.
doomsdaydave1
Hi guys, although this is for a class project, this isn't really a traditional homework question, so the mods can move this if they like, though.
I scrapped some hard drives and made a stereo speaker set for a physics project, but now to complete this project I need to relate some equations for it.
Assuming this is the most basic magnet/coil/membrane speaker, what would be a basic (algebra) equation that I could use to determine, say, air pressure? Or some other measurable quantity that results from "turning it up."
Thanks.
This is actually quite a complicated problem, but let's just see here. The membrane can be modeled using a driven damped harmonic oscillator. The driving force is given by the force on the coil due to the current and magnetic field. The Lorentz force law for conductors should work for that. The air pressure can be estimated by dividing the force by the membrane's surface area. This is the important quantity for volume. I believe the volume perceived by animal (human included) ears is proportional to the logarithm of the pressure, so that an exponential increase in peak pressure is perceived as a linear increase in volume.
That should get you started.
You could also use diffraction to justify the size of the loudspeaker, the reason bass speakers are so large for instance is that for low frequencies single-slit diffraction requires a large slit for the intensity of the sound to be localized in a narrow angle-range.
  • · Replies 20 ·
  • · Replies 43 ·
  • · Replies 18 ·
