Equilibrium Ball attached to wall problem
The discussion focuses on solving a physics problem involving a uniform sphere held by a massless rope attached to a frictionless wall. The tension in the rope is derived as T=(mg/L)*sqrt(L^2+r^2), where m is the mass of the sphere, g is the acceleration due to gravity, L is the distance from the wall to the center of the sphere, and r is the radius of the sphere. The force exerted by the wall on the sphere is calculated as F=mgr/L. The participant successfully solved for the force on the sphere but initially struggled with the tension calculation before receiving guidance on evaluating trigonometric functions in terms of given lengths.
  • Understanding of torque and net force concepts in physics
  • Familiarity with trigonometric functions and their applications in physics
  • Knowledge of the Pythagorean theorem
  • Ability to set up and solve equations based on physical principles
  • Study the derivation of tension in systems involving pulleys and ropes
  • Learn about equilibrium conditions in static systems
  • Explore applications of torque in real-world scenarios
  • Investigate advanced problems involving forces and motion in physics
Students studying physics, particularly those focusing on mechanics, as well as educators looking for examples of problem-solving techniques in static equilibrium scenarios.
brendan3eb
A uniform sphere of mass m and radius r is held in place by a massless rope attached to a frictionless wall a distance L above the center of the sphere. Find (a) the tension in the rope and (b) the force on the sphere from the wall.
net torque = 0
net force = 0
t=force of tension
F=force of wall
mg=gravitational force on ball
well, strangely enough I am able to solve for part B. choosing the point where the string is attached to the wall as my origin. I am able to determine the torque caused by tension to be 0 as the tension force runs 180 parallel the string. Using motion arm times force = torque, I can find the remaining torques so that:
-mgr+t*0+L*F=0
which yields
F=mgr/L
which is the correct answer to part B. However, I have no clue how to solve part A. I have already used my torque, so I tried setting the force equations for the x and y-axis to 0.
T*cos(x)-mg=0
F-T*sin(x)=0
but that doesn't get me anything close to the correct answer of
help please
T*cos(x)-mg=0
F-T*sin(x)=0
Either one of those force equations will get you the answer. Hint: Evaluate sin(x)--or cos(x)--in terms of the lengths given.
oh, thanks!...so
t*cosx-mg
t*cosx=mg
replace L/a for cosx
t*(L/a)=mg
t=mg/L*a
by pyth. theorem a = sqrt(r^2+L^2)
t=(mg/L)sqrt(r^2+L^2)
THANK YOU SO MUCH! It feels so good to get that problem done. For awhile I thought that there would be something way complex to do that would take a lot of work...and I was intimidated to go any further. Thanks again.
  • · Replies 21 ·
  • · Replies 18 ·
